stevebo
312-8 magnum upgrade?
stevebo
All-
I have a mid 90's 312-8 with the magnum 12 on it. Wondering if putting a magnum 16 off a 416-8 is a direct plug in swap? Anyone do this before? If it is not a direct swap, what wiring had to be changed?
19richie66
Wiring should be the same. Two stator wires, one 12volt supply for rectifier regulator. Ground wire for mag unit to shut it off. They are both are magneto engines and have no points. Starter excite for solenoid. All other wiring would probably be just for that particular tractor setup. I can't see why not but then again, I'm not an expert. Good luck! :handgestures-thumbupright:
