Seacrestbf
D 200 Engine
Hello
I have a D 200 and my sons have been cutting the lawn this summer and nerver check th oil and the seized the motor. I freed the motor up and it runs fine until there is a load. I checked the Compression  and I have one dead hole. ;-(   it broke my heart. I have a Mower, tiller, and snow thrower.
Any Advise? Should I buy a motor? Or rebuild or scrap?? I liked the machine. But I dont want to dump a ton of money into it if it is questionable. I am not sure if it is a Kohler or Onan??  Any thoughts
Thank you
Brian Foley
  • Sad 1
Brian, not much advise but if the engine is original it would be a Kohler 20 HP.  That is a lot of tractor and accessories to let sit if the hydro was strong, it may be worth rebuilding the engine.
The site achto shows is a good source as is ebay.
A word of caution here, parts for these big twins - like your K532 - are getting scarce ---- especially CONNECTING RODS!  Its very possible you will need machine shop work what with the engine running low on oil, bore job to clean up the cylinders and regrind the crankshaft, etc. Before you start buying parts determine what work will need to be done . IE: if your crank needs turned then you will need rods and they just may not be available!!
In the last couple yrs I have needed a rod for each of my 18 and 20hp twins, I ended up faithfully prowling ebay and after a few weeks was lucky enough to find them used -- and these were in standard size! You may well need undersized..
Edited by pacer
  • Excellent 1
If it needs rods, I saw a site that makes rods out of aluminum billet stock  I would nose around a bit before making a hasty decision. While the "D"'s are not my favorite's they can do a lot of work for a long time yet.
Do you have info on that site?
Looks like "Free" lawn mowing help wasn't very free.:(
  • Sad 1
You tube : Kohler K series connecting rods 2015/2016 design improvements explained - clearancing 1 cylinder engine for billet rod, Midwest Super Club.
As far as a direct link to the video, I did/could not persue it too far yet, ite a long time to find it the second time, and have nbot made it back yet to look any more.
That's fine. Thanks. Know where to look now ;-)
Would you consider Replacing the motor with something else ??
Send the Motor to a rebuilder?? Brian Miller??
If you are not into keeping it stock consider the Preditor 22hp V twin as a replacement, I have used many of the HF engines
and have had very good luck with them. Their is many parts sources for them now and seem to be very reliable. In our pulling club several
guys have been running them for the last couple of years, and to be honest with you they are kicking our butts at about 1/3 the
 price of a rebuilt/built Kohler.  I think if you go to Brian Millers site the price of a rebuilt opposed twin is going to be in the $14-1500 range.
Harbour Freight and a little fab work . not to complicated, put one of their 13 hp motors on my GT 2500
 and a couple of holes drilled in the base is all I had to do. Plan on replacing it with a 12hp Kohler when
time permits.
I feel for you. In 1993 western PA had a monster snow (22" in 24 hrs). My dad had a D200 (which I now own). He called my brother in law who lives on the same lane and suggested he fire up the Horse and use it to clear the lane. Jeff took him up on it. Unfortunately my dad forgot to tell him about the engine oil leak. After about three hours of running, clearing a 1/4 mile lane, the engine seized up. Dad had to get a new short block from Kohler and have it installed, not a cheap fix. But I am still using that tractor today.
If you can find the parts it is very well worth the time to repair this tractor. Do some research, those K532 engines are still out there. Maybe find a tractor bone yard for parts, or the whole engine.
Might also try this place:   www.isavetractors.com   207-298-9701. They advertise in LAWN & GARDEN TRACTOR magazine and claim to have "everything you need to bring your old engine back to life". They specialize in Kohler K series engine rebuild kits.
Good luck.
Edited by slufoot733
  • Similar Content
    • By Niagara D
      Looking to get out of the WH business so looking to unload everything as one lot.  Have D160 w/ Onan 16 twin original.  Use it to mow last year so it will run, have not started it this year.  Burns oil but good machine otherwise. Has 48 inch belly mower and snow blower. Other machine is 18 Auto with bar tires, 3 pt hitch and rear PTO, 48 inch Rear finish mower and snow blower.  Current state is that it has motor and hydro pump out because the O rings for hydro pump were leaking so while making that repair I planned to change the Pump shaft out.  Motor and drive are good and I have mowed with this in the past.  Spare parts I have include Most of another Machine that was stripped down so there are spare tires rims, rear end, steering components, I also have 2 o 3 spare hydro pumps, extra hydro line sets (hoses and hard lines), Another 16 horse ONAN that blew a rod currently torn down (may be salvageable, never followed up with it).  I am getting several Allis Chalmers garden tractors passed down to me and since I barely have time for my WH I figure its best to pass these on to another collector and make room for the new fleet coming.  Please reach out to me Via Email and we can exchange contact information and I could send pictures when I make time to take some this week.  Thank you.
