Switch Push button 104680.jpg 1.0.0
9 Screenshots
Taken from #492-4207 Electrical Service Manual
104680 Push button pto switch or switch pto with 4 terminals to control ignition and starter solenoid. One pair of terminals NO=Normally open. One pair of terminals NC=Normally closed.
Models using this switch also have a seat switch.
Photo of 105303 plastic wiring connector supplied by hondagod64
Used on
1975 B-Series use 104681 U-shaped spring to contact the pto switch button.
1975 D-Series use 104681 U-shaped spring to contact the pto switch button. Listed on the pto clutch parts list but not in the illustration of the original ipl
1975-1976 C-Series use 104681 U-shaped spring to contact the pto switch button.
1978 D-200 Automatic uses 104681 U-shaped spring to contact the pto switch button.
1977-1981 C-Series use 105873 flat spring to contact the pto switch button.
1980-1981 B-Series.
1982 SK-486 use 105873 flat spring to contact the pto switch button.
Note - The following applications are a work in progress and some are not accurate.
1975 B-80 4-Speed model 1-0141 (Original ipl)
1975 B-100 Automatic model 1-0511 (Original ipl)
1975 C-100 4-Speed model 1-0394 (Original ipl)
1975 C-100 8-Speed model 1-0391 (Original ipl)
1975 C-120 8-Speed model 1-0357 - uses Tecumseh HH120-120180D - No wiring diagram available - Uses 103991 magneto ignition switch and 104075 10 amp regulator
1975 C-120 8-Speed model 1-0375 - uses Tecumseh HH120-120180E - No wiring diagram available - Uses 103991 magneto ignition switch and 104816 20 amp regulator and 104704 wiring harness
1975 C-120 8-Speed model 1-0395 - uses Kohler K301S-47421d (Original ipl)
1975 C-120 8-Speed model 1-0396 - uses Kohler K301S-47421d
1975 C-120 Automatic model 1-0491 (Original ipl)
1975 C-160 8-Speed model 1-0381 (Original ipl)
1975 C-160 Automatic model 1-0481 (Original ipl)
1975 D-160 Automatic model 1-0651 - Listed on the pto clutch parts list but not in the illustration of the original ipl
1975 D-180 Automatic model 1-0612 - Listed on the pto clutch parts list but not in the illustration of the original ipl
1975 D-200 Automatic model 1-0631 - Listed on the pto clutch parts list but not in the illustration of the original ipl
1976 B-60 8-Speed model 61-07K801 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 B-60 8-Speed model 61-07K802 - 101845 or 105877 replaced by 38-0430 for the clutch and 104680 for pto listed on TIPL
1976 B-80 8-Speed model 61-08K801 - 101845 for clutch pedal and 104680 for pto listed on TIPL - Incorrectly named a B-60 @ Toro
1976 B-80 8-Speed model 61-08K802 - 101845 for clutch pedal and 104680 for pto listed on TIPL - Incorrectly named a B-60 @ Toro
1976 B-80 8-Speed model 61-08K803 - 101845 or 105877 replaced by 38-0430 for the clutch and 104680 for pto listed on TIPL
1976 B-80 8-Speed model 61-08K804 - 101845 for clutch pedal and 104680 for pto listed on TIPL - Incorrectly named a B-60 @ Toro
1976 B-100 8-Speed model 61-10K801 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 B-100 8-Speed model 61-10K802 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 B-100 8-Speed model 61-10K803 - 101845 or 105877 replaced by 38-0430 for the clutch and 104680 for pto listed on TIPL
1976 B-100 8-Speed model 61-10K804 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 C-120 8-Speed model 61-12K801 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 C-120 8-Speed model 61-12K802 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 C-120 8-Speed model 61-12K803 - 101845 or 105877 replaced by 38-0430 for the clutch and 104680 for pto listed on TIPL
1976 C-120 8-Speed model 61-12K804 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 C-120 Automatic model 61-12KS01 - 101845 for neutral and 104680 for pto listed on TIPL
1976 C-120 Automatic model 61-12KS02 - 101845 for neutral and 104680 for pto listed on TIPL
1976 C-120 Automatic model 61-12KS03 - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed.
1976 C-120 Automatic model 61-12KS04 - 101845 for neutral and 104680 for pto listed on TIPL
1976 C-140 8-Speed model 61-14K8       (Found in Europe with serial 151811 made in Belgium
1976 C-160 8-Speed model 61-16K801 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 C-160 8-Speed model 61-16K802 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 C-160 8-Speed model 61-16K803 - 101845 or 105877 replaced by 38-0430 for the clutch and 104680 for pto listed on TIPL
