Theroundhousernr
Cheaper Alternative for 122791 Idler Pulley
Theroundhousernr
 Just picked up a 520HC needing the 112791 flat idler pulley. This pulley is used on all later model Hydro tractors without the belt tension release lever.  Thought no problem, till I saw the price( $66.70 ). :blink:  Called my local dealer and he said there is another comparable pulley (93-1622) but the spacer needs to be swapped from the old pulley. This pulley which is the same size in every aspect but with a smaller spacer was $25.00. These are both toro pulleys and pricing? :confusion-questionmarks:   I guess the longer spacer justifies the $40.00 price difference, silly me.
Anyway, swapping the spacers is very simple. It can be done very easily with a press and tooling. It can also be done just as easily with 1/4" rod, 2 washers, 2 nuts and a socket. My press is at work so I chose to use the second method. The most important thing to do is to support the bearing and not the pulley. Find yourself a deep well impact socket that sits evenly around the inner most spot of the pulley( the lip that contains the outer race of the bearing). Take your rod and run it through the socket and the bearing/ spacer. Tighten your nuts and washers down on either side while making sure everything is lined up and keep on tightening. Once the nut can no longer be reached inside the bearing ( due to the nut being pulled into the bearing with the spacer coming out the other side), unscrew the 1/4" rod. Find another socket smaller than the inner race of the bearing that reaches the spacer down inside inner race. Support the pulley on your deep well socket and wack the smaller socket with a hammer and out pops your spacer.
  To install the longer spacer, swap the deep well socket to the other side of the pulley. Tightening the nuts will now draw the spacer into the pulley. Tighten just enough to seat the new spacer. This is an easy and cheap way to do this and prevent damage to the bearing or the new pulley.
  I have not seen this documented before and searched for awhile till coming up with this. This is simple for anyone and hope it helps save someone some time and money. Glad my local dealer wasnt trying to up sell me and helped me out on this one.:handgestures-thumbupright:
      Kyle
Edited by Theroundhousernr
  • Like 4
daveoman1966
I had offered to send you a perfectly good original pulley 112791 and even posted pics of it....for $37....SHIPPED.   Did you not see that posting....
Theroundhousernr
Yes, after I bought this pulley. Was going to send you a message this morning. $25.00 dollars for the same thing but new works out a little better for me. Thanks for the offer though.
Hodge71
I dont think this is about you Dave. I think he was helping others learn of a cheaper alternative to getting raked over the coals by Toro.. I would have bought a brand new pulley for $25 vs a used one for $37. Just seems to make more sense
Theroundhousernr
To add to the original post. The new pulley is the same size bearing also. A friend asked me if the bearing was smaller and maybe had something to do with the price. It is not smaller and is built the same in every way as seen in the pictures. Perfect original replacement.
     Kyle
daveoman1966
I wasn't offended or anything...just thought MAYBE there was a reason my pics couldn't be viewed...given the recent forum changes, which I like.
shallowwatersailor
Kyle, thanks for taking the time to document the alternative method. I saw "press" and thought: Ugh! I'd buy new/used.
I'm sure that I'll use the method on something.
KC9KAS
Thanks for the write-up on the make-shift press.
We all have had to rig a press or puller out of sockets, black-iron pipe, duct tape, threaded rod and what ever else works!!
I once had to use a 1 7/8" ball as a bearing race driver!
Theroundhousernr
Yea , I am getting tired of my press not being at home. Time to buy another maybe. I have some deck spindle bearings to replace and would much rather use a press for the job.....
Yes and as SOI posted ( Thanks SOI! forgot to mention that ). The pulley can be had for as little as $14.00 from other suppliers but they will usually make up the difference with shipping so its a good idea to order other things you might need to even things out a little. I like to support my local guys if the price is reasonable. Maybe that's why they help me out sometimes to.
Xearl
I had a bad bearing in a pulley on the 523dxi I just bought. To solve the problem I ground off one of the lips that hold the bearing in place. I PRESSED IT OUT USING A bolt some washers and a large socket. Bought a new  bearing for $12 and pressed it ln.the way I took it out. Pressed in the spacer with bolt and washer. When I put it back on the mount used a large washer to hold the bearing in the pulley.
Theroundhousernr
   Thats sounds ok but I am fussy and that would bother me. Another thing that you can do is drill the spot welds and seperate the two halfs. Replace the bearing then either weld the pully back together or some have used bolts already in the past. If you use bolts make sure to use red loctite. You dont want that flying apart on you.
  In my case, I had no choice but to replace the pulley. As you can see in the pictures, the pulley had holes rotted in it. Not good.....
smoakey
The spacer can easily be removed and replaced using 2 sockets and a vice. Use the vice as a press. Support the bearing on one side of the pulley with a socket and push the spacer out with another socket with similar diameter to the spacer on the opposite side of the pulley. Slowly close the vice until the spacer is removed. Reverse the process to insert the new spacer.
