ericampagna
GT-14 Steering
ericampagna
Recently my steering went out on my GT-14 I can't find in the manual how the steering is suppose to be attached. (I'm also sorry I don't know the correct terms.) I have attached pictures to show what I'm talking about.
N3PUY
Mine was repaired by cutting off the worn end, welding on a bolt and installing a heim joint.
IMG_6008_(800x600).jpg.daadf6fa17ac4a8c7
steamdriven23
 Looks like you might be missing the little wire snap rings that go inside the socket end of the drag link.
  • Similar Content
    • DennisThornton
      By DennisThornton
      One of the most detailed I've seen.
      https://www.homemadetools.net/forum/garden-tractor-loader-videos-85395?utm_source=newsletter&utm_medium=email&utm_campaign=05-21-21&utm_content=05-21-21-181510&fi=181510#post181510
    • BMW1
      By BMW1
      On my D200, when I turn the steering wheel all the way to the left, it has a tight turn radius, but when I turn it all the way to the right, the turn radius is significantly wider.
      The tie rods appear to be adjusted evenly.
      Anyone have a similar problem and what was done to fix it?  The steering does have quite a bit of play, at least 1/4 to 1/2 turn of the wheel.
    • Off Track Horse
      By Off Track Horse
      Okay, so I just know just enough about engines to do basic care & know when something is wrong.  I have what presented as a hydraulic leak on my 416H with fluid spraying everywhere from under the center of the tractor and it is really only significant when the PTO is engaged.  I took the mowing deck off today expecting to find a cracked hose or loose fitting.  Wrong!  Instead I found fluid coming out from the steering shaft on the opposite side of what I am finding is called the "steering fitting lube" piece on the Toro parts website.  So where it shows part #7 going in the fluid is leaking out of the other side.  I'm really at a loss on this one.
    • wheel horse guy
      By wheel horse guy
      Help I just recently porched a D250 to add to my collection and wish to install power steering Hydraulic. I under stand I might be able to find help on this WH forum. Thank you The wheel hoarse guy
    • Bear G
      By Bear G
      I was thinking about putting this brush guard on my ‘69 GT-14. So much for thinking.. I don’t really care for it..
      Original thought was it would look cool & help protect that exposed fuel tank.
      .  Pretty sure I’m going to abort on this project.
      Back to the drawing board..
        Yes, I know, wrong hood decals for ‘69..
      This hood is off a ‘70 I had.
