BOWTIE
PROBLEM WITH FUEL PUMP 1995 314
BOWTIE
I HAVE A PROBLEM WITH MY FRIENDS 1995 314-8 (M14 KOHLER) WHEEL HORSE. VERY LOW FUEL PRESSURE WHEN CRANKING ENGINE OVER WITH THE STARTER. JUST A TRICKLE OUT THE OUTLET NOZZLE. I REMOVE THE FUEL PUMP AND PUMP BY HAND AND SQUIRTS 2 FOOT OR SO. THIS IS A NEW PUMP TODAY. THE OLD PUMP DID THE SAME THING. DO THE FUEL PUMP CAM WEAR OUT ON THECAMSHAFT? I'M THINKING A CHEAP BASIC ELECTRIC PUMP.
BOWTIE IN CENTRAL OHIO
squonk
Do it!
Forest Road
X2!
I have an electric fuel pump on the shelf. Just havent had time to install it.
skrusins
I have a 1995 314H and install it under the seat with no problems. They push better than suck.
BOWTIE
THE PROBLEM WAS THE OLD FUEL PUMP WAS BAD, THEN THE NEW TAIWAN FUEL PUMP WAS BAD. IT HAD 5/16" PLAY IN THE ARM BEFORE IT WOULD PUMP. THE CAMSHAFT LUBE FOR THE PUMP ONLY AS 5/16" LIFT. THAT WHY IT JUST HAD A TRICKLE OF FUEL WHEN CRANKING THE ENGINE OVER. I CONFIRMED THIS BY TRYING IT ON ANOTHER ENGINE WITH THE SAME RESULTS. SENT THE NEW PUMP BACK TO SUPPLIER FOR A REFUND. PUT A USED ONE ON IT.
Marv
I like electric. I have three tractors with them. Will put them on the others as I get to it.
Marvin