Here is an old topic I needed to read.
peter lena
@Theroundhousernr  tractor supply has related pulleys with , larger bearings / and wider rubber side shields , that combo lets you , do a removal , clean out and regrease .they also have related bronze bushings , so uou can make a larger bearing , into a 3/8  " mount bolt size . same issue with the engine drive belt idler pulley , undersize bearing , non specific lubrication , noisy / rough , why not eliminate the problem ? every one of my related bearings has been changed out , no noise or failures , just a reference , pete
PAguy
Came accross this post and had the idler on my 520h go on me. Taking it off realized the previous owner must have just taken the bearing out and replaced it with what I can't tell since the bearing sort of rusted away it seems. Any way was going to try replacing the bearing rather then pay the 75 for a new idler. Problem is could not find a bearing to fit but did find at tractor supply an idler that seems to be similar in size and can take the spacer part # 1185277. Anyone try using a non wheelhorse idler or see an issue I am not?
sjoemie himself
It would seem to me that an idler pulley is one of the least critical pulleys on a machine as long as the size is similar and the groove is not too narrow.
Bearings used should be up to the task ofcourse!
ineedanother
I've used pulleys from t/s and mcmaster-carr without any issues.
PAguy
Thank you! @sjoemie himselfthe bearing seems well made. I just got it on and it runs quiet without issue and the belt does not appear to have issue running through at all. Just got a little nerves using a non wh part but liked the idea of saving a few bucks if I could.
PAguy
That gives me some peace of mind, it said made in USA so figured it could not he to bad of a part.
Appreciate this group! It has helped me keep these two wh going and given the confidence to make repairs, much appreciated.
lynnmor
I use Stens 280-495 pulleys and add a .467" spacer to match the OEM offset.  You may be able to find a spacer at a hardware store that is close enough.  I do see the inflation reduction act has increased the price to over $30.
Edited by lynnmor
  • Similar Content
    • Brockport Bill
      By Brockport Bill
      520 HC Tractor For Sale: please see photos; Just 630 hours on meter. Powerful Onan 20 HP motor. Hydro transmission, Hydro lift. This HC was limited 2 year production, top of the line Wheel Horse commercial model - including swept front axle. Cleaned and serviced, new Carburetor, new plugs, new engine oil, new tranny oil, new battery, new decals, new foot treads, rebuilt hydro lift cylinder, zerk fittings all lubed, tires hold air, headlight rims. Seat adjust feature. Cash pick up as is, Hudson River Valley, Poughkeepsie, NY area. Tractor only, priced at $1,550. Also available as option: Rehabbed 48 inch side discharge mower deck, professionally sandblasted shell plus lift carriage assembly to remove rust and paint; then newly primed and painted. Plus new hardware. Blades cleaned, sharpened and balanced. Mower deck available at $ 440.  Please send p.m. for questions or info?
    • CB520HC
      By CB520HC
      hello all I figured its time to show off the horses that I own and tell a little about my Frankenhorse. My first one was the C-175 auto with original series 1 kt17 bought it for $100 "running" , driving and mowing. Little did I know that it had a broken connecting rod on the front cylinder I found this out due to going over it and checking plugs found the front plug soaked in fuel, and when I removed the piston from the jug the crank had a narly nick in it that I could see. So after crawling all over this forum I found out that my best option was to go with wither a series 2 or swap to the classic k341. Later that week I found a guy not too far away from me selling one in good shape running with starter and carb that came off either a 416-8 or a c-160 and after some custom plates and stab link bushings as vibration pads tractor was operational again and the 42" SD deck that it wears got me hooked instantly on having a horse addiction. I used this tractor to cut 6 acres of land (4 separate properties) and it did it flawlessly could not get that motor to bog at all even in the heaviest grass i could get it into, in the pictures that are attached you'll find the tractor after the swap and right after a bath but other than that i haven't changed anything other than belts and fluids about a month after this project was completed I was looking to upgrade once again to the larger 500 series and i found a 520HC with only 648 hours on the clock it also had the 60" deck that was in fantastic shape stole the tractor for $800 then right before Christmas I found a 56" snow blade chains and blower with custom rear weight bracket all for $500. So to wrap this up I have the fever and I'm hoping to add a few more in the years to come gonna be cruising marketplace this spring. Looking to add to the herd.
    • JNMULL
      By JNMULL
      Good morning, I have been a long time reader, but a first time poster.
      I have a 1988 Wheel Horse 520HC Tractor.  Does not charge, and I have to assume that it is due to the fuse at the front of the engine being blown.  However if I replace the fuse that is located at the front of the engine, the wire at the voltage regulator will get hot, start to smoke as it melts the wires insulation.
      I have not started testing anything yet, as I just have stumbled upon this issue and was wondering if anyone else has had the same style of problem and what kind of repair did you have to perform.
      Thanks.
    • cafoose
      By cafoose
      My 1988 520-HC (I did get lots of snow that's an old picture) starts up great at first but after running it awhile it will not start back up. It cranks over fine it just does not start. I sprayed starting fluid in the carburetor and that does not help. When I let it sit for a few hours and come back to it, it starts up fine. Today I was cleaning up some snow and it worked great while it was running. I ran it out of gas earlier today   and when I filled it up it did not start until a few hours later.  I put it back in the shed when I was finished with it and when I shut it off I tried starting it back up in a couple minutes and it did not even attempt to fire up. Does anyone have any ideas what might be wrong with it?
