zanepetty
detergent or non detergent oil?
zanepetty
I put 30 wt castrol in my k161. The botle says HD on it. Do you guys run regular oil or non detergent? Thanks in Advance,
Zane
gregg'shorses
Engines without filters best to use non-detergent, newer engines with filters detergent oil. But more important is an oil change, than running oil black as tar. After all I like to say " Oil is worth    $ 3- 4.00 in the bottle but $ 300.- 400 in the engine."
Edited by gregg'shorses
zanepetty
Thank you Greg.
SousaKerry
Most guys here have their favorites and the debates are endless but all will agree is that modern oil intended for cars is terrible on small engines thanks to the EPA and their ever increasing desire to rid the world of our outdated gas guzzling pollution machines.
Modern Automotive oils do not have the additives needed by our older flat tappet engines to lubricate properly, namely Zink.  Myself I stick to the heavy duty diesel oils such as Shell Rotella T and T1 that still have not yet been affected by the evil EPA.
zanepetty
That's good to hear!!! My papaw always uses shell rotella in everything as well. Would you recommend that over non detergent 30 wt? Should I change after I've run the regular detergent oil for a few days?
SousaKerry
I'd think you will be fine until your next oil change in the fall.
rydogg
You are looking for an oil with a higher ZDDP (zinc dialyldithiophosphatewhich)  zinc additive that prevents wear, the epa has taken a lot of it away from the common motor oils but diesel engine oil still has it or you can use whatever oil you prefer and get a small bottle of the zinc additive but do your research and mix correctly since too much can cause more harm than good.  The best you can do for your engine is to run the correct weight and change it before it gets dirty.  Personally I use Rotella 15w40 and a small amount of Klotz Benol in my fuel for extra valve lubrication,  the lawn equipment I sell gets whatever the manufacturer suggests.
Weather my methods are right or wrong it is what I prefer and I have done my research to make sure I am not harming my engines, everyone has their own idea on what is the best for these old engines I have never had much concern for the detergent or non detergent I prefer detergent oil since non detergent allows the dirt or contaminants to collect within the engine and with the violent thrashing of the oil in a splash system some of the contaminants are getting picked up from the sludge anyways.  Detergent oils keep the contaminants suspended since they are filtered but in our small engines they are usually not filtered which makes it very important to do frequent oil changes to remove the contaminates that stay suspended in the oil.
zanepetty
Thanks very much. I'm interested in what everyone has said. I just want to do right with my oil.
rydogg
Clean oil is the most important....my brother and I spent a few years racing go karts on an oval dirt track we would turn a 5hp briggs engine into a modified race engine and run 7000 to 9000 rpms out of a motor that was designed to turn at 3600 rpms, we changed oil after every race due to the dusty conditions on the track and we learned a lot about using the correct oil.
zanepetty
OK. I just heard that all the contaminants in the old motor could break free if HD oil was used. I just don't know what was in it before I got it. Maybe rotella t 30 wt. Is my best bet
zanepetty
Thanks so much for the help guys
zanepetty
One more thing..what about zinc additives??
Hodge71
They're good stuff. But again, I would not panic and lose sleep at night pondering "OMG my oil doesn't have enough zinc in it....whats happening to my poor engine because of this....oh the agony".....  :confusion-helpsos:  :scratchead:  :angry-banghead:  :scared-eek: The only thing youre going to do to these engines to kill them is A). Run water instead of oil, or B). run no oil in them. Other than that, keep the fuel clean hi test with some Seafoam in it, a good fuel filter and enjoy them for what they are.... It it was a Tecumseh I would say rub its belly, let it sleep in the house, dont get it wet, put a blanket on her when she sleep and then maybe it'll run for you when you need it to... :handgestures-fingerscrossed:  :hilarious:
Edited by hodge71
  • Like 5
Jeff-C175
All the classic car guys I know have been using the Rislone ZDDP additive for years...
http://www.barsproducts.com/catalog/view/245-3x-concentrated-engine-oil-supplement-with-zinc-treatment-4405
http://www.amazon.com/Rislone-4405-Yellow-Supplement-Concentrate/dp/B0075559UY/ref=sr_1_1?s=automotive&ie=UTF8&qid=1376698277&sr=1-1&keywords=rislone+4405
My local Advance stocks it, along with the Rotella 30W.
