<?xml version="1.0"?>
<rss version="2.0"><channel><title>Tools and Equipment Latest Topics</title><link>https://www.wheelhorseforum.com/forum/160-tools-and-equipment/</link><description>Tools and Equipment Latest Topics</description><language>en</language><item><title>Fiskars splitting maul and mini ax</title><link>https://www.wheelhorseforum.com/topic/117054-fiskars-splitting-maul-and-mini-ax/</link><description><![CDATA[<p>
	In the continued effort to make certain parts of my life more physical, I've recently picked up this new 36 inch Fiskars splitting maul. It weighs something like 8.5 lb.
</p>
<p>
</p>
<p>
	Trina just a few weeks ago, picked up the little 17 inch mini ax that it's pictured with. Her mom wanted a smaller ax to use for splitting kindling up. The box arrived with two axes in it, so now each one of them has a mini.
</p>
<p>
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="482847" data-ratio="133.33" width="576" alt="20261107_124513.jpg.9a70decc563772dc65cf67d9fa5b0f37.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_11/20261107_124513.jpg.9a70decc563772dc65cf67d9fa5b0f37.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	I did a couple quick test splits with the maul. <strong>VERY IMPRESSIVE.  </strong>
</p>
<p>
</p>
<p>
	I like it so much I think I may have to get the ax that goes with it and has the same size handle.
</p>
<p>
</p>
<p>
	Here's the maul head in my big mitt.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="482848" data-ratio="133.33" width="576" alt="20261107_124536.jpg.80256cd7830c7265383a8d1c26ef6480.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_11/20261107_124536.jpg.80256cd7830c7265383a8d1c26ef6480.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
	I'm hoping to make this part of my better Fitness regiment.
</p>
<p>
</p>
<p>
</p>
<p>
</p>
]]></description><guid isPermaLink="false">117054</guid><pubDate>Sat, 07 Nov 2026 17:58:40 +0000</pubDate></item><item><title>Super inexpensive EDC pocket knife</title><link>https://www.wheelhorseforum.com/topic/117009-super-inexpensive-edc-pocket-knife/</link><description><![CDATA[<p>
	Many of us carry a small knife of some sort. I've almost always had the habit of keeping one close, but not in a pocket.
</p>
<p>
	Fishing tackle box, work "go-bag,"
</p>
<p>
	personal vehicle, etc.
</p>
<p>
</p>
<p>
	My S/O Trina has one clipped in her pocket nearly 100% of the time. So did my Ole Man.
</p>
<p>
</p>
<p>
	Every once in a while I could use one right to hand, not just within walking distance.
</p>
<p>
</p>
<p>
	My hands are larger than most. Comfort in palm is a challenge.
</p>
<p>
	I wanted a flip open style with a locking blade, hopefully with an easy release lock too.
</p>
<p>
</p>
<p>
	I didn't want to spend a bunch of money on a high quality piece only to leave it on the shelf...
</p>
<p>
	After searching the interwebs extensively, I found this Ozark Trail brand from Wally world.
</p>
<p>
	Several colors available.
</p>
<p>
	It has a clip on the back side.
</p>
<p>
	Cost around 8 bucks October of '26.
</p>
<p>
</p>
<p>
	Figured I'd share with the class.
</p>
<p>
	<img alt=":lol:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_laugh.png" title=":lol:" />
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_10/20261030_185759.jpg.1735ed8c0ad3176f7df94efb7580ac79.jpg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="482374" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_10/20261030_185759.jpg.1735ed8c0ad3176f7df94efb7580ac79.jpg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="20261030_185759.jpg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_10/20261030_185753.jpg.41e850e7dc9dfbe2520a3f6f59391ed2.jpg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="482375" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_10/20261030_185753.jpg.41e850e7dc9dfbe2520a3f6f59391ed2.jpg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="20261030_185753.jpg"></a></p>]]></description><guid isPermaLink="false">117009</guid><pubDate>Sat, 31 Oct 2026 17:00:53 +0000</pubDate></item><item><title>Improved Hub Puller</title><link>https://www.wheelhorseforum.com/topic/114354-improved-hub-puller/</link><description><![CDATA[<p>
	I built a hub puller a couple of weeks ago, which worked great (see below), but I thought I could improve upon it, so I fabbed up a new version, which has two advantages over the first one: It has a cavity for the hub spigot, so it can be bolted flat against the hub flange, which can add some rigidity to the flange, and it can be used with hubs that have been retrofitted with studs, as well as those that are still using lug bolts. Mine still has lug bolts, but I used a separate set of bolts and washers with the puller, rather than the lug bolts, in order to prevent any damage to the puller plate or to the tapered part of the lug bolts. The center bolt is longer than it needs to be, but that's what I had on hand. I put a dab of anti-seize on the center bolt threads.
