Switch Ball safety 105877.jpg 1.0.0
2 Screenshots
Clutch pedal and neutral switch taken from #492-4207 Electrical Service Manual
105877 replaced by 38-0430 Ball switch NO=Normally open - Nail head terminals for a slide on Packard connector. Some illustrations show a switch with flat spade terminals.
Used on
1976 C-120 Automatic model 61-12KS03 - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed. - This is the last model of C-120 Auto produced in 1976
1976 C-160 Automatic model 61-16KS03 - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed. - This is the last model of C-160 Auto produced in 1976
1977 C-Series 8-Speed models for pto switch and clutch pedal switch
1977 B-60 8-Speed model 71-07K801 - 105877 replaced by 38-0430 for neutral switch and pto switch - Have IPL
1977 B-80 8-Speed model 71-08K801 - 105877 replaced by 38-0430 for neutral switch and pto switch - Have IPL
1977 B-100 8-Speed model 71-10K801 - 105877 replaced by 38-0430 for neutral switch and pto switch - Have IPL (Also made in Belgium)
1977 C-80 4-Speed model 71-08K4 (Found in Europe with serials 158039 159837 made in Belgium)
1977 C-100 8-Speed model 71-10K8 (Found in Europe with serials 155729 155758 made in Belgium)
1977 C-120 8-Speed model 71-12K801 - 105877 replaced by 38-0430 for neutral switch and pto switch - Have IPL
1977 C-140 8-Speed model 71-14K8 - Made in Belgium
1977 C-160 8-Speed model 71-16K801 - 105877 replaced by 38-0430 for neutral switch and pto switch - Have IPL
1977 C-160 8-Speed model 71-16K802 - 105877 replaced by 38-0430 for neutral switch and pto switch - Have IPL
1977 C-120 Automatic model 71-12KS01 - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed. [Have OM TIPL Wiring]
1977 C-120 Automatic model 71-12KS02 - 105877 replaced by 38-0430 for neutral switch and pto switch [IPL from Parts Tree only Have OM Wiring]
1977 C-160 Automatic model 71-16KS02 - 105877 replaced by 38-0430 for neutral switch and pto switch [Have OM TIPL Wiring]
1978 C-Series 8-Speed models for clutch pedal
1978 C-81 8-Speed model 81-08K801 [Have TIPL Wiring]
1978 C-101 8-Speed model 81-10K801 [Have TIPL Wiring]
1978 C-121 8-Speed model 81-12K801 [Have TIPL Wiring] (One found made in Belgium)
1978 C-121 Automatic model 81-12KS01 [Have TIPL Wiring]
1978 C-141 8-Speed model 81-14K801 [Have TIPL Wiring] (Two found made in Belgium)
1978 C-141 Automatic model 81-14KS01 [Have TIPL Wiring]
1978 C-161 8-Speed model 81-16K801 [Have TIPL Wiring]
1978 C-161 Automatic model 81-16KS01 [Have TIPL Wiring]
1978 C-161 Twin 8-Speed model 81-16B801 [Have TIPL Wiring]
1978 C-161 Twin Automatic model 81-16BS01 [Have TIPL Wiring]
1978 D-160 Automatic model 81-16OS01 [Have TIPL Wiring]
1978 D-200 Automatic model 81-20KS01 [Have TIPL Wiring]
1978 D-250 10-Speed model 81-20RG01 [Have SM TIPL Wiring]
1979 C-Series 8-Speed models for clutch pedal
1980 C-Series 8-Speed models for clutch pedal
1981 C-Series 8-Speed models for clutch pedal
1982 SB-421 model 01-11BH01 8-Speed - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed. - Controls isolation relay
1982 SK-486 model 01-16KH01 - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed.
Plastic 2-wire slide-on connector 106024 less terminals used in 1977 nla (1980-1981 used 2 of 106771 slide-on connector bodies still available from Toro)
9/16-18 threads on 102277 mounting nut
