953 nut 51,675 #26 Posted January 4, 2018 20 minutes ago, tallen4392 said: I cannot find any switch on or near the clutch pedal or anywhere else in that area could it be somewhere else ???? The switch is probably mounted inside the side rails under the seat. When the clutch is pushed down the arm the idler is on will push a small white finger activating the switch. Share this post Link to post Share on other sites
tallen4392 67 #27 Posted January 4, 2018 Thanks again I will look again tommorow but I did not see any switch I’ll will check it out I ran a wire from back of ign switch to selonide and it starts fine I am guessing it is pto or clutch switch never had a seat switch 1 Share this post Link to post Share on other sites