</p>
<p>
</p>
<p>
	Previous version of hub puller:
</p>
<p>
	<img alt="previous-version-of-hub-puller.jpg.10998677f6f6c88afe32987ed3288dbf.jpg" class="ipsImage ipsImage_thumbnailed" data-fileid="461472" data-ratio="123.40" style="width:500px;height:auto;" width="622" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_01/previous-version-of-hub-puller.jpg.10998677f6f6c88afe32987ed3288dbf.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	New version:
</p>
<p>
	<a class="ipsAttachLink ipsAttachLink_image" data-fileext="jpg" data-fileid="461470" href="https://www.wheelhorseforum.com/uploads/monthly_2026_01/improved-hub-puller-on-tractor-2-smaller-image.jpg.ec4c89bf9217d1c439641d3436500d14.jpg" rel=""><img alt="improved-hub-puller-on-tractor-2-smaller-image.thumb.jpg.a6fc3443fac2791b62ccfab5f0ba6a21.jpg" class="ipsImage ipsImage_thumbnailed" data-fileid="461470" data-ratio="76.93" style="width:750px;height:auto;" width="998" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_01/improved-hub-puller-on-tractor-2-smaller-image.thumb.jpg.a6fc3443fac2791b62ccfab5f0ba6a21.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" /></a>
</p>
<p>
</p>
<p>
	Back of puller (I dressed the weld a bit, just for the heck of it):
</p>
<p>
	<img alt="back-of-puller-smaller-image.jpg.1a65d4236765e33d5b73fe1e1e14c009.jpg" class="ipsImage ipsImage_thumbnailed" data-fileid="461469" data-ratio="74.93" style="width:750px;height:auto;" width="1024" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_01/back-of-puller-smaller-image.jpg.1a65d4236765e33d5b73fe1e1e14c009.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	Front of puller:
</p>
<p>
	<img alt="hub-front-smaller-image.jpg.a3e5782fa866f4fedbd243f975be14bd.jpg" class="ipsImage ipsImage_thumbnailed" data-fileid="461468" data-ratio="74.40" style="width:750px;height:auto;" width="1024" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_01/hub-front-smaller-image.jpg.a3e5782fa866f4fedbd243f975be14bd.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
</p>
]]></description><guid isPermaLink="false">114354</guid><pubDate>Thu, 08 Jan 2026 22:55:56 +0000</pubDate></item><item><title>Removing hydrostatic filter off a 312h</title><link>https://www.wheelhorseforum.com/topic/116725-removing-hydrostatic-filter-off-a-312h/</link><description><![CDATA[<p>
	I just modified, cut off 1 end, of a regular oil filter wrench so that I could just spin the filter off without having to reposition the wrench.  I added the bolts so I could push the filter off the wrench easily.
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260921_145427.jpg.9d425177745ad566723e500859ff519d.jpg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="480127" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260921_145427.jpg.9d425177745ad566723e500859ff519d.jpg" data-ratio="177.78" width="432" class="ipsImage ipsImage_thumbnailed" alt="20260921_145427.jpg"></a></p>]]></description><guid isPermaLink="false">116725</guid><pubDate>Thu, 24 Sep 2026 02:14:53 +0000</pubDate></item><item><title>National Hardware Show Inventions</title><link>https://www.wheelhorseforum.com/topic/116685-national-hardware-show-inventions/</link><description><![CDATA[<p>
	Not so much on gadgets but some items are worth a look.
</p>
<div class="ipsEmbeddedVideo">
	<div>
		<iframe allowfullscreen="" frameborder="0" height="113" title="40 Top Inventions Found At Inventor Pavilion 2026!" width="200" data-embed-src="https://www.youtube.com/embed/JqcprXbU-ew?feature=oembed"></iframe>
	</div>
</div>
<p>
</p>
]]></description><guid isPermaLink="false">116685</guid><pubDate>Fri, 18 Sep 2026 18:15:51 +0000</pubDate></item><item><title>Echo CS490 chainsaw. Air filter upgrade kit.</title><link>https://www.wheelhorseforum.com/topic/116570-echo-cs490-chainsaw-air-filter-upgrade-kit/</link><description><![CDATA[<p>
	I've mentioned elsewhere on the site that I've been messing around with a few chainsaws this year.
</p>
<p>
	This Echo CS490 is the only one I've bought new. I believe that was 2017.
</p>
<p>
</p>
<p>
	This year I decided to do a couple upgrades on it.
</p>
<p>
</p>
<p>
	A muffler modification or "mod" is basically when you remove the restrictions of the stock exhaust by either modifying the existing muffler or replacing it with an aftermarket option.
</p>
<p>
	On this particular saw there's a good addition in HP and torque if one removes the internal screen and restrictor pipe.
</p>
<p>
	I did that a couple months ago and was instantly impressed.
</p>
<p>
	As part of that process you have to richen the mixture. For that reason I removed the carb adjustment limiter cover caps.
</p>
<p>
</p>
<p>
	The next thing is to increase intake capacity.
</p>
<p>
	This kit is 3D printed by a company called A2D. (See the sticker.)
</p>
<p>
</p>
<p>
	It's a super simple completely bolt on kit.
</p>
<p>
	The biggest benefit is MUCH better air filtration.
</p>
<p>
	A side benefit is a little better breathing.
</p>
<p>
</p>
<p>
</p>
<p>
	Before.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478881" data-ratio="133.33" width="576" alt="20260905_081814.jpg.16790df59b0791d88b3c209dd8070417.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_081814.jpg.16790df59b0791d88b3c209dd8070417.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478882" data-ratio="133.33" width="576" alt="20260905_081823.jpg.6d5a6e1e9f697a05eb534219afa7786c.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_081823.jpg.6d5a6e1e9f697a05eb534219afa7786c.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
	Original air filter.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478883" data-ratio="133.33" width="576" alt="20260905_081846.jpg.e8e309c8f56cdc134c5321a47af28c28.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_081846.jpg.e8e309c8f56cdc134c5321a47af28c28.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	Original air filter base.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478884" data-ratio="133.33" width="576" alt="20260905_083131.jpg.756f42e8a9aedacb3d08a9866fb591c2.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_083131.jpg.756f42e8a9aedacb3d08a9866fb591c2.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
	Parts removed down to the carb.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478886" data-ratio="133.33" width="576" alt="20260905_084822.jpg.ddd47a62da77f9e4bc666468e139a394.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_084822.jpg.ddd47a62da77f9e4bc666468e139a394.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
	The original air filter and base on the right.
</p>
<p>
	Replacement base, filter, and top holder on the left.
</p>
<p>
	The new air filter is actually a stock replacement filter for a different Echo model.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478885" data-ratio="133.33" width="576" alt="20260905_084814.jpg.cfd942c3eca3a2a5fed5ca953b6dff42.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_084814.jpg.cfd942c3eca3a2a5fed5ca953b6dff42.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	The kit maker recommends a thin layer of grease between the new base and carb, and on both sides of the new air filter.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478887" data-ratio="133.33" width="576" alt="20260905_085819.jpg.68356291bccb5f600a5479ea2e91453e.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_085819.jpg.68356291bccb5f600a5479ea2e91453e.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	Note the large black surround piece. That stabilizes the filter base and raises the stock lid for space to install the new filter.
