echoffmann 2 #1 Posted June 15, 2018 (edited) I have a 2001 268H that threw a rod on it's factory cv18S. I replaced it with a CV20S, swapping stator and flywheel and adding regulator for charging system. I didn't clean the carb and anxiously tried to start it and it ran rough and died. Took the carb off and cleaned everything with carb cleaner and air compressor....now it won't start at all!!!!! Fuel pump was checked and is pumping, the carb solenoid checks out and clicks, I don't know what to check now, any ideas? When it did run maybe float was stuck as it loaded up with fuel and soaked the air cleaner, now dry as a bone, cranks and cranks no fuel getting into carb it seems? All safety items seem to be working as it won't crank without brake on or sitting on mower. Side note....I tried the carb off of the CV18 and it ran, put the CV20 carb on and nothing. Swapped it again for the old CV18 and once again, no fuel at carb to run?!?!?!? Edited June 15, 2018 by echoffmann Share this post Link to post Share on other sites
