Fordiesel69 206 #1 Posted November 2, 2017 I was reading on a puller forum that if an 8HP K181 is operated with a rod knock, most likely the cam will be cracked. The person stated that the 8HP is very unique and the connecting rod passes just a few thousands away from the cam compared to the big block engines. Is this a correct statement? I have rebuilt some k181;s back in the late 1990's and early 2000's and have not seen this happen unless the engine blew up. Share this post Link to post Share on other sites
oldredrider 2,547 #2 Posted November 2, 2017 That statement is correct. Connecting rod bolt tangs MUST be flattened just to give clearance. 2 Share this post Link to post Share on other sites