</p>
<p>
	It also allows a huge improvement in breathing capability by allowing air flow from the sides.
</p>
<p>
	There's a solid piece available for very cold weather operation.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478888" data-ratio="133.33" width="576" alt="20260905_090710.jpg.6d75410508a05ebe9d759dcc0284e3bf.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_090710.jpg.6d75410508a05ebe9d759dcc0284e3bf.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	New filter in place.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478889" data-ratio="133.33" width="576" alt="20260905_091129.jpg.b490347bb378ce9eb079263d63d63b77.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_091129.jpg.b490347bb378ce9eb079263d63d63b77.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
	All cinched up.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478890" data-ratio="133.33" width="576" alt="20260905_092618.jpg.d121c8d701f58be1c6ffb1e75d2cced7.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_092618.jpg.d121c8d701f58be1c6ffb1e75d2cced7.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	The kit even comes with a rub on decal to identify the modifications.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478891" data-ratio="133.33" width="576" alt="20260905_092936.jpg.5c035abd92bc0d879475e2f8aa17c65a.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_09/20260905_092936.jpg.5c035abd92bc0d879475e2f8aa17c65a.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
	I took the saw out to the side forest for a few minutes. Power level seems a tad higher. Definitely runs nice and smooth and has a very quick throttle response.
</p>
<p>
</p>
<p>
	I was unable to run it long because that saw needs a new bar. That's been ordered.
</p>
<p>
</p>
<p>
</p>
]]></description><guid isPermaLink="false">116570</guid><pubDate>Sat, 05 Sep 2026 22:02:14 +0000</pubDate></item><item><title>Terminal Removal Kit</title><link>https://www.wheelhorseforum.com/topic/116533-terminal-removal-kit/</link><description><![CDATA[<p>
	IDK how many times I could have used these over the years and finally ordered me a set. Some of the terminals I have worked on I could release and save but a bunch I could not <img alt=":ranting:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_ranting.gif" title=":ranting:" />. I hope the days of sticking them precision screwdrivers I had been using in my hands and fingers are over. Surely there sumin in this kit that will cover all the terminals I will ever come across from here on out <img alt=":handgestures-fingerscrossed:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_handgestures/fingerscrossed.gif" title=":handgestures-fingerscrossed:" />. These seem well made with a handle that you can hold on to. Will try and replace the 9 pin connectors on my 520’s with new 9 pin connectors instead of replacing with 2 4 wire trailer connectors. Me being a purist ya know.<img alt=":rolleyes:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_rolleyes.gif" title=":rolleyes:" />
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_08/9F09CFA6-6339-4057-9536-1FFAE95D1869.jpeg.68af73c7d0357d662a7a77e40944c317.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="478508" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_08/9F09CFA6-6339-4057-9536-1FFAE95D1869.jpeg.68af73c7d0357d662a7a77e40944c317.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="9F09CFA6-6339-4057-9536-1FFAE95D1869.jpeg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_08/931AB8BE-C81D-4A12-B785-A0DBD9C11F17.jpeg.eb6b923ce1a1afd729666190ad79f75b.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="478509" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_08/931AB8BE-C81D-4A12-B785-A0DBD9C11F17.jpeg.eb6b923ce1a1afd729666190ad79f75b.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="931AB8BE-C81D-4A12-B785-A0DBD9C11F17.jpeg"></a></p>]]></description><guid isPermaLink="false">116533</guid><pubDate>Sun, 30 Aug 2026 17:21:50 +0000</pubDate></item><item><title>Magnetic Socket holders</title><link>https://www.wheelhorseforum.com/topic/116491-magnetic-socket-holders/</link><description><![CDATA[<p>
	My 1/4 drive sockets have been on the below pictured cheap <span class="ipsEmoji">💩</span> chrome rails for yyeeeaarrs. I've thought about getting actual big boy holders pretty much that whole time.
</p>
<p>
	Today I got these nifty blue magnetic holders.
</p>
<p>
	MUCH better.
</p>
<p>
	No more falling rolling sockets.
</p>
<p>
</p>
<p>
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478237" data-ratio="20.31" width="1024" alt="2011676820_20260825_1848442.jpg.ecbb895e2b330b812655bca422c7edf7.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_08/2011676820_20260825_1848442.jpg.ecbb895e2b330b812655bca422c7edf7.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
]]></description><guid isPermaLink="false">116491</guid><pubDate>Wed, 26 Aug 2026 01:03:42 +0000</pubDate></item><item><title>ICON Magnetic Mat</title><link>https://www.wheelhorseforum.com/topic/116481-icon-magnetic-mat/</link><description><![CDATA[<p>
	Can't say enough about then ICON magnetic mat from my favorite haunt Horror Fright!  Super handy when tearing down a tractor. Bolts, parts, tools stick to it so things don't go bye bye  and won't harm the paint on <span><a contenteditable="false" data-ipshover="" data-ipshover-target="https://www.wheelhorseforum.com/profile/15265-whx/?do=hovercard" data-mentionid="15265" href="https://www.wheelhorseforum.com/profile/15265-whx/" rel="">@WHX??</a> and <a contenteditable="false" data-ipshover="" data-ipshover-target="https://www.wheelhorseforum.com/profile/14491-achto/?do=hovercard" data-mentionid="14491" href="https://www.wheelhorseforum.com/profile/14491-achto/" rel="">@Achto</a>'s trailer queens! Not cheap at 25 clams but worth it in my book! <img alt=":banana-wrench:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_banana/wrench.gif" title=":banana-wrench:" /></span>
</p>
<p>
</p>
<p>
	<span><a href="https://www.harborfreight.com/large-magnetic-tool-pad-attaches-to-toolboxes-fenders-and-doors-11-in-x-9-in-mat-holds-ratchets-wrenches-and-sockets-70077.html" rel="external nofollow">https://www.harborfreight.com/large-magnetic-tool-pad-attaches-to-toolboxes-fenders-and-doors-11-in-x-9-in-mat-holds-ratchets-wrenches-and-sockets-70077.html</a></span>
</p>
<p>
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="478160" data-ratio="75.00" width="1024" alt="pad.jpg.9fd5024707f3df69335151c23181f38d.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_08/pad.jpg.9fd5024707f3df69335151c23181f38d.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
]]></description><guid isPermaLink="false">116481</guid><pubDate>Tue, 25 Aug 2026 00:03:23 +0000</pubDate></item><item><title>Cheap lift</title><link>https://www.wheelhorseforum.com/topic/116450-cheap-lift/</link><description><![CDATA[<p>
	Snagged this off CL for an upcoming motor swap in my WorkHorse. $40. Couldn't pass it up for that price!
