Toolmanbill 36 #1 Posted November 17 (edited) Trying to get deck welded and need to remove pulley and spindle and get the pulley off.looks like it should pull off.is it possible it is just frozen? I live in the woods and it is tough on the decks.this is the 3rd deck in 31 years. 2 sets of # on deck 1542sd03 and 1050621.any advice would be appreciated. Edited November 17 by Toolmanbill 1 Share this post Link to post Share on other sites
Ed Kennell 43,537 #2 Posted November 17 Two of these work ....sometimes. 1 Share this post Link to post Share on other sites
nylyon-(Admin) 8,503 #3 Posted November 17 What Ed said, have to get under the center of the pulley. I have had a couple where the pulley just bent, then have to get a new pulley. 1 Share this post Link to post Share on other sites
squonk 44,828 #4 Posted November 17 Buy a pulley, If you wreck it ya got one. If you don't wreck the pulley you have a spare or return it. 1 1 Share this post Link to post Share on other sites
Brockport Bill 2,108 #5 Posted November 17 i have had a few decks i bought used that i tried to rescue rehab that had obviously been left outdoors -- I used every imaginable idea and suggestion but they were totally rust frozen on shaft -- used multiple penetrant products for weeks -- used heat - used wheel puller - used 2 pry bars etc -- but at some point i had to surrender to the rust gods -- then its time to cut pulleys off -- the biggest challenge then is to not destroy the top of shaft with grinder disc which sadly isn't always possible. Just recently had to buy two new spindle shafts from KB. 1 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,815 #6 Posted November 17 Just for your records the model number is 15-42SC03 and the 1050621 is a 1991 serial number. Share this post Link to post Share on other sites
Brockport Bill 2,108 #7 Posted November 17 7 hours ago, Toolmanbill said: Trying to get deck welded and need to remove pulley and spindle and get the pulley off.looks like it should pull off.is it possible it is just frozen? I live in the woods and it is tough on the decks.this is the 3rd deck in 31 years. 2 sets of # on deck 1542sd03 and 1050621.any advice would be appreciated. wondering when you say from living in the 'woods" is tough on the decks -- that you needed 3 decks over 31 years, if that was from structural damage or from rot causing rust through holes ???? I have a 37 inch deck I bought new in '89 with my 312-8 -- I clean deck multiple times underneath each season -- its 36 years later -- i recently did rehab to save it for many more years of use - - cleaning it and mowing carefully has given it a long life Share this post Link to post Share on other sites
peter lena 9,543 #8 Posted November 17 @Toolmanbill your second picture is perfect for wonder bar placement, need 2 WONDER BARS , slide one on each side UNDER PULLEY AND ROCKING on the spindle mount bolt , push both bars OUTWARD t the same time , the leverage equalization ,gives a solid EQUAL LIFTING FORCE , of course penetrating oil before attempt , done a number of them , makes a tough job easy , you are PUTTING 90 DEGREE BAR END UNDER PULLER , ON TOP OF BOLTS THAT HOLD SPINDLE TO DECK , lift off is easy . if it were me I would also plan on doing bearing swap out and re greasing those spindle bearings , lucas xtra HD green chassis grease , done a number of decks , have also added a spindle belt idler , to reduce belt bounce . let me know how you are doing , pete 1 Share this post Link to post Share on other sites
Achto 30,090 #9 Posted November 17 (edited) 40 minutes ago, Brockport Bill said: wondering when you say from living in the 'woods" is tough on the decks Living in sand country is also very hard on decks. I have good black dirt and a full lawn. My friends yard is sand & grass is OK but not real full. A set of blades last one season. By the end of the year they are too thin to even bother sharpening. Given what the sand does to the blades, you can imagine what it does to a deck. 4 to 5 years on a deck before it gets sand blasted through. Needless to say he does not mow lawn with any of his vintage tractors. Instead he just burns through some cheaper lawn tractors and picks up decks for them when he can. Edited November 17 by Achto 1 Share this post Link to post Share on other sites
JoeM 9,121 #10 Posted November 17 I drive wood wedges under two sides of the pulley, you have to try to get as close to center as possible. I use door and window shims and put the nut on the top of the thread and give the shaft a wack. sometimes heat will help. I tried this one time and could not get enough clamping force on the fit. and it pulled off. Might have gave up to soon and should have redesigned the clamp. 1 Share this post Link to post Share on other sites
953 nut 62,793 #11 Posted November 18 8 minutes ago, JoeM said: drive wood wedges under two sides of the pulley, you have to try to get as close to center as possible. I use door and window shims and put the nut on the top of the thread and give the shaft a wack. A pair of wooden wedges on each side of the pulley driven toward one another will provide good even pressure. Put the nut on the shaft and use a brass hammer or a piece of hardwood to protect the threads and a BFH Tool with a good hard whack should pop it off. 1 Share this post Link to post Share on other sites
Brockport Bill 2,108 #12 Posted November 18 i have used the map gas -- multiple penetrants - plus the 2 "wonder" pry bars - and the hub puller -- none worked after many weeks -- thus was time to cut off the pulley Share this post Link to post Share on other sites
Toolmanbill 36 #13 Posted November 18 (edited) For what it’s worth I remove the deck in the winter to mount the standard front plow.before the mount this in the spring I put a wire brush on my angle grinder and repaint the underside and put new blades on. The wear and tear on the deck seem to come from tree roots that grow above ground and frost heave leave me more rocks.they seem to make very many babies in the spring. Thanks for all your help and responses!and for what its worth it’s never stored outside. Edited November 18 by Toolmanbill Not complete 1 Share this post Link to post Share on other sites
ineedanother 1,793 #14 Posted November 18 9 minutes ago, Toolmanbill said: For what it’s worth I remove the deck in the winter to mount the standard front plow.before the mount this in the spring I put a wire brush on my angle grinder and repaint the underside and put new blades on. The wear and tear on the deck seem to come from tree roots that grow above ground and frost heave leave me more rocks.they seem to make very many babies in the spring. Thanks for all your help and responses!and for what its worth it’s never stored outside. FWIW, mowing decks are high labor implements IMO. I enjoy cutting grass but am old and have little love for the engineering that we employ and have to maintain. Share this post Link to post Share on other sites
JoeM 9,121 #15 Posted November 18 (edited) On 11/17/2025 at 7:13 PM, 953 nut said: A pair of wooden wedges on each side of the pulley driven toward one another will provide good even pressure. Put the nut on the shaft and use a brass hammer or a piece of hardwood to protect the threads and a BFH Tool with a good hard whack should pop it off exactly! precisely! spot on mate! perfectly said! I do have a fine thread nut welded to a piece of 1/2" square steel that is put on the top of the threaded shaft when the BFH comes out of the drawer. Edited November 19 by JoeM 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 11,815 #16 Posted November 18 If you have the hub well supported a second sledge hammer and a friend helps. Hold one hammer on the nut and hit it with a second hammer. This prevents damage to the spindle and threads. And don't be afraid to hit it. One good slam is more effective than a few taps. 2 Share this post Link to post Share on other sites
