wheeledhorseman
Tecumseh flywheel removal A-800 Ranger
wheeledhorseman
A bit of help / advice appreciated here guys.....
Picked up another project at the weekend - a 1974 A-800 Ranger with Tecumseh VM80-150056A engine. PO used it for 15 years then one day it wouldn't start. I've been through the easy stuff, compression is good, tried new plug, cleaned carb (obvious that PO had been there before me), disconnected the engine kill lead with no success. The issue seems to be with the ignition - there's a really good spark there (sometimes) and the engine will fire up briefly then die.
So, I need to remove the flywheel to get at the points, condenser etc. The nut came off easily and there's no sign of any corrosion to speak of but using a home made puller acting on the outer edge of the flywheel and giving but a few sharp taps with a hammer won't break the flywheel from the shaft. It's on a taper I guess? It's been soaked in penetrating fluid but it's not likely to achieve a lot with a taper fit. So any hints or tips here guys? With so much diecast about I'm trying to avoid being too brutal.
I'm thinking about getting a genuine Tecumseh puller - are they any good? There's a twist though....
Yes the flywheel has the three holes to take one but the holes have never been threaded. I've looked closely and it's not a case that the threads have been stripped out, they were never cut. Any one found the same? Do you have to cut your own threads before using the puller - seems strange.
Andy
puddlejumper
I have always used a factory 3 fingered puller on the outside, I would make sure your homemade one is pulling evenly. I have broke one but I was half pissed and rough handed when I did it. I think good penetrating oil and a little patience,patience,patience will pay off.
TT
Having to tap the holes isn't unusual.
I made a puller from a 1/4" thick steel "disc" with three holes drilled to match the holes in the flywheel.
Three appropriate-length bolts are inserted through the disc into the flywheel holes, they are drawn tight, and the center of the disc gets a hit with a hammer.
SousaKerry
Put the nut on a few turns so it has good engagement but not so far as to be flush with the end of the shaft.  Then insert a chisel, big screwdriver, prybar or whaterver else you have handy between the flywheel and the block, being careful not to hit any of the components mounted behind the flywheel.  THe prybar or whatever you use should be thick enough and tapered so that you can wedge it in between the block and flywheel to provide constant pressure.  Then take a brass hammer or similar heavy soft metallic object and smack the flywheel nut from the end.  The vibration will usually pop the flywheel right off.
Tecumseh actually sells a special nut to do this with but it's just a piece of hexstock drilled and taped the correct size.
Just do not strike the end of the crank shaft or you will mushroom it out and the nut will no longer fit.
KATO
YEA THAT !!  Do it all the time ...works great ....just be careful !!
wheeledhorseman
Thanks for the responses guys which have helped me get my head round it. :)
I've yet to be beaten by a flywheel even on a two cycle Tecumseh but somehow this 4 cycle Techy looked kind of flimsy compared with a cast iron blocks I'm more used to and there's not much to pry against.
Interestingly the Techy manual shows the pry and hit method using the special nut so I'll fab one of these I think in the first instance if that doesn't do it then I'll move onto making up the special puller.
Andy
wheeledhorseman
The flywheel came off today!
What I really needed was a second pair of hands for this task, so with my son's help..........
We used two levers - finding the best position where you could get something reasonable to pry on isn't easy on the vertical shaft motor but manged to find a couple of places that were diagonally opposite  under the flywheel.
So with my son lifting on the levers and just the standard nut in place I used a 2 pound hammer to strike the nut firmly and square on.
I wasn't using a full on strike, kind of medium I'd say, but the weight and momentum of using a heavy hammer seemed to work. It took  three or four strikes then popped off. No damage to anything.
The reason for the intermittent spark was that the contact breaker points weren't opening and closing freely. Once the shaft that the moving contact pivots on had been cleaned and lubed, all was good again. I was hoping for a simple fault like this rather than it being the coil. Hardly surprising I suppose, the tractor had done nearly 40 years of cutting grass with two POs and I don't expect the flywheel was ever removed to clean.adjust and lube the contact assembly.
Thanks for the words of encouragement guys.
  • Similar Content
    • Tenday
      By Tenday
      Experts - help please. I’m new to Wheel Horse Tractor life!
      So - I’ve pulled out an inherited tractor and have decided to resurrect her. Unfortunately, no spark :/
      I’m looking for help on diagnosing no spark.
      model - 417-8
      engine - Kohler KT17
      Done thus far:  (aware that some have no implication on spark.)
      - new ignition switch
      - new battery
      - new starter
      - new ignition coil and wires w/ plugs
      - new condenser
      - new points
      - new starter solenoid
      - bypassed all switches except oil and seat.
      notes:
      idiot lights removed.
      All fuses tested with Ohms as well as visual inspection  ..
      coil tested w/ ohms as well
      all switches bypassed except:
      -oil switch  ( don’t think it has any implications other than a visual indication for idiot lights. )
      -seat switch
      ran a pos from batt direct to pos of coil - nothing; no spark.
      Electric is as follows:
      - Starter switch wired to solenoid
      - - solenoid to starter
      - - solenoid to batt
      - one wire from starter switch goes to engine ( I think this is for batt charge / flywheel)
      - I have two yellow wires, which are married up, that go to engine which have constant power; They power coil.  Comes from switch and seat.
      Help - what the heck am I missing ?
    • DVail2000
      By DVail2000
      Ok, So I am seeing that most of you are leaning towards the ONAN engines being crap.  That said, I have 2 416's  # 1 is a -8 and # 2 is a -H.  Both have the -216 in them.  i was thinking of rebuilding the engine from the 416-H, but I am also considering changing the engine out with a different type.  What are the recomendations? I am seeing Koler, what else will fit?
      Thanks
      Dave.
    • 84Workhorse
      By 84Workhorse
      I'm looking for help in troubleshooting a starting problem with my 520. I used it yesterday to mow my yard for about 1.5 hours and when finished I let it cool down before shutting it off. It sat for about 2 hours and I put fuel in it and drove it on the ramps to clean the deck and after rolling it off the ramps I hit the starter and the engine made a noise and tried starting. I tried several times after that and no pop at all so I did a compression test and the front cylinder was fine and the rear was poor so I immediately thought of the valve seat being loose wedging the valve open. This morning I took the head off and much to my delight I did not see the seat as I thought but the head bolts were not very tight so I understand the poor compression (see pictures). The piston goes back and forth so that seems fine so I'm not sure where to focus my attention next. I am new to the 520 world and I tried searching the forums to find a thread that might walk me through this to no avail. I'm going to hold off putting the head back on just in case someone says to check something else related. This machine is new to me and has been smooth running, no smoke, good power, and always started easily with very little choke so I'm very surprised at this. Any help would be appreciated.
    • nickjet67
      By nickjet67
      Hello all, I recently acquired a "new" B-115, and with the help of @ohiofarmer, I will be fixing her up, first with a engine he is trading me for my old Kohler engine off my '77 B-80 that I trashed when I was 13. I haven't been in the Wheel horse game long, as I am 16 now, I hopefully will be able to keep this project updated on here, especially in the spring when I will be completely repainting it! I am super excited for this project, and am ready for all the challenges that lay ahead with it. if you have any helpful information you are willing to share about my newly acquired project, please share! I haven't had tons of luck finding tons of information about it.