</p>
<p>
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_08/Lift.JPG.abe0c59e133eea14fb9d287ec9788b3f.JPG" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="477932" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_08/Lift.JPG.abe0c59e133eea14fb9d287ec9788b3f.JPG" data-ratio="96.36" width="797" class="ipsImage ipsImage_thumbnailed" alt="Lift.JPG"></a></p>]]></description><guid isPermaLink="false">116450</guid><pubDate>Fri, 21 Aug 2026 17:48:00 +0000</pubDate></item><item><title>Bench grinder</title><link>https://www.wheelhorseforum.com/topic/116251-bench-grinder/</link><description><![CDATA[<p>
	I found my old grinder today.  Yes, I used it in this shape as a teenager.  <img alt=":scared-shocked:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_scared/shocked.gif" title=":scared-shocked:" />  That power cord has been like that as long as I can remember.
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_07/IMG_7040.jpeg.addfb49ee43199ebc298982d67670e09.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="476537" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_07/IMG_7040.jpeg.addfb49ee43199ebc298982d67670e09.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="IMG_7040.jpeg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_07/IMG_7041.jpeg.9d2077009a92d837d649c87a4e83fe86.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="476538" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_07/IMG_7041.jpeg.9d2077009a92d837d649c87a4e83fe86.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="IMG_7041.jpeg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_07/IMG_7042.jpeg.3aa201e6674233131cdc5426b735759b.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="476539" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_07/IMG_7042.jpeg.3aa201e6674233131cdc5426b735759b.jpeg" data-ratio="75" width="1024" class="ipsImage ipsImage_thumbnailed" alt="IMG_7042.jpeg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_07/IMG_7043.jpeg.af8be433e7b3a434e652e9af531bd0be.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="476540" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_07/IMG_7043.jpeg.af8be433e7b3a434e652e9af531bd0be.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="IMG_7043.jpeg"></a></p>]]></description><guid isPermaLink="false">116251</guid><pubDate>Tue, 28 Jul 2026 19:21:53 +0000</pubDate></item><item><title>Inspection camera</title><link>https://www.wheelhorseforum.com/topic/116129-inspection-camera/</link><description><![CDATA[<p>
	I was never inclined to have an inspection camera in my shop but my wife was apparently not meeting her Amazon purchasing quota and thought I could use one <img alt=":rolleyes:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_rolleyes.gif" title=":rolleyes:" />. Well I actually used it today. I had a loose drive pulley on my c-161-8 and couldn't find the set screw behind the pulley with all of the dirt and dust. I don't know how often I'll use it but it came in handy today <img alt=":thumbs:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_th_thumbsup.gif" title=":thumbs:" />
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_07/930365284_IMG_27541.jpg.1caee9147106c9fc5b982db32a474557.jpg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="475361" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_07/930365284_IMG_27541.jpg.1caee9147106c9fc5b982db32a474557.jpg" data-ratio="75" width="1008" class="ipsImage ipsImage_thumbnailed" alt="IMG_2754[1].jpg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_07/735272286_UATP19391.jpg.c4fd6f2ff9549b0589f7be8ddb2569ba.jpg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="475362" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_07/735272286_UATP19391.jpg.c4fd6f2ff9549b0589f7be8ddb2569ba.jpg" data-ratio="75" width="480" class="ipsImage ipsImage_thumbnailed" alt="UATP1939[1].jpg"></a></p>]]></description><guid isPermaLink="false">116129</guid><pubDate>Sun, 12 Jul 2026 22:46:12 +0000</pubDate></item><item><title>Low Budget DC Volt Tester</title><link>https://www.wheelhorseforum.com/topic/115825-low-budget-dc-volt-tester/</link><description><![CDATA[<p>
	<a contenteditable="false" data-ipshover="" data-ipshover-target="https://www.wheelhorseforum.com/profile/15265-whx/?do=hovercard" data-mentionid="15265" href="https://www.wheelhorseforum.com/profile/15265-whx/" rel="">@WHX??</a> picked one of these up at a flee market last weekend, of course he got the last one there. <img alt=":wacko:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_wacko.png" title=":wacko:" /> I found them on the jungle site. Handy tool to have, doesn't take up much room, and a low price.
</p>
<p>
</p>
<p>
	<a href="https://www.amazon.com/WINAMOO-Automotive-Voltmeter-Polarity-Stainless/dp/B0D8PXNPYH/ref=sr_1_6" rel="external nofollow">https://www.amazon.com/WINAMOO-Automotive-Voltmeter-Polarity-Stainless/dp/B0D8PXNPYH/ref=sr_1_6</a>
</p>
]]></description><guid isPermaLink="false">115825</guid><pubDate>Tue, 16 Jun 2026 13:48:26 +0000</pubDate></item><item><title>Waste Oil Burner</title><link>https://www.wheelhorseforum.com/topic/110909-waste-oil-burner/</link><description><![CDATA[<p>
	I’m going to call this a tool or equipment.  It’ll be used to safely heat my shop, compared to a “topedo” heater.  I also have a fan assisted coil from the wood boiler, but the shop consumes a ton of heat and I spend more time throwing wood in.
