rondo 0 #1 Posted May 30, 2009 Question or two on belt replacement. I have the deck lid off, the pullies are exposed and everything seems clean and tight. From what I can see, the idler pulley is fixed. Though there is a spring on an apparent swing arm, the arm is bolted to the deck. Don't know if this is normal or not but when I go to replace the belt, which was broken, is there supposed to be an adjustment on the idler pulley to allow the belt to be placed over all of the pullies and then tightened? Also, the belt seems to be 76" X 3/8", though I'm not sure how much stretch there's been. Does this sound like the right size? By the way, this deck is on my B-100 ('74). Thanks folks. Share this post Link to post Share on other sites
