saminmn
gt14 tow valve
saminmn
I have a gt14 we pulled out of the woods this summer but the tow valve will not move .Which way should the lever  turn? clock or counter
JustinW.73
Should be counter but i could be wrong. Just do it slowly tho. You shouldn't hurt anything.
KC9KAS
It will actually turn completely around.
It needs to be turned 90* to go from "Go to Tow" or "Tow to Go".
Right now I can't remember if it needs to be parallel or perpendictular with the frame for towing.
Shynon
180 parallel with frame
daveoman1966
If the tow valve is stuck,  use a crescent wrench to back off (out) the top nut several turns.  The whole valve comes out, then cleaned it up refit it.
post-1200-0-73286200-1422943354_thumb.jp
post-1200-0-29708500-1422943360_thumb.jp
post-1200-0-78438300-1422943451_thumb.jp
meadowfield
btw,the later ones were different, they were 1/2 turn on the piston-piston sundstrands