</p>
<p>
</p>
<p>
	I’ll call this the brainstorming phase picture.  My first ever new air compressor purchase, it lasted about 12-15 years before the compressor gave out.  Some drums and rotors for thermal mass and a burn pot, some stuff to create a door area…
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2025_02/IMG_7642.jpeg.595d94c604d5a38594bdf1bdf38317d0.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="433770" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2025_02/IMG_7642.jpeg.595d94c604d5a38594bdf1bdf38317d0.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="IMG_7642.jpeg"></a></p>]]></description><guid isPermaLink="false">110909</guid><pubDate>Thu, 13 Feb 2025 12:49:33 +0000</pubDate></item><item><title>Spindle wrench and Horse Head key</title><link>https://www.wheelhorseforum.com/topic/115506-spindle-wrench-and-horse-head-key/</link><description><![CDATA[<p>
	My $5 marketplace score - 6 miles from my house!
</p>
<p>
</p>
<p>
	<img alt="IMG_5120.jpg.4798556c78e391fa593c6ceed9630e77.jpg" class="ipsImage ipsImage_thumbnailed" data-fileid="470483" data-ratio="74.90" style="width:1000px;height:auto;" width="1024" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_05/IMG_5120.jpg.4798556c78e391fa593c6ceed9630e77.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
	 <img class="ipsImage ipsImage_thumbnailed" data-fileid="470491" data-ratio="89.93" width="854" alt="image.png.c7c99003498bd90d94bec0f25c1d0e70.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_05/image.png.c7c99003498bd90d94bec0f25c1d0e70.png" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
]]></description><guid isPermaLink="false">115506</guid><pubDate>Sat, 16 May 2026 00:38:27 +0000</pubDate></item><item><title>Work Stand Height for Tractors</title><link>https://www.wheelhorseforum.com/topic/115487-work-stand-height-for-tractors/</link><description><![CDATA[<p>
	Quick question for y'all that has a worktable or lift fir their Wheel horse tractors. If you had just one height for your table, what would it be? I have an old table I made out of an electrical cabinet door with black iron pipe for legs years ago (very sturdy) that measures 6ft by 3 ft and is around 3.5ft tall and wanting to lower it so I can put my tractors on to work on them, just can't decide what height I should make it. Probably use atv ramp to load/unload tractors and maybe some casters or wheels on it to make it a little mobile.
</p>
]]></description><guid isPermaLink="false">115487</guid><pubDate>Thu, 14 May 2026 19:59:27 +0000</pubDate></item><item><title>Washing the shop rags</title><link>https://www.wheelhorseforum.com/topic/115196-washing-the-shop-rags/</link><description><![CDATA[<p>
	Shop rags can get expensive and I don’t like to put them in my washing machine. I’ve had this cement mixer around for a while now and figured I’d put it to good use <span><img alt=":)" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/emoticons/default_smile.png" title=":)" /></span>
</p>
<video controls class="ipsEmbeddedVideo" data-fileid="468291" data-video-embed>
	<source data-video-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_4450.mov.e2a7cf8103028b79fb841f1ed4c5994d.mov" type="video/quicktime">
	<a class="ipsAttachLink" href="//www.wheelhorseforum.com/applications/core/interface/file/attachment.php?id=468291">IMG_4450.mov</a>
</video>]]></description><guid isPermaLink="false">115196</guid><pubDate>Sun, 19 Apr 2026 01:03:06 +0000</pubDate></item><item><title>Boss Industrial brand 20 ton Dual action log splitter</title><link>https://www.wheelhorseforum.com/topic/115205-boss-industrial-brand-20-ton-dual-action-log-splitter/</link><description><![CDATA[<p>
	Looonng first post.... LOTS to write....
</p>
<p>
</p>
<p>
</p>
<p>
	For several years we've been considering an upgrade to our old wood splitter. It's a very well (re)built decades old unit that was home shop rebuilt in 2012 by a local logger.
</p>
<p>
	After 14 seasons of splitting it's understandably getting tired.
</p>
<p>
	We started a thread here, got some great info.
</p>
<p>
</p>
<iframe allowfullscreen="" data-embedauthorid="19474" data-embedcontent="" data-embedid="embed7668492464" scrolling="no" style="height:271px;max-width:502px;" data-embed-src="https://www.wheelhorseforum.com/topic/111323-how-do-we-speed-up-our-log-splitter/?tab=comments&amp;do=embed&amp;comment=1221380&amp;embedComment=1221380&amp;embedDo=findComment#comment-1221380"></iframe>
<p>
</p>
<p>
</p>
<p>
	We researched on other sites and spoke to our favorite small engine repair place.
</p>
<p>
	We decided that it would need the entire hydraulic system replaced and a new larger engine to meet the goals.
</p>
<p>
	Not at all opposed to this but it would easily cost $2,000 +.
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
	While doing research online we found a couple dual action splitters.  Very intriguing.
</p>
<p>
</p>
<p>
	We started a thread on that here:
</p>
<iframe allowfullscreen="" data-embedauthorid="19474" data-embedcontent="" data-embedid="embed3392338964" scrolling="no" style="height:388px;max-width:502px;" data-embed-src="https://www.wheelhorseforum.com/topic/114775-tell-us-the-pros-and-cons-of-this-splitter/?do=embed"></iframe>
<p>
</p>
<p>
	..... And again learned some great information along with creating some additional thought processes.
</p>
<p>
</p>
<p>
</p>
<p>
	We decided to get the Boss model over the HF model because of several factors.
</p>
<p>
	1. Kohler engine on the Boss.
</p>
<p>
	2. Too many pivot/ wear points on the HF.
</p>
<p>
	3. Hydraulic control lever is centered on the Boss vs one sided operation in the HF. This is a very convenient feature for Trina in particular because she's prone to jumping around wherever the workload can be accomplished the best.
