dclarke
RJ58 rebuild
dclarke
I've started the rebuild of my RJ58 and the CBR32 sickle bar that fits it. I've been collecting parts for it for a few years so I thought I'd get started on it. I didn't take many pics of the tear down, mostly just close ups for reference. I've got the engine tore down and cleaned up, ready to go to the machine shop. This one will get bored .010 and the crank will be turned .010. I got the parts for the engine today so I'll be able to take it to the shop this week.
While it's at the machine shop I'm going to have them bore and tap the exhaust port to 3/4" N.P.T.
Any opinions on which rim is correct for the RJ would be appreciated
I picked up new blades for the sickle at the show in Le Sueur last year, I finally got those changed. Now I need to get it and a bunch of small parts sent to be plated.
  • Like 8
Lane Ranger
Looking good Denny!
AMC RULES
Looked pretty clean to start with Denny...   :)
looking forward to the progress reports, and your finished work of :wh: art.
dclarke
It is pretty clean, Craig but there's several things that need attention. I really like these little RJs and I've been wanting to put a fresh coat of paint on this one since I got it. Terry's already got me fixed up with new decals to finish it off with.
dclarke
I'm going to use stainless hardware when I put this back together and found a young man here in town that was able to make this shoulder bolt for the idler pulley on my sickle bar  from a piece of stainless I had laying around. He tinkers in his garage when he's not working, amazing in a town of less than 3000 that someone can do stuff like this. I think it'll add a nice touch to my project.
Ken B
Can't wait to see it when its done, I know it'll look nice!
rmaynard
Always look forward to this time of the year when rebuilds seem to take front and center.
I am anxious to follow this one Denny. You always do a great job.
Lane Ranger
Denny:  I saw something the other night on Rick's Restorations on the HBO channel that to make your spray paint or brush applied paint look flat or flatter on a restore you use Corn Starch in the paint.    I tried out a little on some rough spots on one of the tractors in regal red and it worked.   I only applied with a brush but a small amount of paint and maybe a tablespoon of corn starch.
A google search will turn up quite a bit of information and it applies to all paints,  may go on somewhat shiney but dry flat, and one uses says 8 to 1 paint to corn starch as the mix.
Edited by Lane Ranger
AMC RULES
Lays down flat...   :eusa-think:
as in...no sheen, or the paint lays down smooth Lane?
Lane Ranger
I used it on a chip and guessed a little on the mix ration  (using a brush) and it goes on like normal but dries with less sheen.
dclarke
I've never heard of that Lane. Good to know. :thumbs:
Terry M
I can't wait to see this one done Denny! I think Everyone would agree that your restores are some of the Best!! :handgestures-thumbupright:
dclarke
The hood was cracked from the weight of the gas tank so I decided to mount the tank to the frame instead of hanging it from the hood. It still needs a little tweaking but looks like it'll work. I've left a small air gap between the tank frame and the hood so it won't rub. Next I need to extend the filler neck on the tank to get it back to the correct height.
Shynon
Looking good Denny, keep the pics coming.
                     Tom
AMC RULES
Actually, I'm really diggin' the look of the lowered filler cap Denny.    :icecream:
dclarke
Workin on my gas tank today, I needed to extend the filler neck a half inch or so. I unsoldered the neck, then cleaned the tank and removed all the J B Weld on the bottom of it. This tank hasn't leaked while I've had it but it must have at one time. With my little propane torch I ran some solder into the seam around the tank to fix any leak that was there. Next I needed a 1-5/8" O.D. pipe to extend the neck, the only thing I could find that diameter was a 1-1/2" copper street elbo at Menards. I cut about an inch off of it and soldered the neck to it then soldered that into the tank.
Jake Kuhn
Very nice Denny!
thirdjoker
thats a clean repair. good job.
AMC RULES
Wha...couldn't get your fingers on it, dropped down in the hood?
The repair does look really good Denny.   :handgestures-thumbsup:
dclarke
Craig, I just wanted it to look the way it did before and I was thinking that I'd scratch the paint on the hood over time just removing and installing the cap.... like that's not going to happen anyway.
Terry M
Nice job On the gas Tank Denny!! :handgestures-thumbupright: .
shorts
Nice work on the tank
dclarke
Anybody know which one of these rims is correct for the 58 RJ?
Lane Ranger
Denny:  Her is a photo of a rear wheel on my 1958 RJ I bought in Oklahoma.  I am sure the wheels on this one are original to the tractor.
dclarke
Tthanks, Lane.
