Bowdoinham Dan
Correct wire gauge for k241
Bowdoinham Dan
I have a Raider 10 with a K241 engine that won't turn over.  It's totally dead.  Headlights won't even turn on.  I've got a brand new battery and new battery terminal wires, but the small wiring is old and this might be the problem:  a disconnection somewhere.  So I'm gonna rewire some parts with new wire.
Does anyone know the correct wire gauge to buy?  I can't find it listed in the manual.
rmaynard
It was originally a combination of 14 gauge and 16 gauge for everything but the battery cables. To simplify, I would just use 14 gauge.
  • Like 7
953 nut
If your Raider has the ignition switch that powers the starter directly rather than using a solenoid the switch probably is the problem. Here are a couple wiring diagrams you may want to use to get away from the older style switch. One is for battery powered ignition with points and the other is for electronic. Raiders came both ways depending on the year.
Bowdoinham Dan
It's a K241S- -electric start with a 15 amp alternator.  There's a solenoid.  I'll start replacing old wires with 14 gauge and see what happens.  For what it's worth, the tractor made a buzz buzz buzz sound when I turned the key  before it quit.  A buddy of mine was not able to get it to turn over using jumper cable from the POS terminal to the solenoid.  He thinks it's the stator, but I'm going to try the simple solutions first.
It's annoying.  7 inches of fresh powder last night and I can't run my wh-powered snowblower!
rmaynard
Download the Kohler manual from the files section of this forum. In the electrical section is the procedure for testing the stator. The stator has nothing to do with starting the engine. However, if it is bad (which I doubt) you will not be able to maintain a charge to the battery, and a weak battery can cause a world of problems.
rmaynard
I'm going to venture a guess that your problem lies in this area:
The arrow points to the engine anti-vibration cradle. The cradle is isolated from the frame with rubber mounts. Therefore, it is not grounded to the frame or battery. So Wheel Horse added a separate ground wire from the cradle to the frame. Your starter ground is made through the bolts that connect the starter to the engine block. The block is grounded to the cradle through the mounting bolts, and the cradle is grounded to the frame via a 6 or 4 gauge cable. The battery connects to the frame and completes that ground circuit to the starter.
Check this ground path first. It is a common problem with all 1978 and later tractors with the cradle mount.
JimmyJam
Just throwing it out there: .... 953 nut  made an excellent point .... depending on the year of the Kohler.  I recently acquired a 1973 "No Name" 12.  Couldn't get to start. After some research, I found out that in that one year, 1973, Kohler used a Solid State breakerless ignition module. Mine was bad.  Just throwing it out there!
Edited by JimmyJam
rmaynard
Good point when it comes to an engine that won't start due to no ignition (spark), but in this case his engine won't turn over, which has nothing to do with ignition.
953 nut
The only reason I included the two drawings is that we didn't know what year Raider 10 we were dealing with. With the additional information I am thinking that the first step should be to clean and tighten ALL electrical connections including grounds. I would also suggest moving the ground cable to the engine block.
  • Similar Content
    • JeremyNzl
      By JeremyNzl
      Hi Guys,
      Looking for some advice,
      We rebuilt this k241 with a +.010 piston, Its had a rebore to +.010 but they did it off the manual specs and not the piston.
      Not ideal with an aftermarket piston but I wont get caught on this next time.
      Its developed this oscillating ting noise, its not the metal cover its there with it on and off,
      its 100% from the cam side, does it under low load / slow idle,
      Have setoscoped the motor with a screwdriver to the ear, and I cannot locate it.
      but its in the top.
      Have rechecked valvel clearances x2 already , 1st before initial run, and again day after, very minimal adjustment made after 1st run.
      Ting noise clearly heard in the video , appreciate any advice.
      Jeremy Nz
      https://www.dropbox.com/s/txf8fciaqi5rozg/2021-06-10%2009.08.11.mp4?dl=0
    • WheelHorseC101
      By WheelHorseC101
      When I start my engine it will die once i change the throttle from idle to full throttle and when I switch the cold start throttle to what ever down is. It will just die every time
    • Builderchris
      By Builderchris
      I need some help. I just purchased 3 garden tractors, plus implements, from a guy on Craigslist and I'm having difficulty identifying one of them. It looks to me like it's a C100, but honestly for all I know it could be a Raider10 or a charger10 just as easily. I'm really not sure. The tag under the dashboard reads, Model T10, Serial # 329650. When I googled Wheel Horse T10 I got nothing. Can one of you great Wheel Horse guru's help me out?
      Thanks
      Chris
    • Bowdoinham Dan
      By Bowdoinham Dan
      I've got a Raider 10 that won't start and am not sure what to do, but I suspect that something needs replacing.
      ENGINE MODEL: KOHLER K241S 10HP
      WHAT HAPPENS:  I turn the ignition and hear a loud buzz/crackling sound coming from somewhere in the vicinity of the starter/battery area (PICTURED).  I turn the ignition over again and the sound repeats.  I turn it over a third time and it's dead.
      RECENT MAINTENANCE:  Replaced/patched some wiring, new battery (charged yesterday, had been sitting for the winter), new spark plugs.  I'm an idiot with the internal combustion and am probably in over my head with this thing, but willing to give it my best go with good guidance.  Would really love to get the tiller running for the spring.
      Thanks gang
      Dan
    • 69-Raider-10
      By 69-Raider-10
      Happy Easter fellow Horse Junkies! I am not happy with my Raider 10 after I swapped out the Lauson for a K181. Its not so much the difference in power between the 10hp and the 8hp, its the fact that my other 2 tractors are a Bronco 14 and a 416 8 Onan. I hop on the Raider and even though its the most mechanically sound and aesthetically pleasing tractor, it has the least cajones. I have a low hour 14hp Magnum sitting around that I was saving as a backup but I think I want to drop it in the Raider. Anyone make this type of swap before? Anything that makes it not doable or ill advisable? As always I appreciate the input and your time in answering. Happy Easter!