</p>
<p>
	4. Overall frame strength and build quality appears better on the Boss than the HF according to multiple online sources.
</p>
<p>
	5. The Boss is certified for road towing. The HF is not.  (We'll visit that below)
</p>
<p>
</p>
<p>
</p>
<p>
	The new Boss splitter arrived this week.
</p>
<p>
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="468332" data-ratio="75.00" width="1024" alt="IMG_20260419_100437.jpg.8e9291d163c5ec7fda3ee6eb5689642f.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_20260419_100437.jpg.8e9291d163c5ec7fda3ee6eb5689642f.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="468334" data-ratio="75.00" width="1024" alt="IMG_20260419_100427.jpg.8541eab9e223793f6a4665bc5ef16e98.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_20260419_100427.jpg.8541eab9e223793f6a4665bc5ef16e98.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="468335" data-ratio="75.00" width="1024" alt="IMG_20260419_100423.jpg.37266d63b517ab8ab89e000214bbc2fb.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_20260419_100423.jpg.37266d63b517ab8ab89e000214bbc2fb.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
	Overall it looks good. I agree with  #4 above. The welds are solid. The frame is good thick steel.
</p>
<p>
	The cylinder is encapsulated in a square slider tube which is encapsulated in the frame.  Purely a flat surface sliding design with no bearings. <a contenteditable="false" data-ipshover="" data-ipshover-target="https://www.wheelhorseforum.com/profile/7208-ed-kennell/?do=hovercard" data-mentionid="7208" href="https://www.wheelhorseforum.com/profile/7208-ed-kennell/" rel="">@Ed Kennell</a>
</p>
<p>
	Grease will be applied. Often.  <a contenteditable="false" data-ipshover="" data-ipshover-target="https://www.wheelhorseforum.com/profile/20913-peter-lena/?do=hovercard" data-mentionid="20913" href="https://www.wheelhorseforum.com/profile/20913-peter-lena/" rel="">@peter lena</a>
</p>
<p>
</p>
<p>
</p>
<p>
	North American design but made in china.
</p>
<p>
	Build quality is reasonable except for a few things.
</p>
<p>
	The trailer tongue mount is too narrow for the main frame.   We had to use washers to set the tongue to one side and add longer bolts to the other side.
</p>
<p>
</p>
<p>
	I WOULD NOT tow this unit on the road the way it's sent. IMHO it was not safe.
</p>
<p>
	That - quite frankly - pi$$ed me off.
</p>
<p>
</p>
<p>
	This side is flush.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="468336" data-ratio="133.33" width="576" alt="IMG_20260419_100400.jpg.c7d10e9163fe75c2f780f2e9b257eb98.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_20260419_100400.jpg.c7d10e9163fe75c2f780f2e9b257eb98.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
	This side is not.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="468337" data-ratio="133.33" width="576" alt="IMG_20260419_100355.jpg.615921a527b2430f70af3caa9cc2a181.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_20260419_100355.jpg.615921a527b2430f70af3caa9cc2a181.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
	See the space difference...
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="468338" data-ratio="133.33" width="576" alt="IMG_20260419_100350.jpg.c5876e070aae054b1e6bc83224f0867f.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_20260419_100350.jpg.c5876e070aae054b1e6bc83224f0867f.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	Now imagine trying to "tighten" that enough to close the space using low quality hardware... or even great quality hardware. Not happening buster.
</p>
<p>
</p>
<p>
</p>
<p>
	The entire hardware package is the unfortunate cheap trash we see all too often on cheap items. Nut &amp; bolt head sizes are inconsistent (WTH??)  and lacking quality.
</p>
<p>
	I upgraded several bolts, added washers, and replaced the disgustingly lightweight axle castle nuts with better quality pieces.  We were unable to drive the steel press fit axle dust caps in so we popped the plastic ones back on.  This is fine unless/until we ever need to road tow it.
</p>
<p>
	The axle inner seal surface isn't even properly machined.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="468339" data-ratio="75.00" width="1024" alt="IMG_20260419_100339.jpg.f67bb7b14ef0918075d03a6b0bbc8c03.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_20260419_100339.jpg.f67bb7b14ef0918075d03a6b0bbc8c03.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	If this was going to be towed often or long distance it would eat seals.  Fast.
</p>
<p>
</p>
<p>
</p>
<p>
	After using it for only a few minutes it's developed an issue already.
</p>
<p>
</p>
<p>
	Like many splitters, It has a two stage hydraulic system. When the pressure reaches a certain level the system changes from high speed low pressure to low speed high pressure.
</p>
<p>
	This one WAS working like that. Now it starts high speed. Goes low speed and stays there. Shut it off and move the lever to release system pressure. Restart and repeat. I'm hoping it's an adjustment, not a defective part.
</p>
<p>
</p>
<p>
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="468340" data-ratio="75.00" width="1024" alt="IMG_20260418_141623.jpg.94495aafebb9943a85c4a17f04fb8e6b.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_04/IMG_20260418_141623.jpg.94495aafebb9943a85c4a17f04fb8e6b.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
	We've run some decent sized beech wood through it. That went well.
</p>
<p>
	Power level seems good.
</p>
<p>
	We're thinking it should be faster though. That may be related to the above issue or possibly because it's new and needs to break in.  Or.... it's just slower than we hoped.
</p>
<p>
</p>
<p>
</p>
<p>
	Again, overall I believe it'll be a good addition once the bugs are worked out.
</p>
<p>
	The work habits obviously are very different from a single action to this dual action. The fact that one can use both directions is very nice. Very weird at first too.  Once a different and properly adjusted set of habits is developed we can see a new kind of usefulness.
</p>
<p>
</p>
<p>
	We did get the additional cross piece to split horizontally. It has its place but also has its challenges. The second split is nice IF the pieces of wood separate correctly. Because we use a lot of beech wood, that isn't practical much of the time.
</p>
<p>
</p>
<p>
</p>
<p>
	I'll document repairs and changes in this thread.
</p>
<p>
</p>
<p>
	Some changes we figured on making even before purchase, no matter what splitter we got.
</p>
<p>
</p>
<p>
	1.  Wheel size, tongue height &amp; length increase.
</p>
<p>
	The OE tires are 4.00/4.80 x 8. Seems most splitters are standard at that.
</p>
<p>
	I'd likely add a set of 5 lug hubs and increase to a full size tire like we did on the other splitter. Tongue height and length will be adjusted to level and to compensate for the additional table length..(Next comment)
</p>
<p>
</p>
<p>
	2.  Larger flat work table.
</p>
<p>
	As you can see in the last picture above there are small catch shelves on the sides. The principal is good. The upward angle is actually a bit of a challenge to work with. The wood pieces want to fall back into the work area. Remember gravity?
</p>
<p>
	We're thinking about adding a much larger, flat work table to catch the pieces on both sides.
</p>
<p>
	Start the split. Set one half aside. Work with the other. Have plenty of space to move the shrinking pieces around and off the table.
</p>
<p>
</p>
]]></description><guid isPermaLink="false">115205</guid><pubDate>Sun, 19 Apr 2026 16:05:55 +0000</pubDate></item><item><title>Tell us the pros and cons of this splitter</title><link>https://www.wheelhorseforum.com/topic/114775-tell-us-the-pros-and-cons-of-this-splitter/</link><description><![CDATA[<p>
	The BBT aka Trina person and I have been discussing an upgrade to our firewood processing system.
</p>
<p>
</p>
<p>
</p>
<p>
	This splitter seems to be a decent idea.
</p>
<p>
</p>
<p>
	<a href="https://www.woodsplitterdirect.com/products/boss-industrial-20-ton-horizontal-dual-action-gas-log-splitter-gd20t24" rel="external nofollow">https://www.woodsplitterdirect.com/products/boss-industrial-20-ton-horizontal-dual-action-gas-log-splitter-gd20t24</a>
</p>
<p>
</p>
<p>
</p>
<p>
</p>
<p>
	Thoughts comments questions suggestions??
</p>
<p>
</p>
<p>
</p>
]]></description><guid isPermaLink="false">114775</guid><pubDate>Sat, 28 Feb 2026 14:50:23 +0000</pubDate></item><item><title>HF Coupons</title><link>https://www.wheelhorseforum.com/topic/114949-hf-coupons/</link><description><![CDATA[<p>
	Show of hands who subscribes to their email blasts for coupons or deals? It's prolly a good thing I don't have a HF just down the street I'd have a lot of things I want but don't need. Here's one for The Pullstart... He gets his sockets I get my missing step bit. <img alt=":lol:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_laugh.png" title=":lol:" />
</p>
<p>
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_03/1428408371_Screenshot2026-03-23074539.png.fb1fe65e94399fb9fc5a2d9b4538bf4c.png" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="466372" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_03/1428408371_Screenshot2026-03-23074539.png.fb1fe65e94399fb9fc5a2d9b4538bf4c.png" data-ratio="78.92" width="517" class="ipsImage ipsImage_thumbnailed" alt="Screenshot 2026-03-23 074539.png"></a></p>]]></description><guid isPermaLink="false">114949</guid><pubDate>Mon, 23 Mar 2026 12:47:27 +0000</pubDate></item><item><title>Auction items</title><link>https://www.wheelhorseforum.com/topic/113821-auction-items/</link><description><![CDATA[<p>
	Scored some decent tools from a local online auction. Pick up Tuesday morning.
</p>
<p>
</p>
<p>
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2025_11/2147205876_Screenshot_20251117_162319_Chrome2.jpg.b25a1a71cb4ff4f1fc3295f920d5c09c.jpg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="457410" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2025_11/2147205876_Screenshot_20251117_162319_Chrome2.jpg.b25a1a71cb4ff4f1fc3295f920d5c09c.jpg" data-ratio="162.37" width="473" class="ipsImage ipsImage_thumbnailed" alt="Screenshot_20251117_162319_Chrome~2.jpg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2025_11/1350510999_Screenshot_20251117_162356_Chrome2.jpg.552fce47b82f999c5d4a040f9a83cb10.jpg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="457411" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2025_11/1350510999_Screenshot_20251117_162356_Chrome2.jpg.552fce47b82f999c5d4a040f9a83cb10.jpg" data-ratio="159.01" width="483" class="ipsImage ipsImage_thumbnailed" alt="Screenshot_20251117_162356_Chrome~2.jpg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2025_11/535276507_Screenshot_20251117_162440_Chrome2.jpg.49790c6a61d3866687f2b73d5f450ec7.jpg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="457412" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2025_11/535276507_Screenshot_20251117_162440_Chrome2.jpg.49790c6a61d3866687f2b73d5f450ec7.jpg" data-ratio="123.87" width="620" class="ipsImage ipsImage_thumbnailed" alt="Screenshot_20251117_162440_Chrome~2.jpg"></a></p>]]></description><guid isPermaLink="false">113821</guid><pubDate>Mon, 17 Nov 2025 21:52:53 +0000</pubDate></item><item><title>Balancer puller</title><link>https://www.wheelhorseforum.com/topic/114797-balancer-puller/</link><description><![CDATA[<p>
	After l bent the balancer puller plate and destroyed the threads on a advance auto PT brand one. I returned that one for the warranty.
</p>
<p>
</p>
<p>
	And ordered a used snap-on from eBay for $30, 100% worth it. I was going between this snap-on, and a old Mac puller. Ended up going snap-on because of the applications I am using it for, the snap-on's design let's the plate sit a little closer, when pulling on shafts like this.
</p>
<p>
	I am not huge on tool truck name tool brands. I have many different brands in my toolbox, lot of old craftsman, crescent, masterforce (menards brand) are the main ones.
</p>
<p>
</p>
<p>
	But these pullers, are one tool I would definitely go name brand, or at least old on.
