r1jakecfd
Christmas Day Storm with FEL
r1jakecfd
Didn’t get to swap the loader out for the 44” 2-stage snowblower and cab on the 520-H before the Christmas Day storm. I had the engine out to redo the top end (decarbon, clean and reseat valves, New gaskets, New fuel pump, tubing, filter, plugs and properly seat camshaft Welch plug) so no time to switch over before storm. It’s just another excuse to use the loader! Merry Christmas everyone🌲🎅🏻
  • Like 5
r1jakecfd
Did I mention how excited I was when I took off the heads and the valve seats were all intact and seated solidly?!? Whew! 👍😂
Adams94
Used my loader to move some snow a couple weeks ago and played with it Saturday.  Can't wait for good weather.
oliver2-44
I'm sure glad I don't have one of those darn ol loaders. They don't seem like they would be good  for a person.......I be so stuck in the seat you'd never get me off of it
Edited by oliver2-44
  • Haha 2
Adams94
21 hours ago, oliver2-44 said:
I'm sure glad I don't have one of those darn ok loaders. They don't seem like they would be good  for a person.......I be so stuck in the dead you'd never get me off of it
Yea you don't want one... if you do get one just call me and I will come get it out of your way lol. I haven't been on it much. Just got it mounted before Christmas
  • Similar Content
    • Rob R
      By Rob R
      So... I got cabin fever and against my best judgement, picked up from my brother a 520H Model # 4120OE02; Serial 1033076 (1991) that he got from a Friend who claim it ran but hasn't been used in years and was in dry storage. Included was a 48-inch triple blade mower in very good condition, total cost $250 ..... I figured that even if the tractor was no good the deck was worth the coinage....... and it had a good new battery....... So got it home fixed the one flat tire, replace the cooked fuse in the fuse holder. Cranked the engine over it cough a few times and then quit, was not getting fuel, replace the fuel line from the tank to the pump, pump not pumping, replace it with a B&S pump, cranked her over and she started right up ran and idled decent with no noticeable smoke. p.s. the hour meter is disconnected but you can tell she was run hard and put away wet but overall, in fair to good condition.
      So without doing anything else time for a test drive. It moved forward and backwards took her out into the yard got about 50 feet and the motor started laboring to me was like the transmission was putting a heavy load on engine, I tried to shift into neutral, but it wouldn't let me do that and then the engine bogs down and shuts off. Wait like 10 seconds start her up again and the issue repeats.... In all my years I have never had anything close to this issue hence my call for help.
      I did all the normal stuff trans fluid looks clean added some 10-40 weight to top her off, did not change the filter yet as I do not have one in stock.  You can start the engine without engaging the transmission and it will run fine until the cows come home..... put it in gear forward or reverse and it will go an little ways and then the load condition occurs, the engine loads up and is dragged down into a stall.
      Appreciate all your advice as this one has me stumped......
    • PWL216
      By PWL216
      Looking for a good to very good condition hood. Thx
    • PWL216
      By PWL216
      About a year ago I bought a C-121 auto with the intention of using it as my go-to mower. Shortly thereafter I got a great deal on a low hour 314-8.  It ran perfect and had several attachments - it became my new go-to mower.  So, I decided to repurpose the 121 to be a front end loader. After purchasing the build plans from P.F Engineering (which are excellent), I realized I couldn’t build it for less than $2k in material. I decided to look for a used one and found a Thompson TC10 local to me, mounted on an “end of life” 1077, for $1,000.  The loader swap itself was pretty straight forward. The only modifications needed were drilling a couple of mounting holes in the tractor frame, grinding away a little of the loader top frame so the hood opened/closed and welding in a new hydraulic pump mount. I have a few things to button up still and the bucket itself needs attention but it’s fully functional. I also bought a pair of clamp-on pallet forks.
      I also did a “refresh” of the 121. The total project cost is shown below. Roughly $2,300, with just the FEL itself being around $1,300.
      Tractor
      C-121 Auto $500
      Solid engine mounts $50
      Front End Loader
      Johnson 10TC $1,000
      Hydraulic fluid $35
      Spare hydraulic hose $40
      Ignition
      Battery $35
      Battery cables $20
      Points & Condenser $20
      Fuel
      Carb & Gasket $65
      Electric fuel pump $60 (later removed)
      Air filter $10
      Fuel filter $15
      Fuel line $10
      Spark plug $5
      Decals and Paint
      Decals $115
      Paint $30
      Lights
      Headlight Lens $45
      LED Headlights $25
      Rear lights $25
      Misc $200
    • Truckedup1
      By Truckedup1
      I have a very recently restored 1989 wheel horse 520-HC tractor with 60” deck. Family owned for over 10 years but now it’s time for another project. Please contact me with any questions I have the original 60” deck but it was rough so I sourced the current deck off this site, it really is in excellent condition for not being restored.
    • jleitschaft
      By jleitschaft
      Hello All,
            New to the group and looking for advice. My father was a devoted wheel horse enthusiast for many years. He only cut grass with a wheel horse tractor (rear discharge deck) pulling a Parker lawn sweeper. We have a lot of property and it took him a while but he was retired and loved being on the wheel horse. When he got sick, I had to take over all the lawn maintenance. All of our family lives close on the same road. At the time, I was responsible for maintaining 7 properties plus my fulltime job. Using the wheel horse was not an option for me so I bought a commercial zero turn mower.  Unfortunately, in 2017 my father passed away. I have all his tractors and it has been hard for me to think about what to do with them. He had 6 wheel horse tractors total. 3 tractors we used for cutting grass and 3 tractors are show pieces that have never cut a blade of grass. I have a few guys that have been asking me for years to sell them but I am not sure if I’m ready. I am turning to the group because I am lost at what I even have. Its my belief that the tractors are rare and the conditions are mint. If anyone would be willing to express their opinion and provide feedback I would be grateful.
      Wheel horse 420 LSE (shows 7.5 hr)
      Wheel horse 520 hydro (shows 92 hr)
      Wheel horse classic GT (shows 26 hr)
