Lordoftheflies
Newbie - C-81
Lordoftheflies
One of my neighbors is trying to offload a C-81....for free. He just wants me to get rid of it.
I don't have a big property and most of it is rocks.....but I could see using this to plow my rather large driveway although I'd need to buiild a shed to store it.
As a newbie I'd like to ask for some help. Currently the tractor doesn't start. Previous owner says he can see the fuel filter isn't showing any activity so my guess was that it's the fuel pump that needs to be replace. Engine tries to crank but it's most likely not getting any fuel.
Any help is greatly appreciated. He added weights to the rear wheels, filled the wheels with windshield washer fluid, and it has chains. Also has the mower attachment. 8HP. I haven't taken possession of it yet because it's at the bottom of a steep driveway so it will be a royal pain to push it up to get it out!
Hm not letting me upload even one picture.
Pics.
  • Like 7
leeave96
IMHO - a C81 is a very good tractor.  It will make a great snow moving machine.  Once you get accustomed to it, you will likely find it useful for other chores.
Get the tractor!
953 nut
:WRS:    You have come to the right place. It isn't too unusual for a :wh: that has been sitting for a while to have fuel issues, the ethanol fuel being sold today will eat rubber fuel lines. Start out by removing any fuel from the tank and replace the fuel line and filter. Also, remove the carburetor and clean it up with a little lacquer thinner and put in a new needle and seat. You can get a kit on :techie-ebay: for around $12. When you fill the tank you want to use ethanol free gas, go to buyrealgas.com put in your zip code and it will let you know where to find it.
Good luck and please keep us posted.        :text-welcomeconfetti:
AMC RULES
:WRS:
muz123
welcome!
coolhandblack
What are you waiting for? I'd be all over that for free!
Ed Kennell
You should probably not touch that tractor.  They have been known to cause the dreaded WHA disease.
  I am already afflicted, so I would be able take it off your neighbors hands without spreading the illness.:wacko:
                    :text-welcomeconfetti:  to  :rs:
  • Like 6
elcamino/wheelhorse
Be very careful of the Forum disease , if you are married you will constantly here " Quit looking at the Wheel Horse Forum, we can not afford any more of those D_ _ _ Wheel Horse Tractors" . Your ears will hurt after a week or two. It only takes a few day for the Forum Disease to take hold of your brain.
doc724
Take the machine.  It looks in pretty good condition (much better than the C101 I restored this past spring).  Everything all the other posters said is good info.  However, although you likely have a fuel delivery problem, you could also have an ignition problem.  A quick way to tell is to remove the spark plug and put about 1cc (a teaspoon) of gas down the spark plug hole.  Put the plug back in and put the plug wire on and crank away.  If the spark is good, the fuel will ignite and the engine will run for a few seconds.  Then you know it is a fuel delivery problem.  It could be a fuel pump (after all it is about 37 years old).  Also, if the vent in the gas cap is clogged, the fuel pump cannot pull the fuel forward.
JERSEYHAWG /  Glenn
get it and welcome to the best place.
Glen
AMC RULES
After you've tried Doc's suggestion, and it fires/runs...
You should be able to pull the old fuel line from the carb,
and hook up a temporary line that gravity feeds from a fuel can...
to drive it up that hill, and start your :wh: addiction. :handgestures-thumbupright:
Good luck...let us know how it goes.
:handgestures-fingerscrossed:
  Edited by AMC RULES
JC 1965
Hello and   :WRS:
DennisThornton
Mostly what they already said.  The real concern is not the C-81 but what will become of you!  Especially if you hang out around here!
But, it's most likely too late for you so back to the tractor.  Pull the plug wire and test for spark with a used plug or tester if you got one.  If you have a good spark:
Pour a little gas down the carb, choke it and crank.  Most likely you'll hear a very satisfying sound and your disease will progress.
Drain all the gas from the tank, lines, filter and fuel bowl. Check 'em, clean good, blow them out, make sure the float AND needle will move up and down, put 'em back or replace the lines and filter.  Put some fresh gas in the tank, dribble some more in the carb, crank again and hopefully drive it around.  Then you will be hooked forever.  If not come on back or run for your life while there is still hope!
My ailment began with a C-85.  Then with a C-81, actually now setup like yours with a blade.  REALLY NICE piece of equipment!  All the horsepower needed for the blade or a 36" deck!  Now I have several from very old to fairly recent.  Big ones and little ones and my affliction is very mild compared to others!  Wait 'till you see some of these collections!
Aldon
:WRS:
Lordoftheflies
Awesome. Thanks for the warm welcome and the great advice. Battery is also dead. And it's probably been a while since the po tried to start it.
Will post back upon progress. Thanks again!
Edited by Lordoftheflies
Rob R
Great Machine, I own one and would not be without...... great snow pusher...... If you can't get it going trailer it to Brewster, NY and I will get it going for you or if you decide you don't want it just let me know..... put a 75 watt or greater drop light next to the engine  for a hour prior to going out in the dead of winter and that little eight will start and purr like a kitten..... you'll be amazed at how much power they have......
Edited by rgrottk
wrong picture
SylvanLakeWH
I had similar issue with my recent first WH - a free c105. New Fuel line, filter and new gas and boom...runs like a charm...
Take it, get it running, then enjoy the excellent advice of the folks who seem to live on this forum when they aren't driving their WHs or fixing them...
Welcome!!!
woodchuckfarmer
I think the K181 was one of the best engines Kohler made.
  • Like 4
Pullstart
That's a clean freebie alright!  You have essentially the same powertrain as what I've put in my 1962 502 and it's amazing what I can accomplish with it.  Enjoy and welcome to the asylum.
