Niagara D 11 #1 Posted July 30, 2015 I am currently looking into pricing to get some pump couplers made up. my question is are any of you out there interested in some as well? I am hoping to get a larger order in to reduce the per unit cost and am willing to pass them on for my cost plus shipping. Please let me know. 2 Share this post Link to post Share on other sites
pfrederi 17,040 #2 Posted July 30, 2015 are you talking about the rubber spider or the steel flange with internal splines?? I would be interested in the steel flange Share this post Link to post Share on other sites
Niagara D 11 #3 Posted July 30, 2015 Yes steel flanges. I have a friend looking into some people he knows to see about making them up. Share this post Link to post Share on other sites
wheeledhorseman 573 #4 Posted July 30, 2015 Would also be interested in the steel flange or two as I have two D-200sAndy Share this post Link to post Share on other sites
Niagara D 11 #5 Posted July 30, 2015 I told my friend to have a few "samples" made up and get me a price for 50 of them. I figure there's several folks around here and then the rest that I don't want to hoard can go on ebay. But it would be nice to get an idea of how many people 'round here would like them....and how many! Share this post Link to post Share on other sites
reecie 3 #6 Posted December 7, 2015 (edited) I would take 2 (or 3 if slightly the 3rd is slightly discounted). Please let me know. --Maurice PS I sent you an email with my cell phone number, if you can call to let me know more details. Edited December 9, 2015 by reecie Share this post Link to post Share on other sites
tommyg 152 #7 Posted December 7, 2015 I would be interested in at least having a spare. But ideally, it would be great if someone could design a coupler that didn't rely on the splines (which we all know wear out) and come up with something that could be affixed to the pump shaft more permanently with a more durable (and available) coupling kind of like the one below. Share this post Link to post Share on other sites
ranger 1,588 #8 Posted December 8, 2015 On 07/12/2015 at 5:24 PM, tommyg said: I would be interested in at least having a spare. But ideally, it would be great if someone could design a coupler that didn't rely on the splines (which we all know wear out) and come up with something that could be affixed to the pump shaft more permanently with a more durable (and available) coupling kind of like the one below. Here is an idea to help prevent spline wear, this, we used years ago on parking brake drums which were only held on the shaft by circlips. The hub is split part way through and has an external taper, the cap has an internal taper, when the two are pulled together by the three screws the hub is clamped tightly to the splined shaft, It usually holds it so well that no other fasteners are needed. If you have room to fit something like this, it may be worth a try. Share this post Link to post Share on other sites
bgh5469 17 #9 Posted December 9, 2015 Depending on the price I would be interested in one or two to keep just in case. Share this post Link to post Share on other sites
JackC 616 #10 Posted December 9, 2015 Usually it is the steel half of the coupler that fails and the splines on the pump remain undamaged. There is also a clamp on coupler configuration that could be used (or made) for repair applications if the splines on the pump are also damaged. Share this post Link to post Share on other sites
tommyg 152 #11 Posted December 9, 2015 1 hour ago, JackC said: Usually it is the steel half of the coupler that fails and the splines on the pump remain undamaged. There is also a clamp on coupler configuration that could be used (or made) for repair applications if the splines on the pump are also damaged. I see a similar amount of wear on both, but I would agree that the steel half might wear a bit faster. This design would keep friction and wear to a minimum if movement of the splines was minimized by a couple bolts. Can something like this be designed to adapt directly to the rubber dampener? That would be most ideal. Share this post Link to post Share on other sites
JackC 616 #12 Posted December 10, 2015 Some have drilled through both the steel half of the coupler and the hardened shaft of the pump and used a pin or bolt all the way through. Share this post Link to post Share on other sites
Sarge 3,462 #13 Posted June 28, 2017 @Niagara D - Any news or gains on getting a proper coupler made yet ? I had drilled mine back in the middle of the winter to get it back in service . Over time , it has worn further now to wear down the spline shaft into a taper - so that shaft is junk . Got another good pump with good shaft , will have to either machine the shaft on the new one to accept a keyway or similar work to make it stronger . The D's power and weight is far too much for that little pump shaft - I do have a C series hydro drive pulley that has the machined steel center , plan to cut it out on the lathe and weld it into the original coupler that is totally stripped out now . In my mind , still not a very good fix and it will eventually fail again - I'd rather do this once and be done with it in a much more bulletproof way... Sarge Share this post Link to post Share on other sites
