Followers
0
753 headlights
By
zanepetty, in Restorations, Modifications, & Customizations
Similar Content
By Donavon
Need ideas to convert my 1054 A Frame plow into a snow blower
Any idea's?
By Wheel Horse 3D
Welcome, and thanks for visiting our vendor area.
We got our start in 3D printing for customers right here on Red Square!
If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our Etsy store and reach out to us through there.
Greystone 3D on Etsy
By Wheel Horse 3D
Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here Custom Wheel Horse hood ornaments..9 different styles
By Burnerman
I’m building a lowered 300 series wheelhorse. So far it’s a combination of 3 scrap tractors.
the frame, trans and tins are from a GT2500 anniversary special given to me by a neighbor with a trashed Briggs. The Kohler M12 is from a junkyard 312 that was roached. The parts tractor I’m using for the build was another older 312. I’ve got the k301 in the garage. The trans was toast. Both axles wallowed out keyways and 1 axle actually broken.
Anyway! I needed a project and a toy to putt around the neighborhood. I couldn’t find any other posts on how to do the whole thing. I’m trying to keep it cheap using stuff I have on hand and looking as “stock but cooler” as possible. So here we go.
I’ll update this as I go along.
By BrianKoch
Hello gentleman,
Problem: will not crank on its own, will crank with jump box—but still not fire
Recent things I did prior to this issue: cleaned fuel filter, replaced battery cables, replaced cable from ignition to starter
I have my test light out and am probing around.
There is no power at ignition/magneto wire or the ignition/starter wire
There is power everywhere else
