WHX?? 46,736 #26 Posted May 4, 2018 Just curious, my headlights flickered like mad when the reg was overcharging but seems to have gone away once I replaced the it. Share this post Link to post Share on other sites
CountryRock 198 #27 Posted May 4, 2018 I'd wager mine probably did too. I never noticed the over voltage issue until later last year though. By then the incandescent bulbs were replaced. Share this post Link to post Share on other sites
BlueOx 4 #28 Posted May 9, 2018 OK guys here's my latest findings: Battery is only 3 months old. Owner says the battery runs down after using a couple times. I have 14+ vdc coming from regulator. I show 13.8 vdc going to battery. I checked the clutch to see if it showed any continuity to ground and found none and do have continuity to both clutch wires. But, the battery meter shows heavy discharge when the clutch is engaged. Also, this clutch is a used one the owner had put on to replace original. voltage is at WOT. The readings I get show the stator is putting out correct voltage (AC). Any ideas? I'm not sure where to check next. I've checked all the connections and applied dielectric grease everywhere I could get it. Am I missing something? Thanks Share this post Link to post Share on other sites
pfrederi 17,146 #29 Posted May 9, 2018 Sounds like the clutch is drawing amps at a rate greater than the amperage of the charging system. The electric PTOs for my Electro/Chargers only seem to draw about 4-5 amps. With engine off and clutch engaged can you get an amp draw reading??? Maybe the replacement clutch was not the right one or is faulty... Share this post Link to post Share on other sites
BlueOx 4 #30 Posted May 10, 2018 pfrederi, thanks for the suggestion. I'll check that next. I didn't know until today that the clutch had been replaced. Not sure what model it came off of. I'm guessing that I'll have to have the switch in the "on" position so I have current flow? Also, I seem to remember there was mention of an aftermarket clutch that was more reasonable. Would you know where to get those? Thanks again Share this post Link to post Share on other sites
WHX?? 46,736 #31 Posted May 10, 2018 @CountryRock put the same on as I. You wouldn't be dissapointed. The OEM clutches are garbage compared to these ....will get you some links if you are thnking about replaceing it. 1 Share this post Link to post Share on other sites
CountryRock 198 #32 Posted May 10, 2018 Xtreme Outdoor Power Equipment. https://xtremeope.com/p/xtreme-replacement-clutch-for-toro-78-6990-with-wire-harness-repair-kit/ Worth every penny. 1 Share this post Link to post Share on other sites
BlueOx 4 #33 Posted May 10, 2018 Thank gentlemen, you’re the best! 1 Share this post Link to post Share on other sites
WHX?? 46,736 #34 Posted May 10, 2018 Here is Country's thread on a 246H. He has pics of that clutch installed. Share this post Link to post Share on other sites
BlueOx 4 #35 Posted May 12, 2018 pfrederi, how do I check the clutch for amp draw? I checked the battery voltage when the switch was engaged and saw a 1+ voltage drop. Thanks Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,491 #36 Posted May 12, 2018 Do you have a multimeter that will measure amps? Garry 1 Share this post Link to post Share on other sites
BlueOx 4 #37 Posted May 17, 2018 OK guys, here's my question: I have a multimeter that will measure 10amps, can I test from the clutch plug-in to the battery (+) to check for amp draw ? I'm looking for a quicker way than removing gas tank, battery and fuse block to get the check. Thanks Share this post Link to post Share on other sites
pfrederi 17,146 #38 Posted May 17, 2018 If the PTO is acting normally it should work. If there is an issue it may damage your multimeter. Hopefully it has a fuse. Share this post Link to post Share on other sites