  • Similar Content
    • wh315-8
      By wh315-8
      The RJ58 was the big hit for spectators this year at my local festivals here in Carroll County OH.
      the children loved getting their pictures sitting on it, then they discovered the bicycle horn under the steering wheel. It’s always a joy even in parades. Just love showing off part of my collection every year and hearing all the stories from those that had WH in their lives at one time. Can hardly wait to get to retirement so I can get some of my other models back to their glory in working order and be able to attend other shows/festivals throughout the year. My fellow tractor enthusiasts always know when a spectacular starts asking about WH, they point in my direction. I study up on the history of the different models and always intrigue those that didn’t know much about how WH came to be. This website is one place that has helped me learn so much about the WH history and I thank you for sharing your knowledge that I am able to pass on to keep WH alive and well.
    • CasualObserver
      By CasualObserver
      Operator manual
      Illustrated parts list
      6 pages 3.73MB
      Illustrated parts list #A-7136
      Includes PSB #023 #052 #058 #060 #080
      10 pages 938.48KB
      Engines used according to Toro
      Clinton B1290-1107
      Kohler K91-31307A
      Kohler K91-31388A
      Electric start kit
      Electric starter kit model EC-35 for Clinton engine - Listed for 1958 and 1959
      Electric starter kit model EK-35 for Kohler engine - Listed for 1958 and 1959
      6-12 tire chains model TC-12 - Listed for 1958 and 1959
      Seat cushion Foam rubber with imitation leather cover model FC-24 - Listed for 1958 and 1959
      Transmission drive belt 1567 - (4L x 29" or 1/2" x 29")
      Details & Attachments
      2 pages 107.33KB
      1958 model RJ-58
      1958 serial numbers that have shown up for the RJ-58
      Early models used Kohler K90T-27107D equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      00005
      00251
      01099 - No casting date on trans. Leather gearshift boot, large, round rear wheel hubs, "slab" hitch, replacement engine
      01188 - Has round rear wheel hubs
      01516
      01768
      01789 - No casting date on trans. Leather gearshift boot, 3-ear triangular rear wheel hubs, "slab" hitch, Clinton engine with Schnacke recoil
      01797
      01871
      02525
      03177
      03501 - Located in UK
      03796 - Kohler K90T-27107D with serial 364044 equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      04883
      04885
      05000
      05619
      05714
      05798
      06528 - May be 16528
      06749
      06771
      07633
      07649 - Transmission J12-8 October 12, 1958
      07725
      08440
      08612
      09284
      09337 - Hard to read
      10163
      11432
      11628 - # 3521 spline gear with 10 splines changed to 11 splines in 5003 and 5010 transmissions at serial # 11628 PSB #023
      11916
      12221 - B3-9 trans casting date - Kohler K91 engine with Schnacke recoil
      12291
      14473
      14713
      16097
      16528 - May be 06528
      166x6
      16868 - F4-9 trans casting date - Kohler K91 engine with Fairbanks recoil, solid pan seat without holes
      18348
      June 2023
      18500 and lower
      Late 1958 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      2 pages 106.94KB
      1959 model RJ-59
      1959 serial numbers that have shown up for the RJ-59
      Early 1959 units came with a Kohler K-91T-31307A equipped with a Schnacke recoil unit with a backup rope starter contained under the recoil assembly and an oil bath air filter.
      18501 and up - Possible 1100 units built
      20078 - Located in UK
      203xx
      21033
      292xx
      21900 - 1960 Suburban 400 began production at serial #21900 somewhere around Aug-Oct 1959.
      Late model RJ-59 tractors with a Kohler would have a K-91T-31388A with the Fairbanks recoil starter and paper air filter element. The 31388A was also used on the 1960 Suburban 400.
      K91T-31388A Serial 425251 found on RJ-59
    • Vaughan32850
      By Vaughan32850
      Has anyone got a WT-30 tiller they can send pictures if pleas? It’s the one fitted with a K91 engine for RJ models.
      Many thanks
    • wh315-8
      By wh315-8
      My show tractors for October Festivals.
      RJ59, 1045, 657 w/sickle bar, 10HP and D200. Just love the attention and hearing the stories of grandpa or growing up had one. Always can see the joy these Horses bring to the spectators. Than telling them the WH history story along with Speedex story always intrigues them.
      Than of course there is always someone that needs to get one out of the way.
      Last year it was the 1045 and the PO was so excited to learn I got her running and been mowing my grass all summer. Of course I had to let him drive her around.
      This year it’s a 702 I think I getting this week.
      So many were engrossed by the Sickle Bar never knowing such was available on garden tractors.
    • HorsePower58
      By HorsePower58
