scott ostrander 30 #1 Posted December 6, 2017 (edited) This summer I put gear reduction steering and the swept front end out of a 520h into my C 195 and it worked awsome. But now my plow is hitting the tire. I'm going to build a extention to correct this. But I've done some research on here and I'm even more confused. I have seen extensions anywhere from 4-1/2" to 12" Does anyone know what the original extension kit length is ? Edited December 6, 2017 by scott ostrandet Share this post Link to post Share on other sites
gwest_ca-(File Mod) 10,495 #2 Posted December 9, 2017 I don't know what the original length of the extension is. The wheelbase of the straight axle models is 45-1/2" and tread width is 38". The HC model at the same time with the forward swept axle has a 47-1/2" wheelbase and a tread width of 40-1/2". Allowance for the wider stance would require more clearance for when the wheels are turned. Garry Follow this thread for the 81640 extension dimensions Or click on the picture below. Then on each picture and it will enlarge. Share this post Link to post Share on other sites
