CasualObserver
My new shop
Sparky
WOW! And WOW again!
  Gorgeous shop! Great write up on how it all progressed.
  How ya gonna feel when some old rusty relic looses all its tranny fluid on that beautiful floor!?
  • Haha 2
Ed Kennell
I'll add another   WOW.
Thanks for the show Jason.
Marv
Darn, Too small already!
Great job. I love it.
Marv
WHX??
Nice Jason ...real nice :handgestures-thumbupright: Thanks  for the :text-coolphotos:.
What is that about 22 x 32?? Couple of things I like and a couple I woulda done different. The lighting is real nice and what's not to like about infloor!!  Go with a tankless to run it, that's what we use. Any chance you put a floor drain in by the tubes for a drain for a high eff. one? Here there is no requirement for pressure testing the loops but we do anyway. Had an unruly concrete dude stick a shovel in one once and a run with a hole in in from factory. I woulda spaces the tubes a little closer. Then you can run lower water temps thus less gas use. For a shop it's probably not a big deal tho.
Is that a pull down stairs for stowing horse parts in the attic??
I woulda had the big door an eight footer. looks like you had the head room.
Now the real work begins tho....getting it set up the way you like. Air compressor & piping, sound system, wall art, stocked fridge...cot for when in the dog house.....:ychain:
  • Like 4
dclarke
Really nice, Jason!  Thanks for all the pics and the great write up.
Shynon
Been there seen it, this shop Rocks. Looking good Jason:handgestures-thumbupright:
elcamino/wheelhorse
What a shop , love it. Don't see the floor covered in :wh:.
CasualObserver
24x36 can't believe I forgot to mention size!:blink:
It will be. Gotta wait a little while to afford that. Ceiling was supposed to be 10'  but I got 10' 6". Lower cost ladders stop at 10' 3".:unsure:
Yep... Plumbed in a condensate drain right next to the pex stubs. It ties into the floor drain. :thumbs:
  • Like 4
  • Excellent 2
SylvanLakeWH
:bow-blue:
953 nut
:text-coolphotos:             Jim took the words out of my mouth, too much floor showing,   need more :wh:.
CasualObserver
Just fine since it will soak right up with some oildry and not leave a stain!
WHX??
Exactly the same size  as my heated  shop ... which is way too smal! Oh well we'll make do. If you like I can pm you on some infloor suggestions. Let me know you need help in that department. Personally  I would not have done infloor in a building  such as this. Once you fill it and lite it off it's like marriage. ....your committed to keep it running.
Daddy Don
I want it!!!!!!! Nice
Terry M
Very Nice Shop , Jason !!!!  :):handgestures-thumbupright:
RandyLittrell
Wish I could redo mine to look like yours!!!!
Randy
r356c
Careful planning, solid execution, beautiful results!
The differences between Northern and Southern construction techniques are interesting.
Pex in-floor heating in the South? No.
Trusses rated for snow load rather than wind load... Hmmm... I've been told such a thing exists.
Foam under the slab? Transferring heat into the soil is a good thing!
Sheet vapor barrier is only required between a garage space with exhaust fumes and a living space in FL.
The prevailing view is to let the structures breath to avoid any moisture entrapment.
The words mold and mildew will strike fear into most FL homeowners hearts.
Gobs of insulation, yes. Especially in the attic.
Again, beautiful shop! Horses far and wide will be jostling each other to get in there!
KC9KAS
Beautiful garage!
I haven't figured out how to get enough 11% rebate money from MENARDS to make my next trip free! :ROTF:
You put a lot of thought and time into figuring out what you wanted and did an excellent job!
AMC RULES
Far and above...  :bow-blue:
your typical magic :wh: shed Jason.  :clap:
rmaynard
Wow. That is just what I have been dreaming of for the last twenty years. However, whenever the idea is floated, the wife always gives it a thumbs down with a "why don't you just get rid of some of your junk? Building a bigger building will just encourage you to get more". Well duh!?
