fdchief
PTO shaft
fdchief
Is the connection point on the PTO shafts on all garden tractors the same?
What is the correct terminology for the D-180 PTO connection point?
I know the farm tractors have the 540 and 1000 RPM spline that are different from each other.
I am looking for a PTO tiller for my D-180 and I don
Operator
I can't help on the PTO question but can I throw in a :thumbs: . Someone will be along with more smarts on this one.
Randy
520HC
The D-Series pto is called a 2000 RPM hook up. Your 3-pt hitch is a Catagory 0, so look for this and it will work for you.
HarleyMan46929
The D-Series PTO is called a 2000 RPM hook up. Your 3-pt hitch is a Category 0, so look for this, and it will work for you.
fdchief, the connection is 180-degrees different from the regular 540 RPM where the tractor has the male part of the connection, and the shaft has the female. On the Wheel Horse D-series, the shaft on the implement has to be "male", 1"outside diameter, 15-splined in order to fit inside the 1" inside diameter 15-spline FEMALE coupler on the PTO shaft on the tractor. Good luck!!! You're gonna need a lot of luck...especially on eBay!!!!
I hope this helps clear up the confusion. I just wish Wheel Horse had used commonly-attainable parts instead of the specialized PTO parts they used on the D-series tractors (then); It sure would've made things a lot easier to use and find replacement parts for in the future (now).
