3609horse 27 #1 Posted February 10, 2013 Did all snow blowers have the chain go to a top sprocket ? I have one not sure which model it is but it would fit a 400 series tractor. The chain on this unit does not have the top sprocket like others I have had, and due to a chain that came loose it ate up the auger sprocket. I have the same set up on a blower that I have for a 604 it seems to be the same way. Is this the way it came or did the previous owner change the way the chain was routed ? Thanks. Gene.. Share this post Link to post Share on other sites
855ownerJoel 32 #2 Posted February 10, 2013 I can tell you that mine on my B80 and on my 414-8 have a top sprocket in the front. Do not know if that helps. Share this post Link to post Share on other sites
3609horse 27 #3 Posted February 10, 2013 I can tell you that mine on my B80 and on my 414-8 have a top sprocket in the front. Do not know if that helps. Thanks for your answer. Anything helps. Thanks again... Share this post Link to post Share on other sites
