UncleJerm76
1054 Hydraulic Lift Pump Diagram?
UncleJerm76
Need help locating the Hydraulic Lift Pump Manual/Diagram that came on the 1054. I found the HY-2 and HY-3 manuals but they are both for the old style pumps. The 1054 pump is the one that came with the redesigned return spring as well as the needle bearing upgrade to the drive gear shaft & brass bearing upgrade to the second idler gear. It also has a fill plug in the middle of the reservoir and the control lever bolted to the pump (instead of screwing in).
wheelhorseman
  • Excellent 3
UncleJerm76
Yup that's the one! Is that manual on this site anywhere?
wheelhorseman
Yes go to the manual section and download the manual with the IPL for the 1054
  • Excellent 2
UncleJerm76
Perfect, Thanks Lowell. I didn't realize it was bundled inside the 1054 manual, I should have thought to look there!
