dclarke
RJ58 rebuild
squonk
Pardon my left-brain, but what's the difference in the wheels?  :confusion-scratchheadblue:  :confusion-scratchheadblue:  :confusion-scratchheadblue:  :confusion-scratchheadblue:
dclarke
Mike, see the difference in the 4 open spaces between the center part of the rim and the outer part of the rim. The rim on the left has more space in that area than the rim on the right.
squonk
So by Lanes' picture it takes the larger opening? Now I have to go look at my wheels!  :eusa-think:  :eusa-think:
Edited by squonk
dclarke
I believe it does.
Racinbob
Mike, ever play this game? :ychain:
post-8408-0-31679900-1406072269_thumb.jp
stevasaurus
Mike, I have the same left brain as you...scary.:)  I was looking and looking at those pictures and with Lane's mounted and looking at that from the back side...I could not pin down the difference.  I will trust Denny here.  :)
stevasaurus
I got it Bob...the bow, the left arm is up and bent in the other and the shirt collar is different.  Z WALA...must be the practice from looking at those rims for an hour earlier.
BOOM SHA-KA-LA-KA... :)
Don't ask me to pass this test tomorrow...I just seem to be sharp tonight.  :)
Edited by stevasaurus
squonk
Steve, I'm Craig 's surrogate older brother and you 're my surrogate older brother!
Hello Kitty was way easier than the rims! Time to dust off my micrometers
Racinbob
Atta boy Steve! But doesn't it make you wonder just what I do in my spare time?
squonk
Tiddilly-Winks is a great game but I prefer left-handed Parchese
Racinbob
Denny, one of the things that's been on my mind while doing my Suburban is those pesky gas tank straps fastened to the hood. Mine has issues. Well, after seeing your set up I've been pondering and measuring. OK, I'll get right to the point. I'm stealing your idea :eusa-whistle: . I'll try to avoid any patent infringement by making some minor modifications because my hood stand is different. That's a much better setup than the straps. Looking good! :handgestures-thumbupright:
Edited by Racinbob
dclarke
Bob, I stole... eh I mean I got the idea from another member's RJ project here on the forum. Help yourself!   :thumbs:
Racinbob
Thanks Denny. It will be our secret. Nobody else has seen these posts. Oh............I'm also 'borrowing' your filler neck extension idea. :hide:
Racinbob
How ya coming on this Denny? Question for you. I see you test fit the hood over the gas tank stand but the steering column wasn't installed. Have you tried it with the column in place? I'm curious if there could be a problem removing/installing the hood because it has to move backwards as it's lifted. Are you able to tilt, twist or whatever it takes to clear the tank and stand? I want to build a tank stand for my Suburban and this came to mind. I'm going to build a mock up but any input would be appreciated so I minimize the potential for dings in the paint. The hood is unfinished but the frame, hood stand, steering column, etc. is all painted up.
dclarke
Good question, Bob. I haven't tried to put the hood on with the steering shaft in yet. I'm still gathering parts and really haven't made much progress on it, one of these days I need to dig it out and get busy on it.  Worst case I might have to put the hood on before I mount the engine.
Racinbob
I was thinking more about clearing the frame mounted gas tank with the shaft installed. I just answered my own question this morning. I did a test fit on my hood for the first time I was mainly checking the hood stand ears that I had to work on. In the process I saw that there's plenty of clearance to unbolt the hood and lift the front up to easily clear the tank. The 1" shaft hole in the hood gives plenty of slop to do that.
dclarke
That's good to know, Bob. My hood is at the body shop right now and I'm not sure when I'll get it back.
dclarke
I dug this project out of my "I'll get to it some day" pile and am gonna see if I remember how it goes back together. The bare frame had a little rust on it from sitting so I cleaned it up, welded a couple of cracks on the fenders and have all the tires mounted and the front rims painted.
  • Excellent 2
dclarke
A while back Jake Kuhn rebuilt my engine and tranny, they just need cleaned up a little and they're ready for paint. Thanks Jake!
  • Excellent 3
Lee1977
How about making the cap fit flush and weld a horse head on top.
dclarke
I'm wanting to repair the plastic on this steering wheel and was wondering what would be best to fill all these very small imperfections and the cracks? I'm thinking of trying PC7 epoxy, anybody have any luck repairing one of these?
AMC RULES
:text-yeahthat: The perfect choice Denny.
dclarke
Thanks Craig!
Pullstart
I used it filling the hood seam after welding on Putt Putt.  It is much harder than bondo, but still sandable and workable.  It seems to have a short malleable life before hardening.
AMC RULES
Tip...have a cup of water on standby,  use a gloved, wetted finger to work that PC-7 into the perfect shape before it sets up.
Greatly lessens the amount of time you'll spend sanding it later.
  • Similar Content
    • wh315-8
      By wh315-8
      The RJ58 was the big hit for spectators this year at my local festivals here in Carroll County OH.
      the children loved getting their pictures sitting on it, then they discovered the bicycle horn under the steering wheel. It’s always a joy even in parades. Just love showing off part of my collection every year and hearing all the stories from those that had WH in their lives at one time. Can hardly wait to get to retirement so I can get some of my other models back to their glory in working order and be able to attend other shows/festivals throughout the year. My fellow tractor enthusiasts always know when a spectacular starts asking about WH, they point in my direction. I study up on the history of the different models and always intrigue those that didn’t know much about how WH came to be. This website is one place that has helped me learn so much about the WH history and I thank you for sharing your knowledge that I am able to pass on to keep WH alive and well.
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • Vaughan32850
      By Vaughan32850
      Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
      Many thanks
    • wh315-8
      By wh315-8
      My show tractors for October Festivals.
      RJ59, 1045, 657 w/sickle bar, 10HP and D200. Just love the attention and hearing the stories of grandpa or growing up had one. Always can see the joy these Horses bring to the spectators. Than telling them the WH history story along with Speedex story always intrigues them.
      Than of course there is always someone that needs to get one out of the way.
      Last year it was the 1045 and the PO was so excited to learn I got her running and been mowing my grass all summer. Of course I had to let him drive her around.
      This year it’s a 702 I think I getting this week.
      So many were engrossed by the Sickle Bar never knowing such was available on garden tractors.
    • HorsePower58
      By HorsePower58