Anyway, great building Jason. :handgestures-thumbupright:
  • Haha 2
CasualObserver
Sincere thanks for the compliments guys. This has been a long-time dream and it's finally coming to reality. I've been thinking about doing this post for a long time, but wanted to wait until it was more complete and moved into.  Some of the highlights in the project...
-in-floor heat ready
-10 foot ceilings
-attic trusses... Before I sheetrocked the ceiling I also bought and stowed several 4x8 sheets of OSB for flooring up there.  Figured it would be mighty difficult to get them up there through the scuttle hole! Not installed since I still need to insulate the ceiling/attic floor.
-driveway and backyard overhead doors
Just wait, how's the old saying go? "If you build it, they will come!" :D
I haven't gotten the others out of the back shed or shown you the house garage!
I really did consider this, but in the interest of the budget and the fact that I don't need anything taller than 7', I opted to have larger headroom for storage over the door of stuff like those big boxes that the trampoline gets put back in for winter, or lawn chairs... less to see when the doors are open. Besides, if the need ever arises farther down the road, that's a minor adjustment... I already went with the 10' walls... planning for any future needs that the door can be replaced and enlarged with minimal disruption. :thumbs:
Sadly I have. You have to write a real big check at one 11% sale and then wait a long time to keep working on things. I was diligent about watching sales and 11% weeks for the things I was needing. I'm really glad they let you use those 11% checks on purchases at the next 11% sale!
Little side note here for those who might not know.... if Menards does an 11% sale the week after you bought something... they have a price adjustment rebate slip at the front customer service desk... but you have to ask for it, and you have to send your original receipt with it... not a reprint from the kiosk. You don't always get the full 11% because maybe what you bought was already on a better sale or something... but it never hurts to send it in.
Ah kindred spirits. Sounds like something I've heard verbatim in my house as well.
CasualObserver
Yep... I know, and just like my marriage... I won't have cold feet! :lol:
Seriously though, I received lots of opinions on this, and it truly was a 50/50 split. What it came down to is I know that I want it because I want to be able to go in my shop at the drop of a hat in the dead of winter if I feel like it. I have two daughters who are rapidly approaching teenage years... I need the ability to be scarce in an instant. :hide:  Besides, I don't have to fill it and go with it yet... but the slab is insulated and the pex is roughed in because you can't go back and add it later! All about the future planning. :thumbs:
Sparky
Is the concern that it must be kept running all winter to avoid a freze-up? I have no skills in the plumbing heating game but if it's a sealed system why can't it be filled with a glycol or anti-freeze type fluid so that if you did want to turn it off you could.
CasualObserver
My source on this is a relative who sells and installs these systems....  The system will be some water/ant-freeze mixture so it can go dormant if need-be. After seeing his done in his 30x60 shop I have no concerns at all.  The biggest thing about radiant systems is that temperature adjustments can take days to make, so it's not a system you just stop and start quickly... nothing like just turning on a Hot Dawg heater or firing up a Knipco... or just having a furnace running and bumping the thermostat up or down. But.... radiant heat is far more efficient... as long as the space is insulated properly.
mmmmmdonuts
Wow...what a fantastic job you did. Solid execution and amazing results. Enjoy your new shop.
  • Similar Content
    • sjoemie himself
      By sjoemie himself
      Besides working in my workshop I sometimes have, or want, to make improvements to it and I figured in this topic I would take you along for the ride.
      First off today was installing a new door and doorframe. The old one was rotted and starting to fall to pieces, literally.
      My dad made a sweet doorframe out of stainless steel and I repurposed a hardwood door that came out of our home when we renovated the place. Still needs paint but should be good for a few decades I'd say.
      Old door with flaky paint and rotten underside.
      New stainless steel doorframe and repurposed hardwood door.
      Next up was lighting. Few years ago I got some freebie fluorescent lamps but they were old and dying one by one. Having to replace the tubes and/or starters regurarly got kinda lame.
