Irv
GATOR BLADES
Irv
Anyone know where I can get gator blades for a 42" sd deck? thanks
Duff
...and once you've got 'em, it'll spoil you for just about every other blade out there. I'm running them on three tractors now (two non-WH, unfortunately), mowing about 4 acres every 5-6 days, and they are amazing! Seem to hold an edge better than most, too! :drool:
(The preceding is NOT a paid advertisement!)
Duff :omg:
munsonRN
How about for a 42" RD deck? I've looked at a few different places but can't seem to find them. Thoughts?
MaineDad
It's my understanding that they are not available for the RD decks. Correct? If so, I'm buying a set too!
Duff
Guys, if you can get me the measurements from one of your 42" RD blades I'll do some digging around. There are a couple of suppliers who have huge inventories of these blades for a whole range of mowers and somewhere there's got be a close enough match to work.
I'll need the length and as exactly as you can get it (within 1/64th), the diameter of the center hole (are they round, "D" or "double "D" shaped?).
Since I don't know anything about these decks, how much clearance is there between the upper surface of the blade and the underside of the deck shell? Gator blades do have a pretty radical upsweep at the ends where the mulching tips are located!
Duff :omg:
GlenPettit
No difference in the three Gator blades for a 42" RD or SD deck.
munsonRN
Hmm.
I've looked at many different webpages and can't seem to find them.
The following are the specs from one of the web pages.
Blade Length 14-1/2" (36.8cm)
Blade Width 2" (5.1cm)
Blade Thickness .203" (5.15mm)
Center Hole Diameter 3/4" (19mm) (ROUND)
I will have to measure the distance from the deck to blade as I am unsure as I sit here at work.
04fxdwgi
Hmm.
I see what you mean. That size doesn't fit ANY mower manufacturer for a Gator blade.
KyBlue
I've got a set on my 36" RD Deck...really wonder if they didnt put a set on from a SD Deck, thou the TORO MPV lists two different sets of blades for the SD and RD decks..
d180man
Hi if you have a part # we can get them if they still make them or we can get some like Gator blades but thanks have a nice day! :omg:
munsonRN
The wheelhorse/toro model # is 106635. Three are used to fit the deck.
gwgdog66
Irv
Toro parts viewer lists same blades for 42" sd or rd deck. Gator part # is 90643. The Gator blades are sold individually.
munsonRN
http://www.jackssmallengines.com/gatToro.cfm
The specs on that blade are different than the specs for the 42" RD. The blade for the RD is 14 1/2 inches and that spec says 13 27/32.
Hmmmm...
GlenPettit
Re: Having two blades on each spindle, loosening.
The nuts do not loosen, but the blades may not always stay at 90
Jedakiego
Hmmmm...
I have a 42 inch RD that I am rebuilding from rust holes and a 42 inch SD that I use on the lawn. There are deffinatley 2 different blades. If you put the 14 1/2 inch blades from the RD on the SD they hit each other.
