IthacaJeff
Replacement Kohler ignition module
IthacaJeff
Hi all:
It has been a while since I've posted here, as I've been over at the Garage Journal the past year getting help on my new garage. Need a place to work on the horses. Now that the garage is mostly done, I've pulled in the first of my projects, my Deutz Allis 1920 (rebadged Simplicity Sunstar). Okay, so not a WH, but the horses are the ones actually running!
The Kohler Magnum M20 lost spark in one cylinder, had to pull the engine to access the ignition module. An OEM Kohler is about $160, aftermarket no-names are $50-70.  A Stens replacement is about $115
Or, which of these three options?
http://www.psep.biz/store/kohler_52_584_02-s_ignition_coil.htm
What are your thoughts? Don't want to pay OEM prices!
IthacaJeff
No responses, my fellow WH'ers?
wallfish
I'd say pick the one you are comfortable with. Probably all come from the same place.
I stopped ordering from Pat's because the last 3 orders got screwed up. The latest showed up a month after the order was placed. It would've never got here if I didn't call and spend a 1/2 hour with one of their geniuses to figure out what happened. I even asked to pay for expedited shipping which they conveniently forgot to do! They never have any problem charging my card right away but as for getting the merchandise out the door, they take their sweet a$$ time! Other orders weren't shipped out for over a week with no back orders. Seems they don't stock much inventory any more and order from their suppliers AFTER a customer places an order so the long wait is for them to receive it before they can ship it. So, expect to receive an order 2 weeks or more after you place your order.
Sorry for the rant but just needed to vent.
  • Similar Content
    • Rick3478
      By Rick3478
      For Sale NOS M12S Short Block, still in the original box.  I bought it pre-emptively when Kohler was phasing out the Magnums.  Thought I would have it on hand if one of mine needed it, or maybe I would find a tractor with a busted rod for cheap.  Neither of those things happened, the darn things just keep running.
      Part number 77 522 35, probably built in late '05, it's the combination replacement kit Kohler made to fit WheelHorse or Gravely, machined to bolt directly into the Gravely transaxle, but also has spacers to mount WheelHorse PTO clutch/brake.  Also has a bunch of gaskets and seals packed with it, probably all you need to install it.
      And it's heavy, so it's not practical for me to ship.  Buyer arrange to pick up near Elida OH, I can lift it about knee high to help load.
      Asking $800 or might consider trade for a good center mount grader blade.
    • mcfarmall
      By mcfarmall
      Tractor features Kohler 16hp cast iron engine, gently used 42" deck, concrete wheel weights, tire chains, new Chinesium carburetor, fuel lines and filter, new air filter, 2 new fwd/rev cams.  A starter,  some new gaskets, and miscellaneous parts.  New drive belt and all the belt idler assemblies.  Engine runs but smokes.  Great restoration candidate or a spare engine for you pullers out there.  Call, text or email for a private showing.   No offers considered unless made in person.  Buyer responsible for transportation.  Many more pictures to send to interested persons.
    • Jeff-C175
    • Jennifer
      By Jennifer
      Husband wants some advice… lol.  So we did an engine swap today on two suburbans because we could not get the one engine to spark all the time to get it running!  The engine ran last year before parking for the winter sleep…. Points were changed out for new the engine was cleaned to make good contact has new spark plug new coil condenser we even switched out the fly wheel today thinking maybe the magnet was weak…. Advice???   It would where are you out yanking on the recoil five or so times and maybe only get the points to fire twice if you’re lucky..  checked the gap and pull again… same thing over and over!  Thanks in advance!
    • johnnymag3
      By johnnymag3
      416-8  clean machine, one owner, M16 Kohler...............no smoke, knocks, etc. Only 771 Hours.
      42" Rear Discharge deck   NO RUST    blades used 1 season
      48" plow very nice condition,
      Wheel Horse weights, on tractor already
      AG Tires on rear,used one season, front tires great condition. Rears are filled with beet juice, done at a Dealer professionally,  ....non toxic, non corrosive.  Traction Galore !!!
      Machine is fully serviced, ready to work. NEEDS nothing....Look below for pictures
      JOHN   845 797 5716 cell