      Since Black Friday is now also a thing around here I snatched a good deal one some LED units which can be daisy chained up to 20 units.
      I ordered six of these lamps for about $80,-
      As a test I installed one.. can you spot it?
      What can I say? Bright as day!
      Greetings from the Netherlands, Mark
    • mmmmmdonuts
      By mmmmmdonuts
      I have approximately an 10x12 lean to shed attached to my house on the side of my side loading garage. I currently have a double door that is 6' wide by 6x10" high. The problem I am having is the door starting to fall apart. It is also framed very heavily with 2x6s. So I am currently looking to either do another double door or a garage door. Part of the reason the door is getting damaged in the first place is because water pools at the bottom of the door in the winter and freezes and I have to basically heat and or chisel the ice away. It is where I store my snowblower.
      My wife ruled out a sliding barn door and a roll up door mainly for appearance purposes.
      I was starting to lean to a 8w x7h regular garage door but see a few cons.
      1) It would block the light when up.
      2) I would lose quite of bit overhead storage and about 2 feet of wall space.
      3) There would be much more work reframing parts of the wall to fit the door.
      Pros.
      1) I could fit my wheel horse plow and snowblower side by side.
      2) Shouldn't freeze to the concrete as easily with a rubber seal.
      3) Don't have to shovel out the doors to get the snowblower out.
      I was wondering what thoughts you guys had on and if I am missing something.
      Thanks.
    • leeave96
      By leeave96
      Need some recommendations on a new shed. I'm looking at putting up one of these metal buildings - I might have posted this link sometime back to the manufacturer's website, but here it is again:
      http://www.carolinacarportsinc.com/configurator/index
      What I'd like to do is put up a building with two garage doors. There would be space equal to the width of the garage doors between the garage doors and the opposite sides of them. This would be on the long side of the building and descriptively is like this:
      wall-space-door-space-door-space-wall
      The idea is to put tractors, junk, pop-up camper, firewood, etc, to the extent possible out of the garage door lanes and that would be to either side of the two garage doors and the space between them.
      So I have some questions:
      - How tall should the building be? Nothing bigger than a 1/2 or 3/4 ton truck would in it.
      - How deep (as you drive into it) is desirable? 20ft, 24ft - looking for some reasonable depth such that I can pull in a vehicle and yet not be so crowded that I can't work around it or even move a tractor around the end of it?
      - how wide should be garage doors be? I'd like to get a full size truck through them without being so narrow that I'd smash a mirror.
      - If you look at the website, they offer vertical or horizontal siding. I'm thinking vertical. Don't know if this is better for looks or strength or both. What you do think?
      - I'd like to put this building on a concrete pad. Question is - how thick and what type - rebar or concrete with fiber or both.
      This is just in the planning stage - not sure I'll do it, but I want to figure out what experience others have with their garages, and lessons learned from theirs you can share.
    • bgh5469
      By bgh5469
      Hey guys wanted to get some opinions on my upcoming detatched dream garage build. I am planning to have 24x28 garage built for my hobbie shop(wheel horses and cars). My question is what kind of foundation should i do. I am in northern indiana and have been told i can build on a monolithic slab(thickened structural slab on grade) or traditional footings with a floating slab. My local building code allows both types for detached structures.  I  prefer footings since they get below the frost line but they are significantlying more expensive. Does anyone have any past experience with a monolithic slab foundations. I don't want to cheap out on my foundation, but if i go with footings I will have give up some other features I wanted.
    • Docwheelhorse
      By Docwheelhorse
      Hello All,
      I ordered an Amish built 20x20 garage/workshop combo back in October and it was delivered and setup today. I can't officially move in with heat and power until AFTER its inspected... but my Nova needed a warm spot for the winter and snuck in. The Wheel Horse Acres sign was made by my father and I thought it looked cool on the front for a photo op. It won't stand up to the weather so it will be hung inside. I can't wait to start turning wrenches on some of the projects that have been honestly neglected around here!
      Happy New Year to All!!
      Tony
