Transmission Gear Uni-drive 8-speed 1.125in axle 8-pinion 103918 1980-1983 IPL.pdf
Model 103918
1-1/8" axle (Uses 2 105875 axles 13" long and 937108 Woodruff #22 keys - 1/4" x 1-3/8")
8 one-piece pinion differential eight-speed
4 pages 358.32KB
Used 1980-1983 in E-141 8-speed model 01-14E801
