Noobwheelhorseguy
D-200 hydro fluid.
Noobwheelhorseguy
Winter is upon us and my D-200 is barely moving and dont know where to put the ATF in at on it? i never really dug into where it filled at and i need to know asap, snows acomin. thanks
"D"- Man
If it is like the 18 Automatic it should be at the right rear corner on top of the trans-axle.
pfrederi
Are you sure it uses ATF??? What year is it...what color is the fluid in there now.  Early ones had ATF later 10w-30 motor oil
Noobwheelhorseguy
Thank you for the help fellas, I found where the fill tube is at and its 10W30 oil not ATF. good thing i didnt mix the two! haha. i do appreciate the help.
Pollack Pete
I'd use Mobil 1 synthetic motor oil.Great for Winter use when the hydros don't want to work til warmed up.Great for Summer use too.I use Mobil 1 in all my hydro tractors.
Sarge
Amen , that Mobil 1 synthetic flows extremely well in cold weather - sure helps with the D's pump being coupled directly to the engine , especially when it's really cold out .
Sarge
