Uncle Buck 246 #1 Posted August 10, 2018 (edited) I have front wheels with an original rim size of 5.50 x 8 with a turf type tire mounted to it. I want to use either a 3.50, or a 4.0 x 8 tri rib with tube on this rim. Will either one fit and work well? I use this tractor with a blade, rear weights and chains for clearing snow. I like the narrower looking tri ribs on the front, but suspect that to get that look I will need narrower rims to start with. I will settle for the wide tire "bloated look" if I must as long as the tires will fit this rim. Edited August 10, 2018 by Uncle Buck 1 Share this post Link to post Share on other sites
Achto 26,554 #2 Posted August 10, 2018 (edited) Here is a pic of the DeeStone 4.00 x 8's on my 1076. I used the stock rims which had 5.50x 8's on them. Edited August 10, 2018 by Achto 5 Share this post Link to post Share on other sites
Uncle Buck 246 #3 Posted August 10, 2018 Thank you! That tells me what I need to know! Looks great. I am going to do the same thing for mine! 4 x 8 it is then! 2 Share this post Link to post Share on other sites
