russellmc301
adding lift cable to tractor
russellmc301
i have a slot hitch plow and cultivator for my suburban. my suburban is all restored and pretty, so i dont want to take it out and get it all dirty. i have a 14hp no name with the cable sleve but no cable in it. is there a way i could add a cable or a way to lift my plow up? thanks
JAinVA
If your machine has the cable sleeve you can push a new cable into it.The cable is available from a vendor here and has a round button squeezed on the end so that it can pushed through the tube.If machine has some age to it run a coat hanger wire through first.If dirt comes out then flush the tube with water from a squeeze bottle.Mud daubers like to clog up the tube for their nests.You will also need a rock shaft to attach the cable to at the rear of the machine.This is also available from the mentioned vendor,Wheel Horse Parts and more.
Edited by JAinVA
squonk
russellmc301
ok great thanks alot
Blackhood Bill
Yes that really helped me also. Thanks for posting pretty clear pictures.