    • By tommyg
      I’m not sure I’m in the right place for this post, but I’ve got a leaky hydro cylinder on my D180. It’s the primary one that lifts the deck, snowblower, etc. I could take a chance on finding one on ebay, but I was wondering if there’s an alternative besides used.
    • By pond195520032003
      This is my 1974 Wheel Horse D-200 with a 20hp twin cylinder Kohler, rear pto, turning brakes, 3pt hitch, ag tires all around, weights all around and a 54" snow/dozer blade! also have a rear finish mower, reat roto tiller, and a Didier 50" sickle bar!
    • By Sarge
      Fast question ...
      Per the IPL for the 6-1141 and 6-1131 54" & 56" blades - how is everyone pinning the rear blade lock arms so they can't unlock the blade ? I've ran into problems with this thing before wanting to unlock itself and drop the blade half off the tractor. It seems when back dragging rough pavement, especially if I back into a snow bank the thing is moving those locks out of position and allowing the frame to drop off. The only reason it stays at least somewhat under the D is the lift arm , but getting it back into position is no fun due to the weight of this thing and especially out in the snow/cold weather. Last time I had to drag the thing back to a clear area so I could wrestle it back into position, lift the frame and lock it again. I did wire them shut for now, but don't trust it and I use it to back drag quite a bit on rough areas I don't want to ram the cutting edge against and risk damaging the rear axle differential or anything else. Mine has been rebuilt with a new cutting edge of 1055HC and the frame is highly beefed up - most of it is now boxed in and the thing has gained nearly 50lbs of steel. It cuts great, almost too good but that random dropping it off is starting to irritate me - need some ideas here...
      The smaller 42" and other frames lock from the other direction - so to speak. The brackets are also drilled to accept large hair pin cotters to keep those locks in place - I see no way the bigger blade frame is designed for that, unless I'm missing something ?
      Sarge
    • By Sarge
      What started out as a simple task of moving my 6-1/2' x 12' utility trailer to unload it's contents back into the Shed Repair Project after building a new floor turned out to be a really bad day . I figured the weight of the trailer and it's load was probably around 2,500lbs or more and the big D-180 should be able to handle it . Used the 3pt hitch and an adapter to lift the trailer tongue and off I went...until I got to the end of the north drive and the pump coupling on the hydro failed - badly . In hindsight - the trailer probably weighed closer to 4,000lbs the way it felt behind the truck ...
      Now , the trailer had to be taken off the tractor and put on it's jack ....which didn't work out too well loaded that heavily . Since the trailer was built with 2x3 angle iron on the tongue it decided to fold itself into a pretzel - despite the wheels being blocked tight so it couldn't move . It fell over and I had to use the HI-Lift to get it off the ground . The sight of the trailer falling over in the rear view camera on the Dodge is still well embedded in my memory - I knew that was going to be another large project .
      The coupling had an earlier repair from last winter's failure - so a pto pin was driven through the hole to get it out back to my work area to be fixed later . It made the short trip , but just barely and the tow valve was frozen tightly . As it turned out , the damage to the D was a much bigger issue..and cost 3 times as much in total .
      The pic doesn't do the damage any justice - that entire tongue was bent badly -
      Sand blasted , new tongue built and waiting for paint -
      Painted , as it sits now awaiting the lights , wiring and re-install the floor decking .
      All the while - got more work done on the D's pump problem . Found a great used pump , as well as a spare coupling in good shape . After a lot of machine work ($$$) we came up with a solution and everything was back together...
      After all this I found that both the original mufflers were completely shot and falling apart - so another project ...
      Bought a pair of 180* mandrel bends , two cone transitions and a pair of @jimkemp 8" mufflers (very nice, btw) . Fabricated the flanges for the engine's exhaust ports , as well as the pipes for the stacks -
      Spent a lot of time rolling the engine over on the starter to slowly prime the pump back up and finally , after several months - fired Big Ugly to test the exhaust before painting the stacks . No leaks from the hydro thanks to some new o-rings and backer rings from @pfrederi on the hydro manifold , that was a big relief .
      A bit shocked at the sound of the big opposed twin - somewhat like a Harley running on the choke or something - but overall not obnoxious or too loud ....
      D180 startup.mp4
      If you don't want to wait for the MP4 to load - here's the YouTube link -
      I don't think the camera's microphone will show the sound too well , but so far I like it . Took a ride around the block , nice having this beast back up and running , finally . Now to finish that dumb trailer....pretty much wasted nearly the whole summer getting all of this done plus the hours at work . I'm about ready for a break but need to get ready for winter .
      Sarge
