Tim T 4 #1 Posted March 29, 2018 1984 C-195 Wheel Horse, 01-19KE02 PTO Clutch disc plate. I'm at the end of my adjustment and the clutch is beginning to slip again. I haven't disassemble the PTO yet but reading from other threads it sounds like the clutch is conical hub shaped and Wheel Horse did not make many (if any) replacement parts for it. Is there anything new to add on this dilemma? Is the only solution to have the clutch hub relined by a shop that specializes in that? Thanks to those who already replied to an old 2008 thread. Thanks 1 Share this post Link to post Share on other sites
Skipper 1,788 #2 Posted March 29, 2018 I have read there should be linings available from a JD. Don't remember where I read it, or from what JD. If you find out, I'm in for some sets. 1 Share this post Link to post Share on other sites
Skipper 1,788 #3 Posted April 2, 2018 If anyone should have a new clutch, I would really appreciate a measurement of thickness of the friction plates. Thanks 1 Share this post Link to post Share on other sites
bmsgaffer 2,043 #4 Posted April 2, 2018 As mentioned in the old thread, you can switch to the flat dick type clutch. If you look at parts for a newer 520 style, the size of the clutch was increased to handle the load from the 60" deck on the 520H and 520HC and should easily handle the loads for the C-195. 2 Share this post Link to post Share on other sites
Tim T 4 #5 Posted May 4, 2018 Finally got around to inspecting clutch material thickness and is 3/32 inch. I think that is ok. But the internal surface of my pulley housing (P/N 109759) is worn and reason my clutch is slipping. Where do people shop for Wheel Horse parts? Amazon has it for $348 and Jack's Small Engine has it for $272. The latter is the best I have seen. Share this post Link to post Share on other sites
Macgyver 90 #6 Posted February 18 I know this has been a while sense any one has posted about this but I have a good original C195 clutch I would sell for a couple hundred if anyone is interested. It came off an 84. I just changed the engine out to an Onan. Share this post Link to post Share on other sites
Wayne0 294 #7 Posted February 19 (edited) On 5/3/2018 at 11:13 PM, Tim T said: Finally got around to inspecting clutch material thickness and is 3/32 inch. I think that is ok. But the internal surface of my pulley housing (P/N 109759) is worn and reason my clutch is slipping. Where do people shop for Wheel Horse parts? Amazon has it for $348 and Jack's Small Engine has it for $272. The latter is the best I have seen. Have you adjusted your linkage to tighten up the clutch engagement ? The clutch material is fine. Don't throw money at it if you don't need to. Edited February 19 by Wayne0 Share this post Link to post Share on other sites
Rowan 0 #8 Posted February 20 Hello! I am really pleased to find that this subject is still alive. I have a 1982/3 B11 and love it. Ive tried to retire it but every time I revive the old thing with delight.. However.. the clutch is two part, conical, under the engine and failing to engage or slipping. I have heard that the spring adjustment is critical but now cannot find the video to show how to make the adjustment. Does anyone know of it? Has anyone reconditioned the whole unit? In the seemingly unlikely event there are any new ones out there has a anyone any suggestions where? It's not relevant that this request comes from the uk, I am determined to get this machine out again this spring. Any help will be gratefully received! Share this post Link to post Share on other sites