DennisThornton
Great snow pusher!  Even a lowly 8 hp!  In my neck of the woods I think it is one of the best uses for an 8 horse WH!  And don't be trying to divert this machine to Brewster when it's obvious that Peru, NY (near Plattsburgh!) would be a MUCH better home for it!
Brian01
Freaking yankies! lol welcome To Red Square!
Brian01
So? Did you ever get the c81? Get it running?
  • Similar Content
    • giddyap
      By giddyap
      I hope to make "It's my thing" my archival record. My first, It's my thing, "I do what I wanna do" is about my wheel standing Wheel Horse, this is about my C-81. Stock machines are just NOT my thing, I have to modify them to my pleasing, to be the apple of my eye, eye candy, or beauty is in the eye of the beholder. In other words, please take no offense in what I choose to do to my property. When I submit more "It's my thing" you know what to expect.
      First photo is when it came home in stock condition. 2nd photo I removed the wrap around gas tank and added the underseat box and flip seat pan. 3rd photo atv 25x10-12 tires and raised seat pan. 4th is working mode. 5th added a 3/8 thick rubber scrapper between blade and cutting edge. Photos 6&7 light bar and back rest, a rear hanger to carry 60 pounds and the front of the hood is chopped 2 inches for a much improved profile. Somewhere between photos I sold the complete engine, PTO and wiring, removed PTO lever and dropped in a Predator
    • Redneckdavis
      By Redneckdavis
      This is going to be a slow project probably but I figured I'd start a build thread. I bought a pulling horse and it came with this c-81 for extra parts. Also a kid's puller for my little girl.
           Homely looking thing missing front tires, and engine. Steering was rusted seized along with pedals and linkages. Extra hood(I don't know what it fits) and back fenders came from the grass next to where it had began to rot into guys yard. Who knows what else its missing but rear end oil is clean and it rolls.
         This is the wife's tractor. She originally wanted any tractor I could modify and turn into a mini Ford 8N. She has since fell in love with the horse and wants it built as is.
    • Pullstart
      By Pullstart
      I picked this C-81 up a while back when I grabbed the C-145 for Jim.  It was apparently a runner, but had been sitting a while and his mechanic told him it smokes and needs overhauling.  The fuel smells worse than varnish.  I shot a bit of starting fluid in after cleaning the points and away we go!  It drives great in all gears, high and low.  It sure smokes, but I’d like to see what some sea foam and fresh fuel will do for the old girl!  I notice the fuel line is cracked, so I’ll plan a fresh fuel system before anything else.
    • mhlmeader
      By mhlmeader
      Hi folks, I been on a quest lately to find a wheelhorse or two that I would actually use for mowing/work, instead of just putting around on.  I mow about 1.5 acres and have been using a husqvarna with 36 inch deck.  This past week I picked up two horses that I think will finally fit the bill.  Last week I got the 312-8.  And the other day,  I found this c-81.   It was owned for the last 25 years by the same family, hes a retired mechanic and took great care of it.  When I arrived to pick it up, he was actually greasing the deck for me:).  New paint,  tires, battery, belts.  He didn't refinish the deck, but maintained it very well.  I only had one picture to go on, when i agreed to buy it, but was VERY impressed when I saw it in person.  Runs like a kitten too!!!
    • Ritter
      By Ritter
      Greetings All,
      Really nice site, and I am a new member.   As I kick back and eat my lunch,  I could not have imagined that Wheel Horse Tractor owners would have such a cool and well-organized place to ‘meet’ despite being out of production for so long.  My name is Ron and I have a 1979 C-81.   It has a WH pull-behind cart as well as a snow plow with chains, weights, etc..
      The tractor belonged to my grandfather, who purchased it new in 1979 for just over $1,100.00.  Some of my best memories are learning to drive it (barely reaching the pedals) and trying to understand the difference between the clutch and brake.   I believe at one point it had a lawn sweeper, which eventually just dragged and made skid marks across the lawn until it was retired.
      My grandfather drove this tractor year-round for 7 years until he passed away.  In the winter it was plowing and hauling logs to the house, in the spring it aerated,  fall it mulched, summer it mowed.   The C-81 always remained at his house and in my family.
      The most interesting part (or at least interesting to me) is that for the last 39 years, this mower has been in-service without missing one season.  It has never been out of commission.   To this day, we have it picked up for service every year and it is still running on its original 8hp Kohler Engine and cuts just over an acre of lawn.  The only major replacements were pulley bearings for the blade deck and a starter motor.   It is ultra-quiet and never strains while performing its tasks. So, when you look at the picture,  you probably see a beat up old machine, but I can assure you that is a tried-and-true Wheel Horse used year-round for nearly 4 decades and maintained as best we thought possible.  It’s a testament to a reliable and powerful brand.
      That said,  I have decided to lessen the workload on this machine and perhaps get another Wheel Horse as a tribute to my Pop.    The main issue is that the cutting deck on this machine is between 32-34” (I believe) and it takes a long time to cut the lawn.  (although I enjoy the peaceful feeling of doing it, it’s not conducive with my day job).   The secondary issue is that this is a rear-discharge deck.  I’d like to somehow bag the clippings for most of my cuts in order to feed my mulch/compost pile.   I’m open for suggestions as to what model would be best.   I do have some hills (a few steep).
      One final note…
      I’d love to crown this C-81 with a new (or comparable) seat.   My goal is to get one as close to original as possible, with the same bolt patterns.  I can provide photos if needed.  Any help would be appreciated.   Again, glad to be a part of this community, and please bear with me as I get used to navigating this site.
      Thanks for reading.