</p>
<p>
</p>
<p>
	<img alt="IMG_20260302_173130477_HDR.jpg.b06a5ec81bb63706c70d82e4f179b639.jpg" class="ipsImage ipsImage_thumbnailed" data-fileid="465298" data-ratio="132.87" style="height:auto;" width="578" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_20260302_173130477_HDR.jpg.b06a5ec81bb63706c70d82e4f179b639.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
]]></description><guid isPermaLink="false">114797</guid><pubDate>Mon, 02 Mar 2026 23:12:11 +0000</pubDate></item><item><title>Umbrella Photos</title><link>https://www.wheelhorseforum.com/topic/114791-umbrella-photos/</link><description><![CDATA[<p>
	Following up on my post yesterday. Found the umbrella. Really nice condition. Don’t believe I ever opened it before. From the mid 1980’s, a gift from Wheelhorse. My office was in their HQ but I worked for the finance company who floorplanned all their dealers. Not looking to sell it but if and when will certainly offer it here. Great forum! Still using my 1996 314-H. The Best Buy ever!  Got one before Toro tossed the quality units out the door.
</p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_7526.jpeg.db491c76d78a865021003b064505cdef.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="465267" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_7526.jpeg.db491c76d78a865021003b064505cdef.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="IMG_7526.jpeg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_7525.jpeg.345342bfc4b423a339aafe609b424d74.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="465268" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_7525.jpeg.345342bfc4b423a339aafe609b424d74.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="IMG_7525.jpeg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_7528.jpeg.9494af5f6d3f8f372ca9a25b023cb64b.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="465269" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_7528.jpeg.9494af5f6d3f8f372ca9a25b023cb64b.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="IMG_7528.jpeg"></a></p>
<p><a href="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_7527.jpeg.e18af619fe916798f5df643543a1ee83.jpeg" class="ipsAttachLink ipsAttachLink_image"><img data-fileid="465270" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_03/IMG_7527.jpeg.e18af619fe916798f5df643543a1ee83.jpeg" data-ratio="133.33" width="576" class="ipsImage ipsImage_thumbnailed" alt="IMG_7527.jpeg"></a></p>]]></description><guid isPermaLink="false">114791</guid><pubDate>Mon, 02 Mar 2026 16:08:09 +0000</pubDate></item><item><title>Wheelhorse Umbrella</title><link>https://www.wheelhorseforum.com/topic/114787-wheelhorse-umbrella/</link><description><![CDATA[<p>
	Wondering if anyone out there has one or has seen one. Just remembered getting one when I worked inside the South Bend HQ in the mid 1980’s. Don’t recall who gave it to me but pretty sure it was a gift. Will post a photo when I get my hands on it this week. Don’t recall it ever being used or even opened up for that matter.
</p>
]]></description><guid isPermaLink="false">114787</guid><pubDate>Mon, 02 Mar 2026 00:18:42 +0000</pubDate></item><item><title>Ritchie Digital Torque Wrench</title><link>https://www.wheelhorseforum.com/topic/114751-ritchie-digital-torque-wrench/</link><description><![CDATA[<p>
	No relation to <a contenteditable="false" data-ipshover="" data-ipshover-target="https://www.wheelhorseforum.com/profile/9187-19richie66/?do=hovercard" data-mentionid="9187" href="https://www.wheelhorseforum.com/profile/9187-19richie66/" rel="">@19richie66</a> I'm sure but every time I use it I think of him. <img alt=":lol:" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/default_laugh.png" title=":lol:" />
</p>
<p>
	It was FREE from a wholesaler for selling mini split air conditioners. Thought what good is it with a stupid metric crescent wrench head in our line of work.
</p>
<p>
	Supposed to be used for torqueing flare nuts for proper install of aforementioned ACs.
</p>
<p>
	'Till I found they offer a 3/8 ratchet head.
</p>
<p>
	Found in the jungle no less.
</p>
<p>
	Bad news it only goes to 60 ft lbs but still. Measures in inch lbs as well. <img class="ipsImage ipsImage_thumbnailed" data-fileid="464899" data-ratio="100.00" width="768" alt="20260225_100428.jpg.220597af3b4a1fc2637858412711580f.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_02/20260225_100428.jpg.220597af3b4a1fc2637858412711580f.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" /><img class="ipsImage ipsImage_thumbnailed" data-fileid="464900" data-ratio="100.00" width="768" alt="20260225_100446.jpg.a697f8575e65ab17c4bb994779127848.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_02/20260225_100446.jpg.a697f8575e65ab17c4bb994779127848.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" /><img class="ipsImage ipsImage_thumbnailed" data-fileid="464902" data-ratio="100.00" width="768" alt="20260225_100524.jpg.98df8712281e06b30620dedee4ee54e7.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_02/20260225_100524.jpg.98df8712281e06b30620dedee4ee54e7.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	Has a visual &amp; tone when torque setting is reached.
</p>
<p>
	<img class="ipsImage ipsImage_thumbnailed" data-fileid="464903" data-ratio="100.00" width="768" alt="20260225_100953.jpg.6331b31127075c34e57930459a981dc5.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_02/20260225_100953.jpg.6331b31127075c34e57930459a981dc5.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
	Very handy for rod caps on a Clinton. <img alt=":)" data-emoticon="" src="https://www.wheelhorseforum.com/uploads/emoticons/default_smile.png" title=":)" /><img class="ipsImage ipsImage_thumbnailed" data-fileid="464904" data-ratio="100.00" width="768" alt="20260225_102950.jpg.2b2f0082803aa0bf76877f6f0c599bfa.jpg" data-src="https://www.wheelhorseforum.com/uploads/monthly_2026_02/20260225_102950.jpg.2b2f0082803aa0bf76877f6f0c599bfa.jpg" src="https://www.wheelhorseforum.com/applications/core/interface/js/spacer.png" />
</p>
<p>
</p>
<p>
</p>
<p>
</p>
]]></description><guid isPermaLink="false">114751</guid><pubDate>Wed, 25 Feb 2026 16:31:08 +0000</pubDate></item></channel></rss>
