RJ Hamner
Sundstrand Hydro Manual "Question"
RJ Hamner
I had downloaded the hydro manual for the Sundstrands SM 492-4206 and as I was putting it in a binder I noticed that pages #18 and #36 were/are missing.
My question is does anyone have them??  If they are the notorious "PAGE LEFT BLANK" I guess it wouldn't matter BUT if not they might come in handy.
Just askin'
Bob
pfrederi
page 18 is just a lined page titled Notes
page 36 has serious information about the pump and its needle bearing installation  it shows up in part 2 here
Edited by pfrederi
RJ Hamner
Got it.  THANKS!!!!
Bob
  • Similar Content
    • TonyI
      By TonyI
      I have a 418-c  worked great plowing over the winter.. but now is having no power pulling a load fwd.
      replaced the fluid.. the old fluid didn't look bad. feels a littls better., but still significant loss of power and high pitched whine coming out of the hydro.  the lift works fine
      is there a repair manual our there for the hydro?  Is there a way to reverse flush the system?   I hear sometimes the hoses crack internally and clog things up.
    • mattd860
      By mattd860
      I have developed a kit that allows a Wheel Horse / Toro hydrostatic tractor to be operated by a pedal on the right side of the tractor. The original forward/reverse lever can be retained or removed. The kit includes everything needed to install the pedal kit and installation is simple with the help of a downloadable installation manual. Additionally, only one (1) 1/4" hole will need to be drilled which can be done by a hand drill. No other drilling or cutting will be necessary. Any tractor with this kit can be converted back to stock without any visible evidence that kit was installed. However, you'll never want to do that
      The foot pedal is custom cast in Aluminum, uses brass bushings to minimize wear, and it closely matches the OEM Wheel Horse BRAKE pedal commonly found on 8-speed manual transmission tractors. Modifications were done to the pedal to add the reverse pedal and adapt the pedal to the rest of the kit. For the most part, the pedal looks like it was designed and manufactured by Wheel Horse / Toro. Additionally, a grease fitting has been adapted to the pedal to further minimize wear and tear and if the brass bushings ever wear out they are fully replaceable without having to buy a whole new pedal.
      Here is a link where you can download the installation manual: CLICK HERE
      I am selling these kits for $330 shipped to anywhere in the United States. I offer multi order discounts as well. I will also sell to other countries for additional shipping charges to be determined.
      Thanks!
    • bigcreek
      By bigcreek
      Price DROP!!! Horse traders out there, this great tractor is available at new price.
      99.5 hours, Horse runs like new. Really Like this horse to go to good home. Let’s talk can provide more images if needed
    • olivertractor
      By olivertractor
      I was pulling a roller and thatch rake the other day with my c120 hydro and noticed oil on the back of the fender. On looking closer I saw the plug thing on the back of the pump leaking oil. Any advice on how serious this will be to repair? Anything helps
    • Salbreth1
      By Salbreth1
      Hello guys and thanks again for the welcome! So long story short, my wife calls me and says theirs a tractor on the trash. So like any normal human I hopped in my truck and drove up to find this 418-C and a set of aluminum ramps on the side of the road. Had to be fate.
      So me and my 6 year old sons new found love of tractor pulling has inspired this build. I’ve been researching everything about the model and currently have it stripped and prepping it for paint.
