Transmission Gear Uni-drive 3-speed 1.125in axle 2-pinion 5058 1967 IPL.pdf
Model 5058
2 beveled pinion gears three-speed
2 pages 349.75KB
3-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section II of the service manual.
Believe the 5080 on this ipl is incorrect and should be 5058. The 5080 uses spur pinion gears.
5058 transmission used in
1967 model 1057
1967 model 1257