1976 C-160 8-Speed model 61-16K804 - 101845 for clutch pedal and 104680 for pto listed on TIPL
1976 C-160 Automatic model 61-16KS01 - 101845 for neutral and 104680 for pto listed on TIPL
1976 C-160 Automatic model 61-16KS02 - 101845 for neutral and 104680 for pto listed on TIPL
1976 C-160 Automatic model 61-16KS03 - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed.
1976 C-160 Automatic model 61-16KS04 - 101845 for neutral and 104680 for pto listed on TIPL
1976 D-160 Automatic model 61-16OS01 - 101845 for neutral and 104680 for pto listed on TIPL
1976 D-160 Automatic model 61-16OS02 - 101845 for neutral and 104680 for pto listed only at Parts Tress - Have OM (TIPL not available)
1976 D-200 Automatic model 61-20KS01 - 101845 for neutral and 104680 for pto listed on TIPL
1976 D-200 Automatic model 61-20KS02 - 101845 for neutral and 104680 for pto listed only at Parts Tress - Have OM (TIPL not available)
1977 C-120 Automatic model 71-12KS01 - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed. [Have OM TIPL Wiring]
1977 C-160 Automatic model 71-16KS01 - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed. [Have OM TIPL Wiring]
1977 D-160 Automatic model 71-16OS01 - 101845 for neutral and 104680 for pto listed on TIPL
1977 D-200 Automatic model 71-20KS01 - 101845 for neutral and 104680 for pto listed on TIPL
1978 model 81-08K801 C-81 8-Speed Tractor *****
1978 model 81-10K801 C-101 8-Speed Tractor
1978 model 81-12K801 C-121 8-Speed Tractor - (One found made in Belgium)
1978 model 81-12KS01 C-121 Automatic Tractor
1978 model 81-14K801 C-141 8-Speed Tractor - (Two found made in Belgium)
1978 model 81-14KS01 C-141 Automatic Tractor
1978 model 81-16K801 C-161 8-Speed Tractor
1978 model 81-16KS01 C-161 Automatic Tractor
1978 model 81-16B801 C-161 Twin 8-Speed Tractor - (Controls ignition isolation relay)
1978 model 81-16BS01 C-161 Twin Automatic Tractor - (Controls ignition isolation relay)
1978 model 81-20KS01 D-200 Automatic Tractor
1979 model 91-08K801 C-81 8-Speed Tractor
1979 model 91-08K802 C-81 8-Speed Tractor
1979 model 91-08K891 C-81 8-Speed Tractor - (One made in Belgium with serial 163175)
1979 model 91-10K801 C-101 8-Speed Tractor
1979 model 91-10K802 C-101 8-Speed Tractor
1979 model 91-10K892 C-101 8-Speed Tractor - (One made in Belgium with serial 183695)
1979 model 91-11B801 C-111 8-Speed Tractor - (Controls ignition isolation relay)
1979 C-121 8-Speed model 91-12K801 [Have D&A TIPL Wiring detailed] (Two found made in Belgium)
1979 C-121 8-Speed model 91-12K802 [Have D&A OM IPL Wiring detailed]
1979 C-121 8-Speed model 91-12K891 (Made in Belgium with serials 167136 169593)
1979 C-121 8-Speed model 91-12K892 [Have D&A OM IPL Wiring detailed] - Belgium built with serial 184568
1979 C-121 Automatic model 91-12KS01 *+w
1979 C-121 Automatic model 91-12KS91 (Made in Belgium with serial 16?329)
1979 C-141 8-Speed model 91-14K801 *+w
1979 C-141 8-Speed model 91-14K802 *+w
1979 C-141 Automatic model 91-14KS01 *+w
1979 C-161 8-Speed model 91-16K801 *+w
1979 C-161 Automatic model 91-16KS01 *+w (One found in Holland Made in Belgium)
1979 C-161 Automatic model 91-16KS91 Made in Belgium serial 167284
1979 C-161 Twin 8-Speed model 91-16B801 *
1979 C-161 Twin 8-Speed model 91-16B802 *
1979 C-161 Twin Automatic model 91-16BS01 *
1979 C-161 Twin Automatic model 91-16BS02 *
1979 C-171 A model that was not built
1979 D-160 Automatic model 91-16OS01 *
1979 D-160 Automatic model 91-16OS02 - Not listed @ Toro and may be an invalid model number
1979 D-200 Automatic model 91-20KS01 *
1979 D-200 Automatic model 91-20KS02 *
1980 model 01-08K801 C-85 8-Speed Tractor - C-81 at Toro
1980 model 01-10K801 C-105 8-Speed Tractor
1980 model 01-11B803 1100 Special Tractor - Controls isolation relay
1980 model 01-12K801 C-125 8-Speed Tractor
1980 model 01-12KE01 C-125 Automatic Tractor
1980 model 01-12KS01 C-125 Automatic Tractor
1980 model 01-14K801 C-145 8-Speed Tractor
1980 model 01-14KE01 C-145 Automatic Tractor
1980 model 01-14KS01 C-145 Automatic Tractor
1980 model 01-16K801 C-165 8-Speed Tractor
1980 model 01-16KE01 C-165 Automatic Tractor
1980 model 01-16KS01 C-165 Automatic Tractor
1980 model 01-17K801 C-175 Twin 8-Speed Tractor
1980 model 01-17KE01 C-175 Twin Automatic Tractor
1980 model 01-17KS02 C-175 Twin Automatic Tractor
1980 model 02-08BP01 B-82 3-Speed Tractor - Controls isolation relay
1981 model 01-08K802 C-85 8-Speed Tractor - C-81 at Toro
1981 model 01-10K802 C-105 8-Speed Tractor
1981 model 01-11B804 GT-2500 8-Speed Tractor - Controls isolation relay
1981 model 01-12K802 C-125 8-Speed Tractor
1981 model 01-12KE02 C-125 Automatic Tractor
1981 model 01-14K802 C-145 8-Speed Tractor
1981 model 01-14KE02 C-145 Automatic Tractor
1981 model 01-16K802 C-165 8-Speed Tractor
1981 model 01-16KE02 C-165 Automatic Tractor
1981 model 01-17K802 C-175 Twin 8-Speed Tractor
1981 model 01-17KE01 C-175 Twin Automatic Tractor
1981 model 02-08BP02 B-82 3-Speed Tractor - Controls isolation relay
1982 SB-421 model 01-11BH01 8-Speed - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed. - Controls isolation relay
1982 SK-486 model 01-16KH01 8-Speed - 105877 replaced by 38-0430 for neutral switch and 104680 for pto only listed on TIPL. 101845 is not listed.
  • Excellent 1
