IBleedRed
1054 Now and Then
IBleedRed
So awhile back I posted a topic called " Modification Dilema" where I asked whether or not I should cut the fenders on my 1054 to accommodate some taller tires. In the end I ended up cutting the fenders, only to realize later that the tire were way to damn tall as they stood at 32" compared to the factory 26/27". About a month later the 12hp Kohler I had put on it started to smoke like a chimney and I knew it was time for a total redo of the machine.
Jump to a couple weeks ago I began pulling it all apart for a fresh coat of paint, newer 16hp twin Briggs, swapping the 4 lug hubs for a pair of 5 lugs, and finally a set of 26x12x12 Ags. The engine proved to be the biggest challenge as it was way longer and wider than the original Kohler. For the width I bolted on a piece of angle to the side of the frame, but for the length I had to make brackets to extend the 50# grill 5" ahead. For extra support and to have a place to bolt on the hood I ran a piece of 1" flat stock from the grill to the tower.
With all the modifications came a drastic new look. Let me know what y'all think. If I ever get decals made up for it I'm gonna call it a
Wheel Horse 1054 "Low Boy"
post-5838-0-28401200-1338746252_thumb.jp
post-5838-0-70645700-1338746315_thumb.jp
post-5838-0-78459700-1338746331_thumb.jp
bowtiebutler956
:scared-eek: That's a beast, I like it! :text-datsphatyo: It would be neat if you built a hood extension to close the gap, but other than that I think its a tuff looking :wh: ! :thumbs:
Matt :flags-texas:
Sparky
Are you runnin it with those two straight pipes? No mufflers at all? Must be plenty loud!
Mike...........
Jake Kuhn
That thing sure is unique,pretty cool looking! :handgestures-thumbup: Jake
IBleedRed
Thanks for the comments. It is quite the beast but its a ways from being finished. The gap in the hood is a future project once I get a better welder (my 110v flux core welder burns through it to easily), same thing with the muffler. Its also a little slow at the moment as I need a step pulley so I can run the pump and the trans axle at the right speeds. Tonight I'll post some pics of it with the loader.
Thought I would throw some pictures of the 3 point up since the first ones didn't really show it.
post-5838-0-25467500-1338761315_thumb.jp
post-5838-0-93344000-1338761341_thumb.jp
post-5838-0-41892100-1338761363_thumb.jp
Alan_Heist
I LIKE it!!!
rexman72
very nice tractor
IBleedRed
Thanks again for the comments. Finished up with the loader today and got it mounted back on the machine. The bucket may look a little big, but it's only made of 1/16" steel and is pretty light for its size. I plan on making a heavy duty bucket whenever I come across some steel for it. Adjustable forks are also on the to do list.
post-5838-0-60261000-1338770594_thumb.jp
AMC RULES
Yeah, looks bada$$ with the FEL installed.
I'm definitely diggin' it IBR.
Jake Kuhn
Wow,that loader and 3 point sure make it look like a beast!
IBleedRed
I guess I'll rap up this update with some future ideas/ projects, of which I can only hope to get to sometime this decade:
Hood Lengthening
Muffler
Decals
Forks
HD Bucket
Wider Front Tires
Power Steering
Backhoe
And about 10 other things I can't think of at the moment.
Again, thanks for the comments.
  • Similar Content
    • Donavon
      By Donavon
      Need ideas to convert my 1054 A Frame plow into a snow blower
      Any idea's?
    • Wheel Horse 3D
      By Wheel Horse 3D
      Welcome, and thanks for visiting our vendor area.
      We got our start in 3D printing for customers right here on Red Square!
      If you'd like to see how every thing gets developed and the contributions of Red Square members, please visit the thread that started it all and browse through our progress to date.
      We love our clients' input and work closely to turn ideas into reality. If you have an idea, request, or questions, you can post to that thread, message us or tag us here on Red Square, or visit our Etsy store and reach out to us through there.
      Greystone 3D on Etsy
    • Wheel Horse 3D
      By Wheel Horse 3D
      Our customized ornaments have a base identical to our version of the original style ornament, but can be topped with 3 different styles of horse head and 3 different styles of wheel! Each is available unfinished, primed, or fully painted.
      They also include the pictured mounting hardware and the base spacer for a clean finished look. Can be ordred here Custom Wheel Horse hood ornaments..9 different styles
    • Burnerman
      By Burnerman
      I’m building a lowered 300 series wheelhorse. So far it’s a combination of 3 scrap tractors.
      the frame, trans and tins are from a GT2500 anniversary special given to me by a neighbor with a trashed Briggs. The Kohler M12 is from a junkyard 312 that was roached. The parts tractor I’m using for the build was another older 312. I’ve got the k301 in the garage. The trans was toast. Both axles wallowed out keyways and 1 axle actually broken.
      Anyway! I needed a project and a toy to putt around the neighborhood. I couldn’t find any other posts on how to do the whole thing. I’m trying to keep it cheap using stuff I have on hand and looking as “stock but cooler” as possible. So here we go.
      I’ll update this as I go along.
    • sjoemie himself
      By sjoemie himself
      A while ago I picked up a Canadiana 5hp heavy duty tiller. It features forward and reverse control and you could buy add on implements for it.
      My example unfortunately suffered a catastrofic engine faillure a.k.a. 'window' in the block. Hence it was cheap so I picked it up. The idea I had for it was to mount it on the rear of my 'Murray to IH 1568' build. However since I bought a Wheel Horse i've been thinking about mounting it on the front of that tractor.
      This is what i'm thinking..
