Docwheelhorse
Bore x Stroke of Kohler 10/12/14
Docwheelhorse
Hello All,
need to find a Magnum 12 for another member here... I have a few Mags that have had there tin borrowed etc.... and only way I can figure to find a 12 is by measuring bore and stroke.
I know I could google or look around here--but figured maybe somebody has the info real handy.
Thanks
Tony
JoeM
Measuring the bore is the only absolute way. I picked up a magnum two weeks ago marked "301" on the crank output shaft side of the casting and it had a 10HP bore.
10hp bore 3.250", 12hp bore 3.375"
Model BxS  K241 (10) 3.251 x 2.875.............K301 (12) 3.375 x 3.250.............. K321 (14) 3.500 x 3.250........... K341 (16) 3.750 x 3.250
12, 14 and 16 show same stroke
Edited by OILUJ52
Docwheelhorse
I take it theres no stroke difference for 10/12/14?
Tony
Shynon
12,14 and 16 have the same stroke, 10 is different
richmondred01
 Yep he’s right on the money.
FYI: when the production line was moving they didn’t stop it if they ran out to k241 blocks. They used k301 blocks. The k301 blocks bored at 3.251 can be bored all the way up to 3.415 which will be +40 over for a k301.
