oliver2-44
Bought a Dealers Work Tractor, Original Patina 701
The Freightliner Guy
Nice find looks beautiful
stevasaurus
Beautiful horse Jim !!  My guess, the check balls in the fuel pump are stuck...carb cleaner.  :occasion-xmas:
SylvanLakeWH
:clap:
Pullstart
Awesome find, great story too!  If you’d like some red luster back, a nice easy wet sand with soapy water and 600+ sand paper to cut some rust off would be a wonderful idea.  Just spraying it with WD40 for a while might bring some red out too, but it sure looks brown!
WHGuy413
Beautiful tractor. I sold my all original 701 a few years ago that was in great shape. I definitely regret doing so.  It’s still local but the guy restored it.
kpinnc
On 9/20/2022 at 10:31 AM, oliver2-44 said:
I'll update this thread as I do maintenance on it and get it running.
That is an impressive machine. I had two 701s, and neither was that nice. I look forward to seeing what you do with it.
19richie66
Very nice original machine.
WHX??
Just caught this one Jim.... not enough :handgestures-thumbupright::handgestures-thumbupright:
WHNJ701
Nice find, keep the patina.
  • Similar Content
    • wh315-8
      By wh315-8
      So just picked up a 701, obviously the engine isn't right. I have a 7hp Kohler to put on and will put B&S on my Speedex. Anyone ever seen a post come out on the right from the rock shaft? It rotates with the lift handle and has no holes in it. It was done up well, almost looking factory.
    • chompinthebit
      By chompinthebit
      Hi all,
      i bought this 1961 701 in fall of 2018 and restored it. I completed it in fall of 2019 and I wanted to show some pictures of before during and after I got it done. I did my research and tried to make this tractor as close to original as possible. The few exceptions are tires, wiring and the steering support. Not a perfect tractor but sure is nice enough for me.
      all stainless hardware
      Rustolium stops rust Primer
      Rustolium Regal Red enamel paint
      powder coated wheels and seat
      Glenn Pettit Reproduction dash
    • T-Mo
      By T-Mo-(Moderator)
      1961 701s
    • NJ Tom
      By NJ Tom
      Just finished my winter project. I also restored the plow blade, now I'm going to look for some attachments.
