RJ Hamner
Kohler K301 Has me stumped
RJ Hamner
Let me first say that it ran when I brought it home.  Drove it around the guys yard, tried out the mower, drove it onto the trailer and drove it off the trailer and into the garage.
I've done a "ground up" restore on the tractor (70 Charger 12).  Swapped out the breakerless for a battery ignition and swapped out the 10 amp for a 15 amp stator, flywheel and regulator.
Pulled the head, looked pretty good, new head gasket and head bolts.new fuel pump, fuel lines,new switches and wiring, new aftermarket carb, new coil, coil wire, new points, new throttle and choke cables.
Static timed (twice just to make sure) Have tried Autolite 216's and the hotter 437's. changed the condenser to the high dollar Kohler one.
It will idle but when I give it some throttle it stumbles or will rev up a little then quits.
I've gone thru the "trouble shooting " steps multiple time and to no avail
Anyone got any ideas??  I am willing to try most anything at this point
Bob
Daddy Don
Check the gap on your points and make sure they did not open up on you
953 nut
Could be the float is set a bit low resulting in fuel starvation. Will it rev up better with the choke pulled part way? Another possibility would be the high speed needle needs to be opened up a little.
RJ Hamner
Hadn't thought about the float. I'll give that a try. May have to wait on the next rainy day. The wife wants to do yard work while we have a couple of nice days
wallfish
Condenser on the - side of the coil?
  • Excellent 3
RJ Hamner
Positive side. OMG do I feel like a DA. It should be on the Neg side :blink:
Edited by RJ Hamner
incomplete text
  • Haha 5
Mike'sHorseBarn
We've all done things like that, don't feel bad!
wallfish
No big deal, bet you'll ALWAYS have it on the neg side now just like many of us do because the same thing happened. How do you think we recognize that symptom?
Is it running good now?
  • Like 5
RJ Hamner
Some days I feel like the windshield.  But some days I feel like the BUG.
They say that a man learns through his mistakes.  If that is true......then I am on my way to becoming the next Eienstein
BTW:  It now runs like a stripped a#&@* ape. (OLD NAVY TERM)
Thanks guys
Bob
  • Haha 1
wallfish
Sweeeet!
So how about some pictures of this restored  tractor?
RJ Hamner
I've got the hydro draining as I type then make the final adjustment on the shift lever and mount the mower deck.
We have some rain coming so I might get to work on it in the next few days.
Yard Work AKA "Pride of Ownership" tends to put a dent in my work schedule:(
WHX??
Sorry RJ... have to agree with 'fish....... :text-worthless:regardless of the :text-blondmoment:  !!!!!
  • Haha 3
wallfish
Take it easy on the guy Jim, the wife is cracking the whip about his yard work so he'll get to it. :ychain:
  • Haha 5
RJ Hamner
"Never give a sucker an even break"
Photos Soon!!
Just so ya know....I've had sooo many "Blond Moments" I am now bald.
To me, a trip to Fantesy Island is looking longingly at the hair brush and comb section at the store.
  • Haha 4
wallfish
4 minutes ago, RJ Hamner said:
Photos Soon!!
Get some with you and the tractor and add it here if you're interested. The more the merrier!
  • Excellent 2
WHX??
46 minutes ago, RJ Hamner said:
I've got the hydro draining as I  drain another adult beverage.
Yard Work AKA "Pride of Ownership" tends to put a dent in my work drinking schedule:(
Thats how it should have read RJ..... You forgot the very most important  thing too RJ .... with baldness comes wisdom.... ok we'll let it slide bout the points thing...:lol:
Signed
Midnight Mafia Lawn Mowers
A drinking club with a tractor problem.
  • Haha 1
RJ Hamner
Now THAT sounds like a fun group:D
RJ Hamner
OK  You all wanted pictures.  Refill your glass and set back.  Here we go.   I SHOULD WARN YOU..THE LITTLE GUY IS A CAMERA HOG AND TRIES TO SNEEK INTO ANY PICTURES OF WHEEL HORSES
  • Excellent 3
  • Thanks 2
  • Similar Content
    • BrianKoch
      By BrianKoch
      Looking for a good and flat cover plate for the k301 crankcase. My current one is warped causing oil to leak out.
    • Jeff-C175
    • PWL216
      By PWL216
      Hi. I have a C121 which starts right up but lacks power. A compression check indicated 30lbs of pressure. I took the head off hoping maybe it’s just a gasket, but I think the cylinder needs to be honed or bored out. Based on the attached pics, is this block still good and would honing fix it?
    • Gingerbread
      By Gingerbread
      I’m new to this and not sure if I’m doing this right, But I have a 211-4 with a Briggs 11hp and the thing was sold in my town years ago when it was new. it was my grandfathers till now so it’s a nice piece of history. and it has some electrical problems I can’t figure out, It blows the 15Amp fuse as soon as you turn the key, it all started after the I had to replace the the ignition switch. And now it just blows the fuse. I messed with it when it happened but I have been away in the service for about two years, but now I’m on leave and want to fix my pride and joy but don’t know if my wires are all in the right spot. And my brother actually hooked the battery up backwards by accident for a few seconds while I was away so don’t know if that did anything. So any helpful suggestions or pictures for an example to look at. Thanks
    • Tuneup
      By Tuneup
      So gang, it's Christmas time and my company has extended its forced vacation to two weeks, sucking 7 days of FTO from me. I've got all kinds of things to do for the wifey-poo but what the heck can I do for me?
      I've got two K301s so may as well get out the surgical tools and do a b-gearectomy. The C-125 goes first. Restored that back in '17 and so she's got maybe 75 hours on her. It'll be rather painless and the youngster is visiting so can assist in getting that b-itch up onto the bench. She's already been moved to the garage and the old Kawi and its carb parts moved back to the shed while I search for tiny o-rings. Wish me luck and pics to come. Oh, there is no rattle BUT she's always had a minor knock I chalk-up to excessive end play (didn't measure it back then 'cause I'm bad but, dang!, will now).
