BB4029
Onan E125v head gasket
BB4029
Recently picked up an early 90's Wheel Horse 212-5 with Onan E125v. Intake valve was sticky and it had a bent pushrod. Can anyone tell me of a source for a new head gasket and a push rod? I've looked online but the only gasket I found was a used one on ebay. Thanks.
gwest_ca
Welcome top the forum
Looks like you can get the head gasket from Toro but not the pushrod.
https://www.partstree.com/parts/toro/mowers-lawn-garden-tractor/32-12o501-212-5-toro-212-5-tractor-1990/cylinder-head-and-valves/
Let's hope Boomer sees this and can provide assistance on both parts.
If you need the service manual click on the picture first
Garry
BB4029
Thanks to the link you posted I've got the head gasket ordered. I've straightened the bent push rod but would really like to find a used or new one. I'll keep looking. Great forum with lots of valuable info.
Just found a pair of used push rods on ebay. Thanks again for pointing me in the right direction.
Edited by BB4029
  • Similar Content
    • lsc1257
      By lsc1257
      I have a 1996 520H Wheel Horse for sale.  The tractor has just over 800 hours on it.  It comes with a 48 inch deck.  The deck is a 1995 and has over 1,500 hours on it, as it came brand new with my 312-8 that I sold several years ago.  This 520-H has the swept front axle so it can handle a 60 inch deck.  I just replaced the battery and the deck belt this summer.  The engine is a 20HP Onan and it starts right up but requires the full choke.  The transmission is an Eaton 1100-062, hydrostatic.  The deck is in rough shape but the spindles appear to be in good working order.  The right rear tire has some cracking.  The original operator's manual for the 520H is included, as is the original operating and maintenance instructions for the deck, plus the installation instructions for the deck.  Also included is a new PTO belt and several miscellaneous deck wheels and rollers.  Additional pictures available upon request.  Asking $500.
    • Joe Warren
      By Joe Warren
      Onan model BF-MS2425A Engine for parts. This engine pulled from NOS Bolens QT16 tractor that sat for 40+ years. Engine has less than 25 hours on it. Engine currently stuck. Local pick up in  Easton  MA.  $49  or offer.
    • Joe Warren
      By Joe Warren
      Wheel Horse
      Service Tool Kit
      Onan Industrial Engines
      ON-420-0556
      Kit is missing oil filter tool, otherwise complete. Tools in excellent condition. Small crack in plastic case, bottom, middle.
      $129 plus shipping cost.
      Message me if you are interested in purchasing. Thank you. Joe
    • SPINJIM
      By SPINJIM
      1992, Wheel Horse 520-H.   Onan overhauled: New rings, cylinders honed, valves lapped, new carb., new seals and filters, new fuel lines and primer bulb for easy starts.  Seat is like new.  Front tires are new.  All tires hold air.  Some repainting, but didn't need much; was stored indoors.  New decals.  Other new parts.
      Has swept front axle and Variable Ratio Steering.  Belt cover ventilated to cool back cylinder.  Rear wheel weights are 55 lbs. each.
    • odee61
      By odee61
      Will the PTO work from the 312 Hydro with a 12 hp Kohler onto the 416-8 Onan?  My PTO disc went today. Any help would be most appreciated.
