DanD
Hello Red Square Community!
My father recently rebuilt a 1990 520-H he found at a junk yard and surprised me with it as a birthday present. I've done a lot of searching for guidance on implements/attachments that will fit this particular model but am coming up short. I would love to get a rototiller, snow thrower, and a blade but I have no idea what will work. My model number is 41-20OE01. Will any wheel horse attachment prior to 1990 work with this tractor? I'm new to this so any help would be much appreciated. Thank you for your time!
cdsl810
Most of the 300/400/500 and C series attachments will work with the 520-H.
The tricky part is that in order for attachments that came from the C, 300/400 tractors often require an extra adapter, extension, or unique lever to allow them to fit the 520-H--even though they are identical in all other aspects. It's because the frame of the 500 series is longer than the others. A prime example is the snow blade: The C, 300/400/500 blades are all basically the same... the 520-H requires a frame extension to allow it to attach at the back Attach-a-Matic hitch--AND it has a different angle adjustment lever that has a "zig-zag" bend in it instead of being just straight.
roadapples
Is the frame actually longer or is it because of the swept forward axle? Just curious.
KC9KAS
:WRS:
MalMac
I believe it's because of the forward swept axel add a few inches to accommodate the 60" deck.
cheesegrader
I used a 48" blade on a 520 for two years without the extension bracket.
The back of the blade rubbed the front of the right tire when the blade was angled.
Not bad, but annoying, and it wore the paint off the blade.
The extension gives about 4" extra clearance needed for the forward swept front axle.
Problem is, they are hard to find, and go for about $150 with the extension bracket, lift point brace and offset lever arm.
  • Similar Content
    • Rob R
      By Rob R
      So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
      So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
      I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock.  You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
      Appreciate all your advice as this one has me stumped......
    • neilevans1971
      By neilevans1971
      42in Snowthrower #79362 for sale
      You pick up, as I cannot deliver.
      Lot's of fun to clear a sidewalk in one pass or driveway in just a few.
      I have the manual, belt and attachment parts that go with it but are not pictured. All are in good working order.
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
    • Bill Winn
      By Bill Winn
      For sale. 1981 WH C-175 Kohler twin series 1
      1. Tractor has brand new ag tires all the way around, brand new seat, new points and condenser, new rear blade quick attach bracket, lights have been rewired with LEDs, it has a brand new lift cable and bracket,seat pan is from a 410... it's surface rusted but at least it isn't busted up like the oem plastic one, starts and runs but smokes a bit on startup if it's been sitting for months but she runs smooth and strong.
      2. Tiller is like new. It had been used only about once when I bought it and now it has been used 4 times more. Tines still have much of the factory paint on them.
      3. 42" mower deck works perfectly, 4. snow blade was/ is rough but I repaired it so it is quite functional,
      4. Brand new rear grader blade,
      5. Wheel Horse brand plow,
      6. Wheel Horse brand disc- I added a piece of motorgrader blade for a drag. I also welded a post to the top to hold weights,
      7. Wheel Horse brand cultivator,
      8. Home built furrower. (Makes good rows)
      The original Wheel Horse plow/disc/cultivator originally came as a modular kit and in order to use it the draw bar and clevis hitch had to be swapped back and forth. (big pain) I fabricated draw bars and hitches onto each piece so this is no longer necessary.
      I think this is a fair asking price at $2200 for all.
