DerrickH
312-8 Headlights
DerrickH
Still learning about my WH 312-8. Where do i start looking to figure out how to get headlights to work without buying new lights right away?
Jerry77
   First, check the fuse...if good..  with the headlight switch on,  jump across the headlight switch. if they don't work, then ohm the headlights themselves..if you get a dead short it is time to check out the wiring...:twocents-02cents:
pfrederi
What is the model number of you 312-8 (Should be on a sticker under the seat.  Some 312-8s had head lights that ran off the AC stator on the engine not the battery,  Those lights would only work when the engine was running.
WHX??
:text-yeahthat:some of my newer verticals are like that. Get us your model and we'll see about getting you a manual/wiring diagram.
While your at the fuses check the socket. often times they get corroded. If you have a multimeter or even a simple tester check for power at the light and work backwards down the wiring to you find 12 volts. If you don't have a simple tester get one.  Handy for other automotive stuff too.
:WRS:
DerrickH
Thanks fellas! model # 3112K804
gwest_ca
Click on the picture
Garry
peter lena
@DerrickH  while I  agree with others on ideas , mine is to move wire connections , like dielectric  grease  to enhance connections , enhance grounding , don,t count on original ground areas , typically rusty / paint / corrosion . like alligator wire clip test wires , to jump over  areas . connected most of my grounding directly to battery ground bolt / cable point . test / check as you go . pete
  • Similar Content
    • 87 416-8 horse
      By 87 416-8 horse
      I’m looking for wheel horse tractors for sale or for parts in the Eastern Nebraska or western Iowa area. Preferably 8 speed manuals. Pm me or comment with what you have. The worst I could say is it’s out of my price or distance range.
      Thanks,
      John
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor! Starts right up and Runs and Cuts like a Champ!
      ONLY 419hrs
      FEATURES:
      Newer Agro Tires on Rear & Solid Front Turf Tires.
      Wheel Weights on rear.
      Fully Swapped Forward Swept axle and Steering off of 520h.
      New Tractor Supply Adjustable Seat.
      Exhaust Fully Restored. (Sandblasted, Outgassed and 2000deg High Temp Satin Exhaust Paint Coated.)
       I ran my 60" Deck on this tractor for over a year with no issues.
      Deck it solid top to bottom with no rot and newer blades. Belt and Pulley are good to go!
      She's just a little dusty and needs a cleaning. Can get a nice Seat a Tractor Supply.
      Asking >>>>> $1,099 OBO <<<<<<<
      (248) 943-8634 Text or Call.  God Bless.
    • tallen4392
      By tallen4392
      looking for rear weights  12 inch  close to 01077 zip maybe fits also let me know what you have  Thanks
    • Duramax7man7
      By Duramax7man7
      Very Solid tractor!
      Newer Agro Tires on Rear and Solid Front Turf Tires. Wheel Weights on rear. Fully Swapped Forward Swept axle off of 520h. I ran my 60" Deck on this tractor for over a year with no issues.
      $1175 OBO   -POOS
      (248) 9for3-8six3four Text or Call. I do not visit this site enough. God Bless.
      NEW SEAT INSTALLED ON THIS TRACTOR! Started it up and ran it for a while yesterday... Forgot how nice this thing is. Tempting to keep it but it's time to send her one her way. GREAT TRACTOR!
    • Little Red Horse
      By Little Red Horse
      I am selling a 1970 Wheel Horse Electro 12. It is in *working condition*.
      It has AG tires and a mid-mount blade from wheel horse.
      It also has a front mounted generator that currently doesnt put out power. It has been in the barn quite a while, so it may be a corroded connection,  not sure. Although there's not too much that goes wrong with them.
      The tractor has been a great one for me. The last 6ish 7ish years that I've had it where I lived it brought the gravel back up my driveway for me every time it rained. In the last few months, it would run for 20-30min then die.
      I was moving at the time so just didn't have the time to look at it. And it seems I still don't. Where I am currently I don't have a place for it. I don't want it setting out and deteriorating. So here we are.
      Please contact me by text or email.
      Thanks for looking!
