Horse Play
So I bought an RJ58...
Chris G
That's a good candidate for a restoration project.
JERSEYHAWG /  Glenn
Best of luck. I never had one.
Glenn
Horse Play
A full restoration is the plan, but it's gonna be a while.  For now I want to get the transmission right, fix the steering issues, and redo the wheels and tires.  Then hopefully get a motor on it; I 'd like to run it around some before the total teardown.
  • Excellent 2
AMC RULES
:handgestures-thumbsup: Nice :wh: score...
lots of potential there.
Horse Play
Yup, I can't make it any worse!
Horse Play
I quickly found out what was causing my lack of steering.  The collar for the steering shaft was loose which allowed for the steering lug-block to be driven into the tie rod.  Someone must have used a big hammer!
  • Sad 1
Horse Play
Is there supposed to be a through-hole on the end of the spindles?  Mine has holes on both spindle ends along with snap ring grooves.  In the owners manual parts diagram it only shows a snap ring holding the front wheel to the spindles.
953 nut
Probably a previous owner didn't have new snap rings but did have a couple of nails around.
Horse Play
I haven't had much time to work on the tractor, but here's a little update.
I'm in the middle of rebuilding the transmission - not what I wanted to do at all, but completely necessary.  While I've been working on that I also sandblasted and primed all the other parts from the back-half of the tractor.  Meanwhile I pushed the front half to the back wall of the garage.  I also bought nicer hood from a forum member.
wallfish
I'm interested in that damaged hacked hood. Only need the front portion so shipping should be easy.
JERSEYHAWG /  Glenn
Slow and steady, nice.
Glenn
Horse Play
My buddy is going to do some welding work on my new hood.  I'd like to keep my old hood around for a little while until I know my intact hood is good to go.  I can contact you when I'm ready to get rid of it, but it may be a while.
Horse Play
The transmission rebuild is ongoing, but getting close to re-assembly.  I also managed to get some painting done.
Not sure what to do about the seat.  Someone welded a U-shaped piece to the bottom along with two pieces of round stock.  The is also two cracks on top around the center hole.  I may try to find another seat pan.
