buckrancher
brian's 854 complete rebuild
bell
Looking GREAT Brian!
:thumbs2:
TJ
Thanks for posting your progress. Great job. :thumbs2:
buckrancher
Got the starter generator sand blasted and tore apart .The bearing was bad
on the pulley end
So I cleaned out the carbon dust and checked all the contections and
brushes also cleaned the commutator with a scotch-brite pad replaced both bearings and painted
nylyon
Very nice and complete job you're doing. I love write-up's like these, they're so great to read.
Stigian
WOW... your doing a fantastic job there Brian :thumbs2:
buckrancher
Thank you all for your kind comments
I'am hoping all the motor parts arrive soon looking forward to hearing her run
sodbuster
the hardest thing about painting,is just do it!! the body work is the hard part!! painting candy,or multi stage is a little more complicated.if this is your first go? it looks good!!
buckrancher
I got my new 3" ball flex hone the other day so I honed the cylinder :thumbs2:
still have not recieved all the motor parts yet
new clutch brake rod and front axle pivot pin out of stainless
piecrazy4
Great job on the restore !
perry
now thats a complete rebuild :thumbs2:
sorekiwi
Really nice job, Brian. :thumbs2:
One question about the stainless pivot pin... I've pulled about 6 front axles out of Wheelhorse tractors, and on all but one, the pin has been badly worn, but the bore in the axle has been ok. I figure that the soft mild steel pin is kind of sacrificial to save the bore in the axle. Do you think the stainless might be a little hard? :thumbs:
buckrancher
Yes it might be but as this tractor going to be a trailer queen
it should not be a problem as long as it's greased well
If I was going to use this tractor I would install bronze bushing's in the axle pivot point with the stainless pin :ychain:
buckrancher
Motor parts came in saturday so I started reassembly this week
lapping in the new valve's. Both seats were in great shape and didn't need cutting
Both valve's lapped
checking piston ring end clearance
governor, camshaft , lifter tappit's new crank bearing's ,crankshaft and side plate
installed. Crankshaft was adjusted for side clearance with gasket and one shim
ready to install new piston and rod
Piston and rod in needs end cap installed and torqued
grinding valve stem for end clearance
Installing valve's
Engine ready to prep for paint
All Primed :thumbs:
:thumbs2:
TT
Excellent work, Brian.
You did remember to lube the heck out of the cam pin, didn't you?
(I'm just reminiscing about a guy I know who assembled the cam dry in a big block K and about 45 seconds into the first run the cam seized on the pin, stuff broke, and lots of pieces ended up in the oil pan. :thumbs2: )
Although not quite as elaborate as your overhaul, I had a post going over a year ago when my son & I were "freshening up" a K-161. Funny thing is - it's still sitting on the workbench and it's still not finished. :thumbs:
LINK to my old post.
buckrancher
Hey TT
yes I did I filled a new glue syringe with 10-30 and injected it in the oil holes
on the cam until it came out the ends
:ychain:
Suburban 550
Awesome job, Brian. :thumbs: A picture perfect restoration. :thumbs2:
buckrancher
Since I'am going to use a stainless steel steering shaft and tie rods
I thought a stainless lower steering shaft would be cool too :hide:
:scratchead:
HorseFixer
Looks Great Brian! :scratchead:
MikesRJ
SWEET! :scratchead:
mnWHfan
Brian,
You're doing a fantastic job. I just finished doing a C161 Automatic last year that I took to a similar level. I worked on it after hours at work and even drew about 80% of it into my 3D CAD system. It's fun to use the tools that you have access to.
Dennis :scratchead:
bitten
Brian Looks as though you arent messing around on this rebuild. cant wait to see the finished prodect.
buckrancher
Finally got the engine painted and reassembled all I'm lacking
is the decal for the air cleaner which is on back order
I fabricated some new parts out of stainless :ychain:
throttle rod, fuel line , generator bracket , dipstick
:hide:
:scratchead:
Suburban 550
Can't wait to see it all finished. :hide: Wish I could have spent more time talking horses at the NAMA show on Saturday but I had somewhere I had to be. Maybe next time. :scratchead:
mnWHfan
Brian,
That is a good looking engine.
Dennis :scratchead:
bell
WOW!!!!
LOVE the attention to detail! :scratchead:
