DANIEL/ALEASHA
Wheel Horse
DANIEL/ALEASHA
I have a 1968 Raider 10 3 speed forward with reverse and low and high range shifter 2 what kind of fluid do I put in the transmission because it is like a transmission slash rear end and also where do you find the headlight switch that pops into the dash
Edited by DANIEL/ALEASHA
stevasaurus
Welcome to Red Square  :occasion-xmas:  I would use 90wt oil, year around, seeing you are from Indiana...it will take about 2 qts.  The light switch might be had from one of our vendors, like @A-Z Tractor  check out our vendor section.  You could also post in the "Wanted Classifieds".  Check out our Manuals section for the manual for your horse...find the part number...maybe the part is still available from TORO.  Somebody here probably knows what the part number you need is crossed to something from NAPA or Autozone.  :)
  • Like 4
rmaynard
You can use 80/90W GL-5 gear oil. Any brand is good. I use Walmart's store brand.
Check with A-Z Tractors, one of our vendors. He may have one, otherwise check eBay or post a wanted ad in classifieds.
Good luck!
rmaynard
The original part number for the switch is 100768. I don't think it is still available new, but it's a common SPST rocker switch.
953 nut
:WRS:       When you remove the "slush" for the rear end it is best to jack up the front of the tractor to ensure complete draining. If it is real bad you will want to run a half gallon of diesel in it for a few minutes to flush it out.
SylvanLakeWH
:text-welcomeconfetti:
KC9KAS
@DANIEL/ALEASHA :WRS:
We are almost neighbors!
WHX??
All above good advice
:WRS:
DANIEL/ALEASHA
What you mean ? You live in Lynnville to
KC9KAS
No, Holland IN
You know the Bunner family?
They are our "garden tractor friends".
DANIEL/ALEASHA
10 hours ago, KC9KAS said:
No, Holland IN
No
DANIEL/ALEASHA
Just now, DANIEL/ALEASHA said:
No
I know the agner's they have a lot of tractors
DANIEL/ALEASHA
On 3/10/2018 at 7:26 AM, KC9KAS said:
No, Holland IN
Hey you got any idea who has a fuel pump for my Raider 10
KC9KAS
Kohler?
About the only new ones are made of plastic.
They do sell a repair kit for the metal ones.
http://www.psep.biz/store/kohler_fuel_pumps.htm
Or an electric fuel pump.
http://kirkengines.com/index.php#FacetElectronicFuelPump
https://www.jackssmallengines.com/Products/KOHLER/Fuel-Pumps-Diaphragms
  • Similar Content
    • AndyZ
      By AndyZ
      Operator manual #A-5274
      Wiring
      6 pages 7.31MB
      Illustrated parts list link
      Use the 1970 parts list for the Raider 10 model 1-6051 and Raider 12 models 1-6251 and 1-6253 with the following exceptions
      For 1970 electric clutch use Electro 12 model 1-7255
      2 pages 282KB
      We also have the 1971 tractor parts manual that followed
      1971 Raider 10 model 1-0300 - (1-0300-6) - Uses HH100-115145C with magneto ignition (Engine oil capacity 2 quarts)
      1971 Raider 12 model 1-0310 - (1-0310-6) - Uses K301S-47407C with breakerless magneto ignition (This model also made in Belgium) (Engine oil capacity 2 quarts)
    • mmmmmdonuts
      By mmmmmdonuts
      My cheap-o walmart U1 battery is starting to bite the dust again (barely able to crank it over fully charged, and ozzing everywhere) after 3 years on my 68' Raider and I am looking into a new battery for winter as I now have a plow setup. I was thinking of either getting the original 22NF battery that came with it or running a mazda mita battery which is a U1 size. Is the AGM worth the extra money over the 22nF even in the smaller size? I think the vibrations keep killing the cheapo batteries and I am trying to make sure I can leave it out in the cold and not have a problem starting in the winter. It does get down to 0F or below zero every once in a while. I don't think I want to go all the way to a 22nF AGM as it is $200.
      Thoughts?
    • ohiofarmer
      By ohiofarmer
      I am picking away at the k series on the raider10. Basically the Piston blew through at the ring grooves as it appears the rings may have had too large a gap. I can feel a slight erosion of the bore where the ring gaps All lined up, but not even close to catching a finger nail.
      I am hoping just hoping out the bore will get it back to round close enough that a ring job will do .
      In any case I can measure the bore and report back. Discipline demands that I do not tear this engine down right now as too many things are taking up my time.
      Just hoping the gurus can offer a bit of guidance
    • davidtmercer
      By davidtmercer
      Just recently had a 10 pinion differential axle gears lose their teeth as shown in this picture from a post in 2014.
      Was wondering if others have had this happen and if they determined the root cause and corrective actions.
      I am considering replacing the two axle gears and five pinions that were destroyed but did not want the same thing to happen again.
      I assume the failure was due to a worn cylindrical spring that I also plan to replace.
    • 12 hp Kohler
      By 12 hp Kohler
      Been looking at a lot or Raiders and Chargers lately and was wondering if they all have LSD? I know most of them did but I was wondering if some of the later models might have had the Uni drives instead ?
      Thanks, Robbie.