Edited by Jeffpicks
RMCIII
Just my :twocents-02cents: ... Pick a oil you feel is right for the application. Flush the engine out with diesel fuel. < YES< DIESLE FUEL. Dump 1/4 pint of diesel fuel into the oil chamber. Start engine and let idle for no more than 3 minutes. Drain immediately. Fill up with a low grade oil. Start engine again and let idle for 5 minutes. Drain again. Now fill with the oil you feel you want to stay with. Unless the engine has been stressed, to the max, you will be able to enjoy your GT for years to come. Oh-BTW it may smoke at start up from time to time, but will cease, unless the engine smoked before you engage in the steps above. I've had many disputes over oils. I run Royal Purple and Amsoil products. Nothing else. But my neighbor, who was a Ford certified mechanic, runs Castrol. Both of us share insights. He's dumbfounded at the lack of carbon build up around the muffler and how many hrs. I get on a tank of gas. I'm equally impressed with the overall engine decibels his produces when at full operating rpm. Both are Koehler 18's. Go figure, what are you looking to achieve? Pick an oil that you have had success with, in the past, and run with it. Everyone will give you their A$%, wait opinion. Isn't there a saying like that. Opinions are like A^&%$)(&, everyone has one...... Before everyone jumps down my throat, I am just saying, everyone likes to showcase what works for them. Each application is different. What works for one, may not work, for another. I am not saying Royal Purple and Amsoil will work for everyone. I am saying that is what I have selected to use in all my engines. It works for me. I also run hi-test fuel with each oil change to clean out the cylinder chamber. 1 tank of leaded 110 octane race fuel. I would guess that, aside from a modified engine, not many would do this. I do. With confidence because I know what my engine can take and more important, what it takes to keep it performing at it's best/. BTW, I would not try the racing fuel, unless you are the original owner or know the maintenance schedule of the previous owner. < Serious about that last statement.
zanepetty
Thanks so much guys. I'm thankful I have you all on here to answer my sometimes stupid questions. Its EXTREMELY handy. I have selected my oil and I'm sticking with it:)
Fordiesel69
Here is what to do.  Use a SAE 30w, or a 15w-40 diesel oil and rock on.
No flush, no cleaning, no scrubbing, no nothing.  Change every 15-25 hrs and not an hour longer.
Old kohlers burn oil.  And they die from people letting them burn oil and not checking / adding makeup oil.
I recently had a kohler with a worn camshaft.  It was already bored over to .010, and who knows how many times the oil wasn;t changed, or how many times it was run low.  The crank was shot to the point it could not be turned another .010.
zanepetty
Wow that's awful. I don't want that to happen to mine! Thank you.
smoreau
The main thing you need to remember is these small engines have a lot of similar parts of a car engine, BUT they are not the same, No bearings on the rods, rods are aluminum, crank rides on roller bearings, no oil pump, governed to no more then 3600 rpms. and much weaker springs for the valves. Non detergent was the norm years ago, but not needed with oil technology these days for these small engines. Non detergent oil let the junk in the oil settle to the bottom of the pan. over time that can build up and unless you pull the pan you will NOT get it all out on a oil change. I have seen this first hand. Detergent oil suspends the dirt in the oil and the junk all comes out during a oil change.   as for the Zink thing, there is not enough pressure on the valves and springs to need Zink for its pressure lubing capability. Just use a good quality oil and change often!! I use Rotela strait 30hd oil and have been very happy with it. I work my tractors VERY hard and abused some of them way more then I should have! but they all run great and the oil is changed once a year or 15 hours of run time. Oil is cheep!! rebuilding a engine is not!!
rick
Ummm, I seem to have read in an owner's manual or two that the manufacturer calls for detergent oil......it's all I have ever used, and have had no problems.
Briggs engines get 10W-30 synthetic, Kohlers get 30 wt.
zanepetty
I went with Kohler oil. 30 wt
Audioshot
Rotella T 15w40 for the last two years with a cap of MMO in the fuel in my 310-8.  I change it every 10 - 15 hours and the M10 motor doesn't burn a drop with 875hrs on it.  so far, so good.
546cowboy
:deadhorse: :deadhorse: :deadhorse: :deadhorse:
zanepetty
I realize now there error of my ways. I'm sorry for reposting this highly controversial topic. Haha. I made my decision and I'm sticking to it:)
Edited by zanepetty
  • Similar Content
    • Tinman1962
      By Tinman1962
      Recently got hold of a 656 it's has a "newer" 61/2 Briggs on it I don't believe that's right any ideas about that
    • Little Red Horse
      By Little Red Horse
      Hey all. I have a Electro 12 with a factory belly blade. It runs* and drives. I had used it to grade my driveway the last 6 yrs. Having moved I'm looking at my options on storing it or selling it. Frankly I have no idea what it is worth. I watched "ISaveTractors" video on 5 things to do with a new to you wheel horse/12hp kohler. (When i got it 6yrs ago) And went thru and did the adjustments and replaced the parts mentioned. It has been a good strong tractor for me until around July of this year. (2023)
      *Around July it started dying after running 20-30min. I replaced the carb (Chinese Amazon purchase) with one from isavetractors web site. That seemed to help it idle smoother(the old carbs jets wouldnt adjust), but it still dies at around 20-30min.
      So I've got 2 questions.
      1. What is it worth? (As-Is) and
      2. What do I need to do to fix it?
      Thanks yall!
    • 850ford
      By 850ford
      I am looking for a replacement Kohler for a 1980 c165,it is cradle mounted.
      Will a standard mount Kohler work, if I remove the cradle?
       I am located in Massachusetts
        Thanks
    • BrianStasC-101
      By BrianStasC-101
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
