  • Please Read
  • Kohler Engine Rebuilding
    richmondred01
    • Active
      Price: 295
    I will rebuild your K181, K241, K301, K321 and K341 cast iron kohler engine for 295.00 plus parts and machine work if required. In most cases cylinder will be bored, crank will be ground, valve seats ground or reconditioned. New piston, new rings, new rod, valves new or reconditioned, all new seals and gaskets. Entire engine brought back to factory spec. I no longer do performance/pulling engines or twins.
    If your old Kohler is knocking or smoking it's most likely time for a rebuild before it locks up on you. Once rebuilt, and properly maintained, it will give you another 30-40 years of service.
    I don't cut corners, I take my time and get it right. 40 plus years of working on and rebuilding k series engines. You won't be disappointed.
    PM me with any questions.
    • Excellent 7
    User Feedback
    Brockport Bill
    Posted
    are you able to provide a range of $ the typical rebuild costs including the other costs typical for an engine beyond the 295 you indicate when adding typical parts, machining etc - - not a quote .... but just a typical total range of costs? eg: for Kohler magnum 12 --- thanks
    Share this comment
    Link to comment
    rjg854
    Posted
    I can attest to his quality of rebuilds I've got a 16 horse Kohler he rebuilt and still running strong after 3 years.:text-bravo:
    • Excellent 2
    Share this comment
    Link to comment
    richmondred01
    Posted
    send me a pm with a phone number.
    There may be several variables associated and I’m not the fastest typist
    Share this comment
    Link to comment
    He has rebuilt two motors for me.  His workmanship is second to none. Quality work all the way.
    Share this comment
    Link to comment
    richmondred01
    Posted
    Thanks
    Share this comment
    Link to comment
    SmileySmithC101
    Posted
    How much do you think shipping would be to get my engine to you ?
    Share this comment
    Link to comment
    richmondred01
    Posted
    26 minutes ago, clueless said:
    do you have a k341 short block?
    No, sorry I can’t keep the k341’s on the shelf. All the pullers want them and they have been sucking up the inventory.
    Share this comment
    Link to comment
    Searching for a K181 cam or someone who can weld and grind one. Thanks for any help you may give.
    Share this comment
    Link to comment
    richmondred01
    Posted
    6 hours ago, Osk said:
    Any chance of getting my K91 rebuilt?
    Pm sent
    Share this comment
    Link to comment
    Martin805
    Posted
    Are you still rebuilding engines? I have a K321 I need rebuilt. Thanks!
    Share this comment
    Link to comment
    richmondred01
    Posted (edited)
    Yes.  Pm sent
    Edited by richmondred01
    Share this comment
    Link to comment
