C-160 Auto
A good tach for a Kohler K341?
C-160 Auto
I've had a governor issue for quite a while, and I fixed that today. Now I want to be sure my wide open RPMs are set right.  I want a good & accurate tach for my K341.  I would prefer something permanently mounted, but I will be happy with something portable. I've read about the Sentec & Tinytach, but I would like something that lasts longer than 4-5 years before the battery dies and it can't be replaced. What are you guys using on the K models?
Jim_M
Your best bet is to use a non contact hand held tach. Just check it every so often, then put the tach back in the garage, it will last forever.
Martin
if you want something permanently mounted, you could use a 520 tach and mount it somewhere.........
heres what i did with one of my tractors.....
WH nut
This is what I use
Google this
TREYSIT Sirometer
C-160 Auto
Thanks for the ideas. I ordered a Vibratach (sirometer) and it should be here this week.
